TTGO T-Beam GPS Antenna Design Fault
That is true to an extent.
However if the TTGo is being used with one of those small rectangular ceramic patch antennas, I would suggest using a bigger antenna. When I tested those small antennas, on a properly working GPS, I could not get a fix after several minutes. The larger 25mm ceramic patch antenna, in the same location, a few minutes earlier, on the same GPS took 35 seconds to get a fix.
