https://www.genericnode.com has all the answers
Thank you but I don’t see anything. Only links to 45 minute videos.
I can’t see links to 45 minute videos - I can see a 3:34 minute video and links to the docs.
Can you please share?
https://www.genericnode.com/docs/
To
https://www.genericnode.com/docs/getting-started/
To
https://www.genericnode.com/docs/getting-started/se-hands-on-guide/
To
Long videos.
I am sorry, I have been looking for how to register the node using the links and the QR code and can not find the information.
I followed the Sensor Edition Software Setup to get the device running.
It is early days for the documentation as the firmware is developed, I’ve not seen a “Out the box” setup guide, only the programming guide - which gives much of the information for setup with keys etc.
Just try the included examples.
LoRaWAN keys (for relevant examples) are placed in conf/app_conf.h (currently only for OTAA).
I also got it up and running with the ST-link V2 and the LoRawan example, I see the messages in the console, anyone has a decoder / payload formatter at hand for the example? otherwise I will have to go thru the code
If you mean the Basic_LoRaWAN (basic_lorawan) code, you should see some real magic in the device console that is instantly decodable without JavaScript because as far as I know, it just sends AA BB CC:
I actually get this payload 4077580B26800C010290A70921631BF0
I think i should use the freefall, but seems it only has temperature and battery level, no example with all sensors?
Which app did you compile for?
Because …
It occurs to me that you are probably seeing the out-the-box demo payload. The free-fall source only sends a count of free-falls, just one unsigned byte. The README.md in the Software folder only talks about dummy payloads.
I don’t think the source for the startup app has been released …
@elsalahy & @cndrxn, could you put the demo app on GitHub please
Thx Nick, @elsalahy your video is awesome! I am still struggling with getting all sensor data and sending it, so would really appreciate some demo on that.
Can you answer my questions, it’s the only thing that motivates me to answer further questions …
Hi Nick, i typed it and delete it yesterday to avoid being the nagging noob
so the payload 4077580B26800C010290A70921631BF0 (and 60% changes) is from the basic_lorawan, i am not able to understand where it comes from yet. I did flash/upload using the cube/stlinkv2 and I flashed the basic with LED and it worked. (I can confirm that it was flashed)
I wanted to use the freefall because it gives an example of reading sensor and sending it… and i think i understand it.
Neither am I, I’d best go and find a debugger and step my way through the code.
If asked a question a reply is sort of polite and expected, it’s more the reverse, if you’re being hassled with questions, just say so.
This is new product so we all have things to learn about it!
That is the raw packet as forwarded by the gateway. You need to look at “Uplink Data Message” for the data in the packet. (And that is 0xAA 0xBB 0xCC in my tests)
Thx Jac, you are right, that was “raw message”
I had to activate the javascript formatter first
and then the message was shown
Thx!
now I need to play around with the sensors
There isn’t a JS formatter in the device repository so unless you entered a formatter that would have no effect. All’s that happened here is you’ve looked on the application / device console where the payload is decoded for you.
Have you used the v2 stack much?
Hi Nick, I see, you are right. I am quite familiar with V2, mixed the “payload” and “Raw payload” in V3.
