404 Error on The Things Stack Console on Ubuntu Server in Proxmox
I’m facing an issue while running The Things Stack in my environment. Here’s what has been done and configured so far:
  • Environment:
    • Virtual Ubuntu Server hosted on Proxmox.
    • Public IP configured and the domain pointing correctly to this IP. The domain resolves without issues.
    • All necessary ports for the Network Server are open, according to the official documentation (HTTP, HTTPS, MQTT, MQTT-TLS, gRPC, UDP for LoRaWAN, etc.).
  • Docker Configuration:
    • The docker-compose.yml is set up correctly with PostgreSQL, Redis, and the Stack container.
    • Environment variables and volume paths are correctly configured, including directories for blobs and configuration files.
    • All required keys for cookies, cluster, gateway token, etc. have been generated and are functional.
  • The Things Stack Configuration (ttn-lw-stack-docker.yml):
    • The domain tts.XXX.puc-rio.br is configured in all relevant sections: Console, Identity Server, Network Server, Application Server, and Join Server.
    • TLS configuration: initially using Let’s Encrypt (ACME), with the directory /var/lib/acme correctly mounted in Docker.
    • Alternatives for TLS considered: disabled (source: none) for testing, or using custom certificates.
  • Observed Issue:
    • When starting the stack, all services initialize correctly and the logs show no critical errors (Redis, PostgreSQL, Identity Server, Network Server, Application Server, Join Server, Console, Gateway Configuration Server).
    • However, when accessing the Console via browser, registering a user and logging in results in a 404 - Page Not Found.
    • Attempts to adjust TLS (ACME or custom certificates) did not solve the issue.
  • Additional Details:
    • gRPC attempts to start with TLS, but fails if certificates are missing (open cert.pem: no such file or directory).
    • Testing with TLS disabled allows the stack to start, but the Console still returns a 404 error.
    • Docker Compose shows no critical errors and the containers remain running.
Question for the community:
Has anyone experienced a similar situation where the The Things Stack Console returns a 404 even with domain, ports, and TLS configured correctly? What would be the next steps to diagnose or fix this issue?
Thank you in advance
Hey everyone, good afternoon! It was my mistake; I missed the last step. I managed to deploy the platform.
It would help if you said exactly which last step so it’s clear to anyone finding this thread via Google.
