Well, we are trying to get them up to speed on the constraints of the offering they purchased and trying to get some other kit to help with trouble shooting ā¦
Yes, but only for their TTIG.
I actually registered our TTIG in order to try to understand what was going on. This part we did on our own.
IMHO debugging best starts by understanding the design of the node, and seeing what itās doing - debug output is both cheaper and more informative than a gateway.
Seems like the real problem is that the system falls into the gap between something designed to be maintainable, and something actively supported by the vendor so that the customer doesnāt need to bother understanding the details. This is a no-information, no-support pitfall.
One can buy an open architecture gateway like something with a proper multichannel concentrator card based on a pi (great for office based testing, not so good for field deployment) but actual problems may not be understandable or solvable without engineering-level access to the node behavior.
Most of that aināt going to happen overnight.
But getting hold of a Pi based gateway as suggested:
will allow some back in the office testing with both on the gateway as well as console logs to get in to the detail of whatās happening with spontaneous re-joins.
And in parallel, liaise with Sensoterra about resolving both the immediate issue of the devices not working and the medium term issue of who holds the keys to the kingdom.
In the meanwhile, Mistress Google will penalise them because this thread will rank well and Iām not sure it will be what they want discussing in public. But thatās a problem they generated.
To be clear I personally suggested gaining an understanding of the node, rather than or before buying a gateway
Not a great recipe for success Iām afraidā¦ it will work but not very efficiently and you will throw away a lot of the range and penetration benefit of LoRa in that case. Your deployment is typical of soil sensors and others where device deployment is at or close to ground level ā¦ or even below (think water meters in pits!). Ideally you should try to get the sensor ant up at >>1m and the gw much higherā¦ early LoRa proving tests for the water industry had devices in pits - often in concrete collars and with metal lids over the topā¦but the GWās were typically on top of e.g. Parisian tower blocks! If nodes are low the GWās really need to be high to subtend a decent tx angleā¦ you really need to read up on e.g Fresnel zoneā¦ you will probably be loosing >40% of your radiated energyā¦and that is before allowing for any obstructions or any ground/terrain masking as you look to scale out.
That said the TTIG is a nice low power device and if rehoused and/or adapted to implement an external antenna (helps in gaining height if run of a short length of ultra low loss cable) and partnered with a close by WiFi back haul or connected over WiFi to a low power 3G/4G dongle you have a great starting point for a solar solution, depending on tolerance for power outages, desired panel, or battery capacity, geo location (how much thermonuclear energy you can harvest!) and if full day sun or partial shadow/obscured.
Would agree with Nick that
Would be a good move until you can reliably test and easily add new devices reliably and consistentlyā¦ then move to field deployments. Buy yourself a telescopic 8 or 10m or even 15m Ariel mast and put ant (& gw?) at top then tether with guy ropes to start your field testā¦ 2m might as well be on a table top in this scenario
Also just to add my 2penneth on customer deployments, unlike typical ttn forum users and even some on this thread many are not into the details but only interested in the final solution/result and donāt give two hoots about device details, gw complexities, secret sauce or secret keysā¦they just want something that is easy to deploy or that can be deployed for them, powers up and works with a nice dashboard display or some graphs, perhaps with some kind of historic data storage for review and/or analysis or auditā¦ in which case pre configuring and shipping a (set of) device(s) to connect to a network, with a (again pre configured if needed) low cost gw, possibly remotely managed, if they are not already in range of one, with the actual data - the only bit they really value or are interested in - then presented on e.g. a simple shared project Cayenne link they can open on a pc, tablet or even their phone. So can understand why some kit suppliers go that route and can see why Nick has clients in same mode, as have a few like that myself.
As for
I would happily carry his bags and besides orchard ok as though a wine fan like Nick I also appreciate cider/cidre/scrumpyā¦ and Limoncello ā¦so not fussy really
Hello again,
Let me try to sum everything up as i read again my emails with Sensoterra, this thread and PMs we had with @descartes. As putting pieces together helps me understand a bit more, it may be helpful for others people too.
We bought 8 Sensoterra soil moisture probes. These probes come already registered to TTN by Sensoterra so we just have to wake them up for them to start joining and sending packets through TTN to an endpoint managed by Sensoterra, that performs raw data treatment (soil-specific recalibration done on the server side), displaying of the data and API integration for delivery and subsequent use of this cleaned data. The probes are enclosed and autonomous, and come with a battery that is supposed to last at least 3 years.
This particular design implies thatā¦
In order to provide connectivity, we bought a TTIG gateway that is powered via a solar panel setup, and a 4G dongle ensures the wifi backhaul. We tested everything beforehand in the office, and have a way to remotely monitor that everything is powered up and connected to the internet.
Now, this setup has been installed mid-march in a citrus orchard with the following layout, with the TTIG being installed in Arbre 1 at 2m high and all probes being installed at ground level. Max distance between the TTIG and the probes is ~100m. Declared signal strength in console ranges from 9+/-1 for SNR, -105+/-5 for RSSI.
When we installed the whole setup, all the probes showed up in Sensoterraās interface, meaning that they successfully performed at least a join and an uplink. Later on, some randomly stopped sending data, while other started sending again. For info these probes have a cache of 6 measurements and each time send a packet with a ātrailā of the 6 last measured values. The data is collected hourly in normal mode and once a day in stock mode. The sensors store up to the last six measured data points, so for normal mode up-to 6 hours and in stock mode up to 6 days. Chart of the points logged by Sensoterraās server during the past 15 days below :
Just to be clear, I understand you have the TTIG on the free to use TTN v2 console and that you see traffic on the TTIGās console?
After that, yes, we decided to have a look at the TTN monitor to try to understand what was going on. Hereās an example of what we see (html file). We registered the TTIG on TTN console and started monitoring. We noticed that we are receiving a high number of join requests, followed by join accept, without consistent up/downlinks. It is around this time that we started discussing with the Sensoterra team, posting this thread, and discussing in PM with @descartes.
After phone discussion with Sensoterra we had confirmation that the sensors perform a new join request every 24h when they are not able to reach the gateway after 6 to 8 tries.
To which @descartes took again some time to explain to me in PM :
To which @descartes added :
As mine is still in 2.0.0, i also went to check if these kind of issues were solvable with the last TTIG firmware, but according to the community the issues weāre facing do not seem to be fixable by that.
In any case, we ended up ordering a RAK gateway in order to do some troubleshooting ; thing is with the new french lockdown time will fly until the day we get it and bring it to the orchard !..
Realistically, while your vendor is right about TTIG issues, if they donāt give you technical details of their devices behavior, itās on them to solve this.
They canāt expect the community to debug proprietary products.
My firm rule is not to by things which are not user serviceable - that rules out both your node vendor, and also the closed TTIG.
Just a couple of quick comments on this - appreciate the write up and fact you have reported back
re #6 - Yes deploy a Canary node - always good to have another device of a type that is not being used as part of a sensor āmonocultureā - even if just a simple T&H monitor - will have addded value of reporting ambiant conditions and warn of e.g. frost that might affect yields. Set it up at ~same 2m height as GW - perhaps in one of the trees with LOS to GW placed min 25/30m away, better yet 50-250m away - set for low power and short SF (7) so that on air time is minimal (enable ADR?) on a 5-10 min reporting cycle - this will help keep Websockets connnection responsive and remove Sensoterra excuses If you dont want to build something yourself simply grab a Laird RS186 or Dragino LHT65 - will do a fine job with longish battery life and reliable operation. As noted this will keep the Websockets connection operational and responsive.
There were early TTIG problems - widely reported and commented on on the forum and whilst Sensoterra are right to call these out the fact is with improvements to back end and improvements to TTIG f/w this is generally no longer an issue - as they should know - and its a bit naughty of them to try and point finger that way.
Your RAK GW should also work fine in this type of deployment and will help provide redundancy and extra coverage if deployed as an additional item vs replacement.
Re
That is indeed self evident in what you are seeing. You hadnt mentioned max 100m range earlier - that should be fine but you ARE wasting LoRa benefits as shown by your signal data:
This is the kind of RSSI/SNR typically seen from nodes several km away not <100m! Your close range tests are running fine but what happens when you scale out to the next field/orchard say 300m away or down the valley say 1.5-2km away?! Your solution (specifically the lack of height for GW) will not scale and as I noted is very inefficient wrt LoRa usage. At the moment I would expect to see RSSIās from aro -65dbm to -85dbm for current config and remember 6db represents approx doubling of range that can be achieved - it is in the nature of the devices that they have to be in/close to ground - that cant be helped but you can help yourself by getting the GW higher to minimise/mitigate the Fresnel effects. Please try when free from lockdown
4G āshould be okā for backhaul unless your network is way out on a limb and hopping through many repeaters or long fibre or dsl back hauls to RAN and Cellco central office.
Re Sensoterra timing and tight coupling to their own back end - sounds like marginal LoRaWAN performance - are they LA certified devices? (I havent checked), if so that should be no excuse - and may be its part of a vendor lock in strategy - even if inadvertent! Which is a pity as like the look of their units and was impressed when I saw them launched - was thinking of getting a few to evaluate for possible client deployments but your story puts me off somewhat (not good PR for them )
If anyone from Sensoterra is reading this perhaps they want to throw a couple of units to Nick (@descartes ) and myself to abuse and destroy - sorry I mean to test and evaluate, potentially against a range of GWās and backhaul solutions - so we are in a better position to judge and advise!..
The console log is very useful. A quick scan of it reveals a number of issues. Can someone transcribe it with columns of:
Time, Msg Type, DevAddr, DevEUI, SF
Where Type = JR, JA, Up, Dn
so we can dig in to the detail. Some sensors happily make it in to double figures for uplinks. The first entry (at the bottom) indicates one is far too close to the TTIG and is overloading the TTIGs RF input stage, thatās a newbie error, but irrelevant, it joins eventually, question is, does it re-join at a later point.
Shame we donāt know what each sensors DevEUI is so we can place it on the map.
Question to this is how do the sensors decide that they are not able to reach the gateway - do they send confirmed uplinks (so the Network Server commands the gateway to transmit an Ack) or do they rely on a downlink from the Sensoterra back end to confirm that data is flowing.
Jeff Mckeown was around at the time they launched LoRa. Heās deployed dozens of community gateways around the UK. If anyone was going to know about gatewayās, itās Jeff. Or Jac Kersing. Or LoRaTracker. All do RF & antennas, me, not so much, Iām more firmware, devices and business intelligence (data processing).
This was a total red herring - it actually says in the link itās not used by TTI, it was created for other gateways that want to connect to TTN. And the TTIG uses BasicStation. This sort of commentary from Sensoterra is just fishing for a reason.
Having seen some gateway logs, I wonder why the Sensoterra back end is not going berserk with alerts about all the re-joins - I assume you donāt get any emails saying your deployed sensors arenāt happy??
Is there anyway of getting hold of one - anyone out in Morocco that can pull one out the ground and send it north? Positioning the sensor & a TTIG for experimentation would be good.
Do you have pictures of the TTIG in itās weather proof box - how the antenna was extended out of it would be useful knowledge to help with elimination of any other spurious objections from Sensoterra.
Just took a quick scrolling look through the console data you shared (havent done any detailed analysis) but from what I see I note a lot of uplinks are SF9-SF12 (ignoring the Join reqs gradually ramping up in SF when unsucessful?), where for this range I would expect to see neary all SF7 or SF8. Also many (most?) uplinks are quickly followed by a downlink suggesting the packets are being sent āconfirmedā? Not a good practice and generally frowned upon as a) as you burn through GW dutycycle limts - again reducing ability to scale, b) potentially will breach TTN FUP very quickly (Max 10 downlinks per day inc join process and acks!), c) when txing a downlink (or repeated join accepts for that matter if node doesnt catch and action forcing repeats) the GW is unable to listen for uplinks - it goes deaf! ā¦and that might result in gaps in Rx dataā¦just saying
As Nick asks please log more & bin the data and if/when I get 5 I may have a browse throughā¦
@Jeff-UK, Sensoterra have closed firmware that the management do not appear to be able to describe the general scheme of operation and the sensors are registered on a private TTI instance that the customers donāt have access to - all they see is what appears on the Sensoterra dashboard. There is no evidence there is a device management system in place, otherwise the re-joins would have been identified by them long before the user did.
So whilst the observations are correct, this is all down to Sensoterra.
Yes sir, just finished it.
Iāll answer to the other messages in the morning tomorrow ! Sleep tight.
Ok will do. We may even try the Dragino LSE01 soil moisture sensor for a change.
Our locations are pretty remote ; is there a way to check what might be the impact of the backhaul ?
At least they say so on the last version of the technical data sheet, however i cannot find any trace of them on the LoRa Alliance certified products showcase page. Also, i just noticed on the last TDS the āGEN2ā label, weāll have to check which one Sensoterra provided as this is not specified in our invoice, and also what are the main differences between the two generations.
We donāt have an explicit info about that, Sensoterraās using an intermediate in-house serial number in between both in their monitoring interface and raw measurement files.
Not much useful on the probes either, the QR code is S/N as well.
I am not in place of putting @Jeff-UK knowledge and experience into question, i was just pointing out these contradictions
Nope, we hear nothing from them.
Well, itās gotten a bit difficult nowā¦
The antenna extension was very similar to what has been done by Tnkerman and Disk91, i.e. disconnecting the PCB antenna and connecting a 868 MHz-tuned one via a 5cm UFL to SMA cable.
ā¦but this makes sense mainly in the case where all probes send data at the exact same time, right ?
Well, the discussions have been mostly handled by the commercial director, but i can try to be in touch and send specific questions to the proper tech guys.
Thatās what the canary will help do for us - if it uplinks every 10 minutes you get to see if there are any gaps in the connectivity.
In this situation, with a 2 byte payload and bypassing ADR to keep it at DR5 and go for 2.5 minutes to get the best resolution possible. It can be remote commanded to return to a less pro-active rate.
The log (thanks for that) shows up some points:
The sensor is using a Multitech DevEUI - which is good as it means we can be reasonably sure the actual LoRaWAN stack isnāt borked, just something about the firmware.
I think DevEUI ā00 80 00 00 04 01 3A 0Fā and ā00 80 00 00 04 00 9F B8ā may be a little too close to the gateway as it looks to me that they are overloading the input and the gateway thinks itās heard a JR on several channels when it was just one.
DevAddr ā26 01 22 11ā is clearly getting on with things but there are gaps in itās uplinks and its count is only on 15.
Itās pretty clear that an uplink frequently gets a downlink. This may be MAC requests from the network but as uplink 15 gets downlink 6, either the node isnāt doing whatās being asked of it (unlikely) or they do get a response more often than what could be considered ānormalā
The pattern of uplinks isnāt very discernible so itās not sure if the ā26 01 22 11ā is working as expected or if something is happening on site that means connectivity to the backend isnāt available (bring in the canary).
I suspect the only way to match DevEUI to a serial number to a location is by the usual āturn them all off, turn one back on at a timeā method. I realise this canāt be done at present.
Re @Jeff-UK, I know you werenāt querying his credentials, thatās my job - it was more an observation that there are others here that are the subject matter experts on gateways, antennas and RF in general. Iāll leave others to comment on the position of the gateway, but I suspect Sensoterra (hi to you guys if you are reading along) will query itās deployment. Personally, Iām a great fan of DuckTape but ideally have it on a standalone pole. Iāve not been in a position to try to cook a gateway as I live in the north of England and Westminster hasnāt authorised the use of sunshine up here, but I will add it to the summer projects.
Yes & No - with all those repeated JRs with corresponding JAs we wonāt know if there was other traffic going on but it would be a huge co-incidence for such a small number of sensors to overlap. We do get lots of people trying to use downlinks as a matter of course in their firmware (potentially like this sensor) and then the problem escalates. Five sensors with a downlink once every three hours is one thing. But then you get 100 sensors deployed ā¦ And as the some developers command JRās without any backoff (delay), you can end up with a cascading effect. So we tend to mention the whole āgateway is deafā during a downlink as it comes up often enough - a sensor should be able to cope most of the time without any downlinks. For this sort of sensor, as itās not tracking nuclear assets or my wallet, Iād leave it to uplink and employ my usual schemes for checking connectivity. If I miss a few uplinks I could extrapolate what the readings might be. If I really really need a data point to fill in and Iād allowed for it in firmware, I could send a request for a resend of one or more readings, or an average for some time ranges or similar.
As the TTIG gateway is not the only device enjoying some wifi backhaul, we have a way to check for big gaps in 4G connectivity with other sensors that ping every 30 minutes - as they successfully do so most of the time despite not having a light payload, we know there is no major trouble in sending the data.
This picture purpose was illustrative, as the box is in practice positioned at ~2m as previously stated. Still, yes, there is duck tape (as well as polystyrene foam-based insulation attempt) involved in the baking !
Hello ! A quick update on this topic. I donāt know if anything has changed on TTN or Sensoterra side, but itās now been three days since our whole setup is working without any issue, i.e. all probes are reporting as they should, and no join requests/accepts, unly uplinks/downlinks in the console during the last 24 hours.
Thatās funny because today was the day where we had planned to setup the RAK gateway on the field
Edit : i wonder if this can somehow be related to an OTA firmware update of the TTIG, but i wasnāt able to probe the TTN noc server to check the firmware version
Good to hear they are working - have Sensoterra communicated a plan for the transition from v2 to v3?
So far, we didnāt hear from them, no. Weāre going to reach them and ask, in the meantime do you know if there has been any major changes on TTN side that could explain this sudden change ?
No, but my recently acquired one is working fine, which is sort of good and sort of frustrating. I am going to park a metal box on top of it to take it off line to see what it does when it can be heard again.
