I’m using the followind uplink decoder:
But I got this error when trying to decode a payload:
How can atob be called in V3 or which alternatives do you recommend?
Thanks a lot!
Thanks a lot!
Apart from the fact that there is no window as the JS doesn’t run in a browser, the input is an object and the input.bytes is a binary array - ie it’s already decoded for you.
Please read: Javascript | The Things Stack for LoRaWAN
Also, your code implies you are sending strings of numbers - please don’t, it is highly inefficient, please read: https://www.thethingsnetwork.org/docs/devices/bytes/
EDIT: Actually, for atob, that implies you think you have a binary array that you want to turn in to Base64. So I suspect you are doing something beyond my understanding.
