TTGO T-Beam topic
kizniche / ttgo-tbeam-ttn-tracker
Hey guys. I’m a little late to the party but im having some issues with kizniche’s tracker sketch. I’ve been reading the issue requests on his Github and none of them are really helping me.
The problem I’m having is that I only get the activation message in TTN Console → data, so im wondering what’s faulty about my setup.
I’ve used the right credentials for OTAA, set up my band in mcci project config and everything else thats provided in his readme.
Also, my end node is trying to activate itself over and over again with no uplink coming through.
This is the output from my activation tab:
“time”: “2020-06-07T13:35:55.731483096Z”,
“frequency”: 868.5,
“modulation”: “LORA”,
“data_rate”: “SF8BW125”,
“coding_rate”: “4/5”,
“gateways”: [
“gtw_id”: “eui-b827ebfffe34bb20”,
“timestamp”: 3666486788,
“time”: “2020-06-07T13:35:55.711068Z”,
“channel”: 2,
“rssi”: -118,
“snr”: -3.5
“gtw_id”: “eui-b827ebfffe6b4594”,
“timestamp”: 787828300,
“time”: “2020-06-07T13:35:55.717715Z”,
“channel”: 2,
“rssi”: -114,
“snr”: 0.8
Anyone over here able to identify my problem?
I’m using the T22_v1.0 revision of the board.
