Browan Object Locator
Hello everybody,
I bought the Browan Object Locator and connected it to TTN.
I followed the manual from the manufacturer’s site:
https://www.browan.com/download/DBk/stream
Compared to other versions of the manual found online of the same device, I cannot find the configurability section via Downlink command, I would like to set periodic sending of the position every hour and not every time there is a movement of the object locator. Has anyone had the same problem?
Greetings,
Did you check Downlink issue and TABS nodes from Tracknet (now Semtech) ?
