Implementing LoRaWAN yourself to talk to TTN is on topic (ie, there are many ways to do this beside using “the TTN library” - whatever that is or was, it is not what most people are using to begin with)
But using a LoRa chip for something other than implementing LoRaWAN to interoperate TTN is off topic
Of course as a practical matter, if you are embarked on DIY project for any purpose, one thing you could do is temporarily fire up some existing code such as LMiC or whatever and either make it log the SPI operations it performs, or use a cheap little USB logic analyzer to see what it is doing.
If your writing your own library, its beholdent on you to check that it is correct yourself.
Thus whatever the datasheet says your going to have to measure the power output in reality across a few different modules. And if your going to have to do that a few simple tests will confirm if your reading of the datasheet is correct.
what i said about RFO was right, but i still don’t know why they said it’s between -4 to 14 dBm and in the same datasheet in other section they said it’s 15 dBm. anyway, about how to set this in the register because you have 2 variable you need to set (maxPower, and outoutPower), you can notice we have 2 regions, from -4 to 0 dbm and from 0 to 15 dBm. for [-4, 0[ set the maxPower to 0 and that will give you a Pmax = 10.8 and from this equation Pout = Pmax - 15 + outputPower = 10.8 -15 + outputPower = -4.2 + outputPower, we can find outputPower = Pout + 4.2, and for the region [0, 15] we set the maxPower to 7 (the max value) so we will have this now , Pout = 15 - 15 + outputPower = outputPower.
About the PA_BOOST it a forward calculation nothing fancy, outputPower = Pout - 2 and don’t forget Pout should be between 2 and 17,
to switch betwen RFO and PA_BOOST, set the bit 7 in PaConfig register. and disable the +20 dBm option in the Pa_Dac register.
About the +20 dBm option, it’s the same as PA_BOOST but instead of Pmax = 17, Pmax = 20 so outputPower = Pout - 5 , and you need to enable the PA_BOOST and then set the PA_Dac to 0x87, 7 to enable the +20 dBm option, , note : just by setting the outputPower to 0xf (15) you will get the 20dBm, and to disable this feature just set PaDac varaible to 4 ( set the PaDac register to 0x84) to disable it.
for the OCP, they have a table that gives you how to calculate the ocp value from the Imax,
ocp-trim [0-15], Imax [45, 120 mA] , Imax = 45 + 5 * ocpTrim
ocp-trim [16-27], Imax [130, 240 mA] , Imax = -30 + 10 * ocpTrim
ocp-trim > 27, Imax = 240mA , Imax = 240 mA
and about the Imax which is the current need for the Tx we can find this in the datasheet:
RFOP = 13 dBm uses 28mA
RFOP = 7 dBm uses 20 mA
PA_BOOST = 17 dBm uses 90 mA
+20 dBm opton uses 120mA
the OCP need to be enabled if you want to use the PA_BOOS.
about the order of the settings. i will just try to set the register in order, just in case.
Definetly worthwhile checking that the power level you think you are writing to the SX1276 matches the reality.
I remember looking at a well known library some time back, due to an error in the library code it was setting up the SX127x for 2dBm more than intended.
@ofauchon, I’m comparing my code with an existing library, “pyLora” and “raspi-lora” and for the moment i’m able to transmit a message from my raspberry pi (that uses lora bee “sx1276”) to a lora-ttgo board. the problem i’m facing now it’s about the range, i mean i’m using the same Tx power for both examples (example uses raspi-lora library after correcting it to use the lora mode and in the other example i’m using my library) and when i use my library i need to get both boards closer to be able to catch the data which is weird because i’m almost sure we have the same function that writes the output power and maxpower to the SX1276 register. i will upload the code to github soon and i will send you the link so you can have a look. and about your suggestion it will be a pleasure for me to have more information how things suppose to be done. thank you.
@LoRaTracker: well about the power level i’m not really sure if it matches what i want, but if i compare my code to anther library about the Tx power section i’m kinda sure we have the same code. but when i test it i face a distance problem, i mean i need to get my distance closer to be able to receive a message even i’m using the same Tx power with other library. for now, i will try to read that register after using the library without clear it and compare it to what i get from the register after using my code. thanks
@cjhdev, RFO or BOOST it’s for the Tx power range you want to use, RFO is between -4 to 15 (or 14) dBm when the BOOST can reach 17 dBm and with the +20dBm option you can reach the 20dBm. and i’m working below the 14 so if i want to consume less power i need to use RFO unless i need to work above the 15 dbm. thank you
this is the specification of the lore bee module, and they mentioned you can reach the +20dBm or use the 14dBm, which mean the can use the PA_BOOST because if you want to use +20dBm option you need to use the PA_BOOST. and i my code i’m not using the PA_BOOST any way, i’m using the RFO which is the main PA that uses a low power consumption. but to be clear here, i already can receive data but the problem here it’s not from a long distance, let’s forget about the long distance for now, if i use raspi-lora library and use Tx power = 8 dBm i can receive a data in 1 meter distance, if i change the code and use my library with the same Tx power = 8 dBm i can’t receive any data and i need to get the board closer to transmitter ( about 0.5 meter) then i can receive data, which is weird especially the Tx power function in my library and the other library looks the same.
There is no way I know of to reduce the TX power enought to cut the line of sight range down to 1m or less. So if you cannot communicate over that distance there is probably another fundamental issue.
Measuring the actualpower output is where I would start loooking for issues.
The same, except you say you are using RFO and not BOOST, which on that HopeRF module is not physically connected to the matching components and antenna.
Explains why it only works at 0.5m.
edit:
For some extra detail, the PA connected to the ‘PA_BOOST’ pin can operate in 2-17dBm mode or fixed 20dBm.
The RFO PA is not connected to the ‘PA_BOOST’ pin.
i’m not using RF96/95, this lora bee uses the sx1276, and about the antenna if is it connected to PA_BOOST or the RFO, i don’t know, i didn’t even though that is an option, though the antenna suppose to work for both, i guess i need to check that out. now after i have checked the raspi-lora library, i found this :
if self._tx_power < 20:
self._spi_write(REG_4D_PA_DAC, PA_DAC_ENABLE) # enable the +20 dBm option, `0x07`
self._tx_power -= 3
else:
self._spi_write(REG_4D_PA_DAC, PA_DAC_DISABLE) # disable the option, `0x04`
which is the opposite of what should happen, and after that i checked the PA_BOOST register and it’s always enabled, which mean this library use all the time the PA_BOOST. i guess the antenne is connected to that PA_BOOST pin. and about the 20 dBm option the description in the datasheet said this option will Set Pmax to +20dBm for PA_HP doesn’t that mean "Pout=Pmax-(15-OutputPower) " will become “Pout=20-(15-OutputPower)” ?!
it’s just my way to learn new things and learn the basics of a new technology. and as you can see i already found some mistakes in those library which i will never be able to figure them out if i just trust them. like using a wrong frequency and the wrong power transmission won’t end good. any way, it’s just more fun for me, by they way thank you all for the help
Back in 2015 I had to write first a PICAXE routines for LoRa then, Micromite and finally Arduino. There were no useable libraries available at the time for point to point LoRa. Clearly when the objective is to write your own point to point library you need to understand haw to configure the LoRa device registers.
My understanding of LoRa devices at register level does not help me to understand LMIC though, the power setting in LMIC for instance is just a function call, its not necessary (or helpful in my case) to know what that function call does in detail.
I know for fact that writing my own library will not be better then a library wrote by a group of engineers have a good experience in the field. and i’m not writing it to use it for a real project at least for the moment, because i’m missing many things. even the LMiC library i didn’t hear about it until now, this is why i don’t step back about asking any question no matter how stupid it looks, “well, i don’t mean stupid for real” but without the community and forums it would be much harder for anyone to develop his knowledge.
