Hoping to receive help in this issue. Have checked the forum for similar posts but they all refered to integration bugs (which this also could be i suppose) but I tried all the suggested solutions but nothing works.
Tried rebooting elastic beanstalk
Tried updating cloudformation stack (already was latest version)
Checked logs and we are not getting any errors
The integration gives GREEN light when you check it
The stacks and servers are OK
The thingsstack server is running fine. We can send mqtt to separate DB but AWS IOT don’t want to receive any data from Thingstack. Won’t add any things. Won’t allow subscription.
And we get no errors.
Don’t really know how to proceed with my troubleshooting. If anyone could help that would be very kind.
We started debugging AWS IOT with the tools from AWS and it seems that Thingstack is not communicating with AWS at all. Which is very confusing since the integration is not reporting any crazy errors. @johan is there some known bug with the integration that can cause this?
