TTN Mapper: Data present but heatmap is not shown
Dont sweat it - just saying given comment above bout getting all details out!
BTW in case you hadnt seen looks like (if I have have it right) you are one of maybe 5 other public/visible Gateways in reasonable range - hope your Tx’s not saturating their GW’s/apps! :wink:
Especially as the one closest to you is a Medical Service - I hope they are not doing e.g. critical temp/cold chain monitoring of Covid Vaccines for the community! :scream_cat:
You might want to try loosing the experiment and just run as a user contributing to the MAP - if using in an exceptional way such that coverage would not be valid for other general users - e.g. sending from a HAB - then may not need experiment status. Just contribute to the coverage overall :slight_smile:
Per the documentation:
Experiment name (optional): You only need to provide an experiment name if you are testing and do not want your mapping results to contribute to the main coverage map for the network. In other words, when you are mapping normally with a device that is between 1 and 2 metre above ground level, you can leave this field blank. If you are doing anything else like launching and tracking a ballon, please provide a unique experiment name here. Adding the date to the experiment name helps to find it again later.
