RN2483 won't sleep
I have tried for longer, but no change.
Actualy no there is no resistor on that, should there be? which value would be good? 10k or something?
I am using the Pro trinklet, which uses the Atmega328p, there should be enough memory for this application.
Ahh i didn’t know that the RN2483 could be used to wake the arduino from sleep. That is smart. :slight_smile:
So you want me to try a lower baudrate?
I have tried with a 10k resistor from reset to VDD, but does not seem to do anything.
I have also measured the sleep current of the arduino, whic is 2.8uA at 3.2V supply, directly from the batteries, without regulator or power diode. and in idle mode (delay) it is about 4.8mA which seem correct,
Futher more i have tried to only send the sleep command without putting the arduino to sleep like this.
void loop() {
    ttn.wake();     // wake the RN module from sleep, if it is still sleeping
    delay(5000);
    ttn.sleep(5000);    //sleep RN module in [ms]
    delay(5000);
This only seem to lower the current from 27.6 to 25.4mA
Also if i try to reset the module in the loop, with a large delay in between, the current drops to 5.6mA
void loop() {
  delay(5000);
  digitalWrite(12, LOW);
  delay(5000);
  digitalWrite(12, HIGH);
  delay(5000);
Anyone have any ideas?, How do TTN.sleep function work?
do you have communication between your RN2483 and processor ?
because with softserial @57600 thats not possible
Yes the messages gets received in the TTN consile. so i guess it works.
How can i make the RN2483 run at a different baud rate? to test it out
good luck
Have now tried a lower baud rate of 19200
with this code
#include <SoftwareSerial.h>
#include <TheThingsNetwork.h>
#include <OneWire.h>
#include <LowPower.h>
const char *appEui = "XXXXXXXXXXXXXXX";
const char *appKey = "XXXXXXXXXXXXXXXXXXXXXX";
#define loraSerial SoftSerial
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
#define SpreadingFactor 7
SoftwareSerial SoftSerial(10, 11); // RX, TX
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan, SpreadingFactor);
void setup() {
  loraSerial.begin(19200);
  debugSerial.begin(9600);
  debugSerial.println("\n Setup started");
  //Restart the RN2483 module
  pinMode(12, OUTPUT);
  delay(500);
  debugSerial.println("Now ttn.reset()");
  ttn.reset();
  debugSerial.println("Now show status");
  ttn.showStatus();
  debugSerial.println("Now Joing network");
  ttn.join(appEui, appKey, 4, 10000);
void loop() {
  debugSerial.println("Loop");
  delay(5000);
  delay(5000);
And the result is the same, only 2mA drop in current when sleeping the RN2483 module.
What are you expecting to happen? You may be putting the RN module to sleep but you are not putting the processor to sleep.
As i said earlier, the MCuy only pulls 5mA when active. so that is not the problem here.
I Also tried putting the MCu and the rn2483 module to sleep, this result in a 22mA current draw, which is 1000x higher than it should be, and what others are reporting.
Perhaps ttn.sleep(5000); isn’t actually doing anything. Can you make it sleep for a long time (say 30 minutes) and then try talking to the RN2483. It clearly shouldn’t reply. If it does then clearly it isn’t asleep :slight_smile:
I am using this library https://github.com/jpmeijers/RN2483-Arduino-Library with the RN2483 and Arduno mini pro and I get 270uA when both (TTN module & Arduino are asleep).
Your numbers do not stack up. There is no way the Trinket draws only 5mA without some form of power management. Given the code shown in the previous post, 22mA is reasonable.
The datasheet for the 328p say 5.2mA at 5V 8MHZ in active mode, so it seem legit.
My Pro trinklet runs at 3.2V but at 12MHz. I have removed the regulator from the board together with the power led.
Thank you, i will try to communicate with it while it should be sleeping, didn’t even think of this!
270uA seems a bit high too does it not?
270uA isn’t bad for a first attempt and includes the moisture sensor and BMP180 pressure sensor also.
Sure, it is not bad, for a first attempt. :slight_smile:
I had a similar issue using a wemos D1 mini with a RN2903. Turned out that when I went into deep sleep , the pin I was using for uart tx (pin 15) when high which caused the RN2903 to wake up so the D1 mini was sleeping but the RN2903 was awake. I ended up using a different pin 0 for tx.
In my case it was about 3ma of current being drawn by the RN2903. Once I changed the Tx pin I was under 1 ma. But the battery still died after a few weeks so I ended up using a TPL5110 to control power. My sensor wakes every 90 minutes for a reading.
The software serial pins is draining the current here. Many years ago, I would put the pins as output with internal pull up before sleep. Recently when I used the AltSoftSerial instead of SoftwareSerial, only an end() is enough to put the pins into proper low power state. Just need to call begin() once awake.
I have now tried several of your solutions. but ended up building a new node. with another set of parts.
Same setup as described earlier, but new parts.
The idle current is now only 8mA, and sleep is 4uA, which is where i wanted it.
So i guess there is something wrong with the first rn2483 module, since it is consuming 22mA in idle, the new one only consume 2.6mA in idle, as the datasheet confirms it should.
Maybe i find the error some day.
able to share your end code?
To test power sleep functionality i only used this code
void setup() {
  delay(500);
  ttn.reset();
  ttn.showStatus();
void loop() {
  delay(5000);
  ttn.sleep(9000);    //sleep RN module in [ms]
  delay(1000);
Rest is connected to pin 12, and is pulled up py a 10k resistor.
Of cause this is only the power down test. my final code is different, and still a work in progress.
