If I have only one device in my device_file, it works, and return json config structure.
However, if device_file has a carriage return at the end of the first line, it throws next error: json: cannot unmarshal number into Go value of type map[string]interface {}
what can I do?
It seems to be an error due to the return json config, when ttn-lw-cli is executed
This is the big clue - you have to feed it a JSON formatted file …
There is mention in the docs about using a tab delimited file, but that’s for migration and only has one column. But you could parse your file and use it as parameters with some sort of loop rather than just pushing it all in in one go.
The file is delimited with spaces, but I wrote tabs (4 spaces) to let best reading.
The script uses a loop, it takes the necessary values to register only one device. The function register_device() gets only 5 input parameters for 1 register each time.
But, it seems that a json config is returned and I don’t know how to deal with it.
How can it have a variable $1 that is the App ID in the command line but then use have Dev ID as the first column.
Perhaps best print the command out to see what it’s trying to send?
But the JSON response is clear, it can’t cope with a number that it needs to turn in to a string - possibly it is a carriage return embedded in to the APP_KEY.
Hi, Descartes.
The code exposed is a part of the complete script. I have echoed the command before send it, and it is ok. If I try code with only one device and not carriage return, it works.
I have tried to remove the last character with tr -d ‘\n’ or awk and it still not working. I have echoed it with xxd, so Im sure that APP_KEY contains the expected characters.
Complete code script is next one:
#!/bin/bash
CURRENT_DIR=`pwd`
PATH=$PATH:/$CURRENT_DIR
APPLICATION=$2
menu_ayuda() {
echo -e -n "\n"
echo "Uso: ttnctl_reg_masiva archivo de entrada"
echo -e -n "\n"
echo "Formato del archivo de entrada"
echo -e " DEVICE_EUI APP_KEY"
echo -e " ...\r\n"
# Selecciona el archivo de entrada
if [ -z $1 ]
then
echo "Seleccione un archivo para operación masiva"
menu_ayuda
exit 1
elif [ ! -e $1 ]
then
echo "El archivo seleccionado no existe"
exit 1
else
FILE=$1
fi
register_device()
JOIN_EUI=$2
DEV_EUI=$3
APP_KEY=`echo -n $4 | tr -d '\n'`
DEV_ID=`echo $3 | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
ttn-lw-cli end-devices create $1 $DEV_ID --join-eui $JOIN_EUI --dev-eui $DEV_EUI --root-keys.app-key.key $APP_KEY
echo end-devices create $1 $DEV_ID --join-eui $JOIN_EUI --dev-eui $DEV_EUI --root-keys.app-key.key $APP_KEY
while IFS= read -r device
do
register_device $APPLICATION $device
done < "$FILE"
