i get it, but promising the customer with 0.4uA and i get that 0.4uA in real practice or even close to it, won’t be a big problem as long as the battery life will be the limit, but as other board (like TTGO) saying 0.2uA in deep sleep while some people hardly get close value to that, (i’m sorry, i forget the exact value), i think it’s a problem, i hope i’m wrong in this one because i do like TTGO board but i don’t trust their specification, and you can’t just buy and test all boards to chose the right one,(wish i can do that XD ).
Which TTGO board claims a deepsleep of 0.2uA or less ?
T-Beam and lora32 oled
Ah, using the power management to power everything off.
Having to restart from afresh everytime wastes a lot of battery power, especially with an ESP32.
A setup which allows the processor to resume from the point at which it was put to sleep will normally be more power efficient since this avoids all the startup and initialisation processes.
but, does it really reach the 0.2uA??
No idea. Don’t have one of those boards.
may i ask you the board you are using?
I build my own bares bones boards, ATmega328 or ATmega1284 mostly.
I have been using Heltec boards (V2) for several tests; 1 channel LoRa gateway, LoRa FM band inspector (in combination with a $3FM receiver).
Even without extra antenna or other options, managed to access a gateway at some 3 km distance.
Pricewise it was appealing for me, then. Noticed prices tripled since then…
nice, and what about the lora chip, which one did you use?
i watched Andreas Spiess video comparing TTGO with Heltec, and the results wasn’t quite good for heltec, poor antenna. but in general it’s a decent board.
did you have a look at the new heltec board “cube cell”, it uses SX1262.
I have a question. does all end node support any LoRaWAN class (A, B or C), i didn’t thought about this before because i thought and still think it’s a software side. i mean i know what are they but some Boards specification keep saying (support class A, class A stack included etc) what do they mean??
Without any context and figures that is a nonsense statement.
That is a general statement which does not hold.
Be specific.
What MCU, board models and which versions?
What antenna, LoRaWAN, WiFi, both?
Also the LoRaWAN antenna’s for these boards are all external, connected either via UFL/IPEX or SMA connector.
Some additional information for ESP32 boards can be found here:
Is there a ESP32 LoRaWAN board for battery operation?
heltec V1 and it uses the UFL antenna for LoRa, if someone want to use that board it’s better to change to SMA antenna or buy another UFA antenna, (better one)
If you are not sure about which board then better not post statements about it because they may very well be incorrect.
What antenna are you talking about. An external antenna provided with the board?
What type of antenna? Coil antenna with UFL connector only or antenna with SMA connector connected via UFL to SMA cable? 868MHz?
To all responders in this thread:
- Please be specific and complete.
- Specify at least manufacturer board model and version.
- Don’t generalize based on experience with only one or two boards.
- Don’t compare apples with oranges.
i just edit the post and this is the link where i have found the information: https://www.youtube.com/watch?v=CJNq2I_PDHQ
and i do appreciate if you could correct my information and my statements since i’m still trying to discover LoRa boards/modules and things get a little bit confusing in my head right now. and every thing become questionable.
