Didn’t mean to, @cslorabox, sorry. I am a newbie and i didn’t understand the whole meaning of your question…
edit : thanks @descartes for the translation
They do need access. Somehow they logged in or subscribed to the data - are they using an account the vendor created after registering devices in it, or what?
There are steps someone had to do, the question is how those got done before the asker got their hands on the result, and by extension if they got done right.
The question that was ignored was “Where did the account / login you are using to access these come from?”
It was generated by the probe manufacturer shortly after we ordered them, hence the “we just turned the gateway on, shook the device to wake it up and data was forwarded for some time”.
The consequence is that there are details of the setup in TTN (not to mention the behavior of the node itself) which only the vendor really knows. And they’re not standing there helping you through the process.
Worse they’ve set you up in a version of the system scheduled to be turned off later this year, and made promises they were in no position to honor about how long something they have no role in maintaining would stay available.
You probably need to have some stern words with the vendor and get them to stand behind what they’ve offered to you, or at least make enough technical detail of it available to you that you can be self-supporting with the aid of ordinary community resources not having to guess at what your vendor was thinking.
No they don’t. They absolutely do not need to log in to setup a device or even log in to an account setup for them. I can provision a device right now and send it to someone with a gateway and pipe the uplinks to them without them having any access to the application or the device. If there is a gateway near by we can rely on, they don’t even need their own gateway.
I know this because I’ve done this a couple of times - customer needs battery level, customer gets email each morning with battery level, customer happy.
Yes, I know which one was ignored. But it doesn’t apply. The customer doesn’t get access to the application console. Period. Because as I said above, it’s all done by the manufacturer before the devices are shipped. And mostly they seem to be able to do this properly otherwise they wouldn’t really have a business.
The customer gets access to an online dashboard / portal that the manufacturer provides that gets the data from TTN, processes and presents it.
Whilst we know it would be preferable to see what’s going on at device level, that’s not the deal on offer.
If you go down that path then you are responsible for making it work, since you’ve made it impossible for the customer to help themselves, or for the community to help them.
Such a customer can gain nothing by posting here.
But this customer actually does have a login to get to a TTN console view.
@cslorabox, moving this on in a direction we have some control over, any thoughts on a low cost gateway so @codename5281 can have something else for general testing & getting to grips with LoRaWAN.
Well, we are trying to get them up to speed on the constraints of the offering they purchased and trying to get some other kit to help with trouble shooting …
Yes, but only for their TTIG.
I actually registered our TTIG in order to try to understand what was going on. This part we did on our own.
IMHO debugging best starts by understanding the design of the node, and seeing what it’s doing - debug output is both cheaper and more informative than a gateway.
Seems like the real problem is that the system falls into the gap between something designed to be maintainable, and something actively supported by the vendor so that the customer doesn’t need to bother understanding the details. This is a no-information, no-support pitfall.
One can buy an open architecture gateway like something with a proper multichannel concentrator card based on a pi (great for office based testing, not so good for field deployment) but actual problems may not be understandable or solvable without engineering-level access to the node behavior.
Most of that ain’t going to happen overnight.
But getting hold of a Pi based gateway as suggested:
RAK7246 / RAK7246G WisGate Developer D0/D0+ boasts an easy set-up, accessible internal modules, and low cost. This Raspberry Pi gateway is perfect for new and old developers alike.
Price: USD 99.00
will allow some back in the office testing with both on the gateway as well as console logs to get in to the detail of what’s happening with spontaneous re-joins.
And in parallel, liaise with Sensoterra about resolving both the immediate issue of the devices not working and the medium term issue of who holds the keys to the kingdom.
In the meanwhile, Mistress Google will penalise them because this thread will rank well and I’m not sure it will be what they want discussing in public. But that’s a problem they generated.
To be clear I personally suggested gaining an understanding of the node, rather than or before buying a gateway
It is placed 2m high in a tree, all sensors are placed at ground level.
Not a great recipe for success I’m afraid… it will work but not very efficiently and you will throw away a lot of the range and penetration benefit of LoRa in that case. Your deployment is typical of soil sensors and others where device deployment is at or close to ground level … or even below (think water meters in pits!). Ideally you should try to get the sensor ant up at >>1m and the gw much higher… early LoRa proving tests for the water industry had devices in pits - often in concrete collars and with metal lids over the top…but the GW’s were typically on top of e.g. Parisian tower blocks! If nodes are low the GW’s really need to be high to subtend a decent tx angle… you really need to read up on e.g Fresnel zone… you will probably be loosing >40% of your radiated energy…and that is before allowing for any obstructions or any ground/terrain masking as you look to scale out.
That said the TTIG is a nice low power device and if rehoused and/or adapted to implement an external antenna (helps in gaining height if run of a short length of ultra low loss cable) and partnered with a close by WiFi back haul or connected over WiFi to a low power 3G/4G dongle you have a great starting point for a solar solution, depending on tolerance for power outages, desired panel, or battery capacity, geo location (how much thermonuclear energy you can harvest!) and if full day sun or partial shadow/obscured.
Would agree with Nick that
I’d definitely think in terms of pulling the lot back to somewhere warm where you can check everything over, then find someone’s garden close to hand to try to emulate the setup.
Would be a good move until you can reliably test and easily add new devices reliably and consistently… then move to field deployments. Buy yourself a telescopic 8 or 10m or even 15m Ariel mast and put ant (& gw?) at top then tether with guy ropes to start your field test… 2m might as well be on a table top in this scenario
Also just to add my 2penneth on customer deployments, unlike typical ttn forum users and even some on this thread many are not into the details but only interested in the final solution/result and don’t give two hoots about device details, gw complexities, secret sauce or secret keys…they just want something that is easy to deploy or that can be deployed for them, powers up and works with a nice dashboard display or some graphs, perhaps with some kind of historic data storage for review and/or analysis or audit… in which case pre configuring and shipping a (set of) device(s) to connect to a network, with a (again pre configured if needed) low cost gw, possibly remotely managed, if they are not already in range of one, with the actual data - the only bit they really value or are interested in - then presented on e.g. a simple shared project Cayenne link they can open on a pc, tablet or even their phone. So can understand why some kit suppliers go that route and can see why Nick has clients in same mode, as have a few like that myself.
As for
Shame it’s an orchard. I like cider but if it was a vineyard, I’d be more than happy to assist in person.
I would happily carry his bags and besides orchard ok as though a wine fan like Nick I also appreciate cider/cidre/scrumpy… and Limoncello …so not fussy really
Hello again,
Let me try to sum everything up as i read again my emails with Sensoterra, this thread and PMs we had with @descartes. As putting pieces together helps me understand a bit more, it may be helpful for others people too.
We bought 8 Sensoterra soil moisture probes. These probes come already registered to TTN by Sensoterra so we just have to wake them up for them to start joining and sending packets through TTN to an endpoint managed by Sensoterra, that performs raw data treatment (soil-specific recalibration done on the server side), displaying of the data and API integration for delivery and subsequent use of this cleaned data. The probes are enclosed and autonomous, and come with a battery that is supposed to last at least 3 years.
This particular design implies that…
The customer doesn’t get access to the application console. Period. Because as I said above, [registering is] all done by the manufacturer before the devices are shipped. And mostly they seem to be able to do this properly otherwise they wouldn’t really have a business.
In order to provide connectivity, we bought a TTIG gateway that is powered via a solar panel setup, and a 4G dongle ensures the wifi backhaul. We tested everything beforehand in the office, and have a way to remotely monitor that everything is powered up and connected to the internet.
Now, this setup has been installed mid-march in a citrus orchard with the following layout, with the TTIG being installed in Arbre 1 at 2m high and all probes being installed at ground level. Max distance between the TTIG and the probes is ~100m. Declared signal strength in console ranges from 9+/-1 for SNR, -105+/-5 for RSSI.
When we installed the whole setup, all the probes showed up in Sensoterra’s interface, meaning that they successfully performed at least a join and an uplink. Later on, some randomly stopped sending data, while other started sending again. For info these probes have a cache of 6 measurements and each time send a packet with a “trail” of the 6 last measured values. The data is collected hourly in normal mode and once a day in stock mode. The sensors store up to the last six measured data points, so for normal mode up-to 6 hours and in stock mode up to 6 days. Chart of the points logged by Sensoterra’s server during the past 15 days below :
Just to be clear, I understand you have the TTIG on the free to use TTN v2 console and that you see traffic on the TTIG’s console?
After that, yes, we decided to have a look at the TTN monitor to try to understand what was going on. Here’s an example of what we see (html file). We registered the TTIG on TTN console and started monitoring. We noticed that we are receiving a high number of join requests, followed by join accept, without consistent up/downlinks. It is around this time that we started discussing with the Sensoterra team, posting this thread, and discussing in PM with @descartes.
That all depends Nick, these soil sensors are often set very low to the ground typically with ant <<1m above surface - well inside the Freznel interference zone, and if GW isnt mounted very high (>10m ideally >20m) then that can severely limit RF signal,
We see you use TTI with packet forwarder. We have little experience with this unfortunately. Could it be a flaw in the forwarder? Are packages “overlapping” each other? […]
Still, as mentioned in the previous mail we think it could possibly the packet forwarding in TTI and we would love to be able to take a look into it, however TTI is a private network which is beyond our control, so unfortunately we can only provide very limited support. So a solution would be to have someone take a look at it that does have knowledge of the system (and package forwarder) on your end. […]
A possible solution to exclude that the irregularities are caused by the TTI/TTN packet forwarder, would be to create an endpoint in our backend for your (private) TTI network. […]
The behaviour we see from our sensors is very strange (and rare), which is why we suspect that the packet forwarder could be the issue. We also don’t think it is caused by your RF setup. It seems like some sensors have issues with joining, which could be caused because the sensors sometimes also need to receive packets (the accepts, which are not all received in your case) from the network after sending. […]
This is why we are suggesting to create a direct connection to our backend by creating an endpoint. This would bypass the packet forwarder. The main reason for this, is that TTI is originally meant as a private LoRaWAN network. And all our sensor data needs to be decoded and calibrated on our servers, which is why this connection is very important. […]
TTI is a private version of TTN. All our probes work by default on TTN gateways. Because TTI is private, there is a workaround called the packet forwarder, which is linking private TTI data to the public TTN network. Although we thought this would work well, we now suspect it is causing issues with the up- and downlinks to our sensors, this is in line with what you see in the communication. Everything else you are describing in your field, i.e. distance to gateway, signal strength when the sensors do check in etc. looks completely normal to us, usually this would cause no issues whatsoever. Therefore we are suspecting the packet forwarder to be the issue.
The TTIG can not inspire any devices to issue join-requests
But fundamentally, the devices are doing the joins, something they should do only once in their lives as they have the batteries embedded in them. Once they have joined, they have no reason to do so again. If by design they do that, the firmware is way outside of the boundaries of normal LoRaWAN behaviour.
There is absolutely nothing that can cause a device to spontaneously decide to re-join - the classic reason is that the battery fades, regains some strength, the device reboots, sends a join request, uses all its power up with the tx so can’t stay alive long enough to hear the rx.
There may be a downlink command in their firmware that can send a reboot / rejoin request - I hope so otherwise migration to v3 will be problematic - perhaps something in their back end is sending these out. […]The bottom line is that devices join once in the life of their battery. That’s the LoRaWAN design and that’s what TheThingsIndustries ask us to do on TTN and that’s what we ask of the community because a gateway can’t hear uplinks when it is transmitting as well as issues with running out of Join Nonces (unique random keys) if a device tries to join too often.[…]
I know I keep saying this, but unless they are being remotely commanded or they have overly sensitive “loss of connection” firmware, either of which Sensoterra can explain, devices do not suddenly decide to re-join each morning. I have devices on batteries for over 2+ years that have joined once. […]
Devices should only join once. They can rejoin if they have their batteries changed or they are remotely commanded to. They should NOT re-join spontaneously.
The decision to give up and do another join request is one made entirely by the node - LoRaWan has no concept of an explicit negative ack, it can only refuse to ack. So it’s up to a node to decide what to do when it doesn’t hear anything. Even if a connected node has a “disconnect and start over” command that’s really just a suggestion that it’s up to the node to actual accomplish.
After phone discussion with Sensoterra we had confirmation that the sensors perform a new join request every 24h when they are not able to reach the gateway after 6 to 8 tries.
The TTIG is pretty straightforward - you have no control over it really so it’s not like you could have messed with its settings.
- The gateway Sowit is using is not a TTN gateway, but a TTN compatible gateway. Similar to a The Things Industries gateway, it is using the packet forwarder to connect to TTN:
- We know from documentation that for the way how our sensors work (more interaction with our own backend then other, more simple sensors), the packet forwarder can be a problem.
- Development and support of the packet forwarder has been put on hold. Please read the following information on Github: GitHub - TheThingsNetwork/packet_forwarder: Packet forwarder for Linux based gateways. If you Google on it, you find many people who are not receiving packets, using this forwarder.
To which @descartes took again some time to explain to me in PM :
the gateway has nothing to do with any of this. It’s about the devices spontaneously re-joining, failing to do that completely and you get a blizzard of ‘wake-ups’ each day. […]
If there was anything likely to work well with the TTN network, it’s their own TTIG […]
As pretty much all of LoRaWAN is specified in considerable detail, if a device & gateway is compliant, uplinks will be received and passed on to a the Gateway / Network Server which has a defacto standard by virtue of the original UDP code that Semtech created. I think most of the gateways I’ve used or recommended use this.
The TTIG uses BasicStation, an updated protocol. The only reason for ticking “I’m using the legacy Semtech forwarder” on the console when setting it up is because it is identified by its EUI. There is an interface between BasicStation devices and the main v2 Network Server. […]
The gateway hears the start of a transmission (called the preamble, the LoRa wake up call), between the closed black box receiver chip (again, one supplier, Semtech) and the well understood & quite simple gateway software arrange to listen to the incoming packet on one of the channels. This is checked for completeness using a simple mathematical algorithm (CRC) and then forward on “as-is” to the Network Server via some sort of network interface - in many cases UDP but for the TTIG, WebSockets, a much more reliable protocol. The Network Server looks up info & decrypts and passes on the cryptographically checked (ie, much better than simple CRC) uplink on to the Application Server.
So I fail to see how the packet forwarder can be an issue with their back end. At the time it is in the gateway it is just an encrypted sequence of bytes. If the packet forwarder changes anything, the decryption will break.
There are known ‘timing’ issues with the TTIG, because this Gateway frequently disconnects from the TTN servers to save resources. Some users report that the TTIG is not buffering uplinks, which means if one is missed, it won’t resend it. These reports are in line with the strange behavior we see. We don’t have anything against TTIG, we only try to apply deductive logic to the information we find. Our sensors are more sensitive to timing than other sensors, because they have a tighter integration with the backend then other sensors (I was not sure if @descartes has any hands-on experience with our sensors). Again, we only try to exclude causes.
To which @descartes added :
This is true but it is quite rare that the TTIG drops the uplink that prompts it to reconnect
[However] a device in the field uplinks - if it’s a compliant device it will have been told by the network what the appropriate rate to use, so the timing of the rate of transmission is variable (speed of light remains the same thou). The gateway could be on a 2G as long as latency isn’t too high, so it could travel up to the internet over GSM at ~40Kb/s.
As mine is still in 2.0.0, i also went to check if these kind of issues were solvable with the last TTIG firmware, but according to the community the issues we’re facing do not seem to be fixable by that.
In any case, we ended up ordering a RAK gateway in order to do some troubleshooting ; thing is with the new french lockdown time will fly until the day we get it and bring it to the orchard !..
Realistically, while your vendor is right about TTIG issues, if they don’t give you technical details of their devices behavior, it’s on them to solve this.
They can’t expect the community to debug proprietary products.
My firm rule is not to by things which are not user serviceable - that rules out both your node vendor, and also the closed TTIG.
Just a couple of quick comments on this - appreciate the write up and fact you have reported back
re #6 - Yes deploy a Canary node - always good to have another device of a type that is not being used as part of a sensor ‘monoculture’ - even if just a simple T&H monitor - will have addded value of reporting ambiant conditions and warn of e.g. frost that might affect yields. Set it up at ~same 2m height as GW - perhaps in one of the trees with LOS to GW placed min 25/30m away, better yet 50-250m away - set for low power and short SF (7) so that on air time is minimal (enable ADR?) on a 5-10 min reporting cycle - this will help keep Websockets connnection responsive and remove Sensoterra excuses If you dont want to build something yourself simply grab a Laird RS186 or Dragino LHT65 - will do a fine job with longish battery life and reliable operation. As noted this will keep the Websockets connection operational and responsive.
There were early TTIG problems - widely reported and commented on on the forum and whilst Sensoterra are right to call these out the fact is with improvements to back end and improvements to TTIG f/w this is generally no longer an issue - as they should know - and its a bit naughty of them to try and point finger that way.
Your RAK GW should also work fine in this type of deployment and will help provide redundancy and extra coverage if deployed as an additional item vs replacement.
Re
That is indeed self evident in what you are seeing. You hadnt mentioned max 100m range earlier - that should be fine but you ARE wasting LoRa benefits as shown by your signal data:
This is the kind of RSSI/SNR typically seen from nodes several km away not <100m! Your close range tests are running fine but what happens when you scale out to the next field/orchard say 300m away or down the valley say 1.5-2km away?! Your solution (specifically the lack of height for GW) will not scale and as I noted is very inefficient wrt LoRa usage. At the moment I would expect to see RSSI’s from aro -65dbm to -85dbm for current config and remember 6db represents approx doubling of range that can be achieved - it is in the nature of the devices that they have to be in/close to ground - that cant be helped but you can help yourself by getting the GW higher to minimise/mitigate the Fresnel effects. Please try when free from lockdown
4G ‘should be ok’ for backhaul unless your network is way out on a limb and hopping through many repeaters or long fibre or dsl back hauls to RAN and Cellco central office.
Re Sensoterra timing and tight coupling to their own back end - sounds like marginal LoRaWAN performance - are they LA certified devices? (I havent checked), if so that should be no excuse - and may be its part of a vendor lock in strategy - even if inadvertent! Which is a pity as like the look of their units and was impressed when I saw them launched - was thinking of getting a few to evaluate for possible client deployments but your story puts me off somewhat (not good PR for them )
If anyone from Sensoterra is reading this perhaps they want to throw a couple of units to Nick (@descartes ) and myself to abuse and destroy - sorry I mean to test and evaluate, potentially against a range of GW’s and backhaul solutions - so we are in a better position to judge and advise!..
The console log is very useful. A quick scan of it reveals a number of issues. Can someone transcribe it with columns of:
Time, Msg Type, DevAddr, DevEUI, SF
Where Type = JR, JA, Up, Dn
so we can dig in to the detail. Some sensors happily make it in to double figures for uplinks. The first entry (at the bottom) indicates one is far too close to the TTIG and is overloading the TTIGs RF input stage, that’s a newbie error, but irrelevant, it joins eventually, question is, does it re-join at a later point.
Shame we don’t know what each sensors DevEUI is so we can place it on the map.
Question to this is how do the sensors decide that they are not able to reach the gateway - do they send confirmed uplinks (so the Network Server commands the gateway to transmit an Ack) or do they rely on a downlink from the Sensoterra back end to confirm that data is flowing.
This is going on the opposite direction from @Jeff-UK’s posts :
Jeff Mckeown was around at the time they launched LoRa. He’s deployed dozens of community gateways around the UK. If anyone was going to know about gateway’s, it’s Jeff. Or Jac Kersing. Or LoRaTracker. All do RF & antennas, me, not so much, I’m more firmware, devices and business intelligence (data processing).
This was a total red herring - it actually says in the link it’s not used by TTI, it was created for other gateways that want to connect to TTN. And the TTIG uses BasicStation. This sort of commentary from Sensoterra is just fishing for a reason.
Having seen some gateway logs, I wonder why the Sensoterra back end is not going berserk with alerts about all the re-joins - I assume you don’t get any emails saying your deployed sensors aren’t happy??
Is there anyway of getting hold of one - anyone out in Morocco that can pull one out the ground and send it north? Positioning the sensor & a TTIG for experimentation would be good.
Do you have pictures of the TTIG in it’s weather proof box - how the antenna was extended out of it would be useful knowledge to help with elimination of any other spurious objections from Sensoterra.
Just took a quick scrolling look through the console data you shared (havent done any detailed analysis) but from what I see I note a lot of uplinks are SF9-SF12 (ignoring the Join reqs gradually ramping up in SF when unsucessful?), where for this range I would expect to see neary all SF7 or SF8. Also many (most?) uplinks are quickly followed by a downlink suggesting the packets are being sent ‘confirmed’? Not a good practice and generally frowned upon as a) as you burn through GW dutycycle limts - again reducing ability to scale, b) potentially will breach TTN FUP very quickly (Max 10 downlinks per day inc join process and acks!), c) when txing a downlink (or repeated join accepts for that matter if node doesnt catch and action forcing repeats) the GW is unable to listen for uplinks - it goes deaf! …and that might result in gaps in Rx data…just saying
As Nick asks please log more & bin the data and if/when I get 5 I may have a browse through…
@Jeff-UK, Sensoterra have closed firmware that the management do not appear to be able to describe the general scheme of operation and the sensors are registered on a private TTI instance that the customers don’t have access to - all they see is what appears on the Sensoterra dashboard. There is no evidence there is a device management system in place, otherwise the re-joins would have been identified by them long before the user did.
So whilst the observations are correct, this is all down to Sensoterra.
Yes sir, just finished it.
I’ll answer to the other messages in the morning tomorrow ! Sleep tight.
