The Arduino Code over here is using the same LoRaMac-node as a basis as the I-CUBE-LRWAN code from ST, but with a lot of fixes. Perhaps you can simply transfer the fixes.
First off US915_HYBRID is a bad idea, as it’s using the first 16 channels (not 8). And it’s fixed to use the first 16 channels. So kind of useless. There is no way for a regular gateway to send the channel mask during the JOIN_ACCEPT, so with a good probability about half of your packets get lost.
You’d really want to setup the channels masks before you attempt the join. The code in LoRaWANClass::setSubBand shows how to do that.
Not sure whether this is all you need to do though. Had a miserable time getting all the kinks sorted out with this code to make it really work well.
@GrumpyOldPizza first off, thank you for taking the time to respond and for the open source work you have done with the Arduino libraries and developer kits. Your response and my review of the linked files answers a ton of questions, so thank you. It also raises a bunch more! However, I will take another pass at modifying the region files with the fixers you provided. My only follow up question at this time is that the LoRa Mac region files you linked to do not include a US 915 Hybrid but rather refer to just US 915. Is this semantics? Meaning, you are using the US 915 source to create the sub band information for an 8 channel hybrid environment? Thanks again.
Yes, I ditched US915_HYBRID. Mainly because it’s 16 channels, and hardcoded to channels 0-15(. Not sure this is useful for any practical purpose.
What you want is US915 with only a block of 8 channels enabled. And for that you simply need to hack up the RegionUS915.c code so that the proper ChannelsDefaultMask is restored (or whatever the name was) instead of the hardcoded values, and then you need to set the current channels mask and the default channels mask to your subband (before you join). The rest of the code changes in RegionUS915.c are structural, or sneaky optimizations (like the code in RegionUS915NextChannel()), which you don’t really need to get going.
Hi guys,
I am totally new to both STM32 LoRa Discovery Kit (B-L072Z-LRWAN1)
I have programed the node and it is running. I can view the message using Tera Term terminal.
I have also opened the LinkLabs gateway using the same terminal.
I can’t figure out how to see the STM32 device’s message on the gateway.
Can anyone help?
We are using RPI3 + iC880A-SPI concentrator but as soon as the GW has two nodes sending data relatively fast (around every 500 ms) the gateway only receives messages from one node as if it is unable to receive from two simultaneously. SFs are different so that can’t be a problem.
Hi!
I’m working with last STM32CubeExpansion_LRWAN_V1.3.0 and TheThingsNetwork can’t recognize Join requests. I have tryed an old example of a STM32 Workshop (see link below) and AT_Slave example is completly working.
I have tried with V1.2.x and it doesn’t work either. Something happens with the new loramac stack.
It would be helpful if you could explain if the join requests are being received by a gateway or not.
If they are, providing their details - raw packet payload as base64 or hex - would be very helpful. This is not private information, as it is exactly what goes over the air and could be received by anyone else with an antenna.
Finally are you seeing the join requests in the TTN console at all?
I don’t have an answer for you, but it works… I went through the ST workshop on this and it was really a scramble with copying and pasting code, which eventually worked. The explanations were fuzzy though, so I plan to go through it again, if I can find the slides or workshop video.
