Hello, I am currently trying to set up my RHF76-052 node and I cant get it to talk to TTN. I have already set up my gateway, but when I try to connect to the TTN, it says that my LoRaWAN modem is busy. I do not know why it says that, since I dont have anything being transmitted which is what I am trying to do. There is probably something wrong with my code or there is another configuration that I need to try. Any help would be appreciated. If you have experience with setting this up please let me know and provide example code if possible.
you really have to be more clear and use search
yes, i probably should have been more specific. I apologize. Do you have experience with setting up one of these nodes? I tried that thread but the fixes that were suggested did not fix the problem i was having. If you have the code you used to set one of these up, then iâd appreciate it if you would post a picture so that I can try to implement your solution. Ive tried several and none of them have worked for me.
again, be more specific about the code youâve used and the problems youâve encountered.
Ive tried ssonzonoffâs code
(Rhf76-052am - getting it working with OTAA)
and I set it to my specifications with the US915 and changed the baud rate to 115200. I have also used the prepopulated arduino code from the LoRaWAN library for the OTAA setup and set the various keys in their respective spots, but that also didnt work. With the code from ssonzonoff I did see that the node was attempting to communicate to something, but when it toggled to try to connect, the connection timed out because the âlorawan modem is busyâ and then it would prompt me to connect to a network.
//Prepopulated arduino code that came with the libraries i downloaded
#include <LoRaWan.h>
unsigned char data[10] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 0xA,};
char buffer[256];
void setup(void)
SerialUSB.begin(115200);
while(!SerialUSB);
lora.init();
memset(buffer, 0, 256);
lora.getVersion(buffer, 256, 1);
SerialUSB.print(buffer);
lora.getId(buffer, 256, 1);
lora.setKey("2B7E151628AED2A6ABF7158809CF4F3C", "2B7E151628AED2A6ABF7158809CF4F3C", "2B7E151628AED2A6ABF7158809CF4F3C");
lora.setDeciveMode(LWOTAA);
lora.setDataRate(DR0, EU868);
lora.setChannel(0, 868.1);
lora.setChannel(1, 868.3);
lora.setChannel(2, 868.5);
lora.setReceiceWindowFirst(0);
lora.setReceiceWindowSecond(869.5, DR3);
lora.setPower(20);
while(!lora.setOTAAJoin(JOIN));
void loop(void)
bool result = false;
result = lora.transferPacket("Hello World!", 10);
//result = lora.transferPacket(data, 10, 10);
if(result)
short length;
short rssi;
length = lora.receivePacket(buffer, 256, &rssi);
if(length)
SerialUSB.print("Length is: ");
SerialUSB.println(length);
SerialUSB.print("RSSI is: ");
SerialUSB.println(rssi);
SerialUSB.print("Data is: ");
for(unsigned char i = 0; i < length; i ++)
SerialUSB.print("0x");
SerialUSB.print(buffer[i], HEX);
SerialUSB.print(" ");
SerialUSB.println();
Canât help you, due the fact iâm facing the exact same problem.
All the KEYS and IDâs like the DevAddr, DevEui, NWKSKEY , APPSKEY , APPKEY match with my configured settings in the things network. And i have a online gateway in range.
But i get the same messages;
+MODE: LWOTAA
+DR: EU868
+DR: DR0
+DR: EU868 DR0 SF12 BW125K
+ADR: ON
+CH: 0,868100000,DR0:DR5
+CH: 1,868300000,DR0:DR5
+CH: 2,868500000,DR0:DR5
+CH: 3,867100000,DR0:DR5
+CH: 4,867300000,DR0:DR5
+CH: 5,867500000,DR0:DR5
+CH: 6,867700000,DR0:DR5
+RXWIN1: ON; 7; 0,868100000; 1,868300000; 2,868500000; 3,867100000; 4,867300000; 5,867500000; 6,867700000;
+RXWIN2: 869500000,DR3
+POWER: 20
+JOIN: Start
+JOIN: NORMAL
+MSG: LoRaWAN modem is busy
+JOIN: Join failed
+JOIN: Done
+MSG: Please join network first
From the top of your listing it looks like it will attempt to join at DR0. Could you try to join using DR5?
Thank you for the reply @kersing !
That doesnât seem to help. Iâve tried connecting to the local lora provider (KPN) as well, which doesnât work either.
For both gateways/providers i tried ABP so there was no need to join the network. This results to the following log.
The error(-20) occurred due the empty AppEui and AppKey which are not necessary for ABP
+VER: 2.0.10
+ID: DevAddr, XXX
+ID: DevEui, XXX
+ID: AppEui,XXX
+ID: DevAddr, XXX
+ID: DevEui, XXXXX+KEY: NWKSKEY XXXX
+KEY: APPSKEY XXXXX
+AT: ERROR(-20)
+MODE: LWABP
+DR: EU868
+DR: DR5
+DR: EU868 DR5 SF7 BW125K
+ADR: ON
+RXWIN1: OFF; 3; 0,868100000; 1,868300000; 2,868500000;
+POWER: 20
+PORT: 1
Setup completed
+MSG: Start
+MSG: TX "9876"
+MSG: Done
I gave this device a try and had problems at first, but could resolve them later. I put together step-by-step instructions for those who have the same problems:
https://blog.squix.org/2017/07/seeeduino-lora-gps-getting-started-with-lorawan-and-ttn.html
Remaining open question: where do you get the DevEUI from? There seems to be no command/method to get the MAC address.
From the registered device in the TTN console
I know this is a cold post, but I think (myself included) weâve all had trouble getting these things to work. So once I got it working, I made a git repo that focuses on making it work for hybrid gateways (the oneâs that have 8 uplink channels, and cost << $1,000). I have only tried it with the US915 hybrid mode, but Iâve also included settings for changing it to any one of TTNâs supported country codes.
I also made an Instructable for it.
Hey Brady,
Thanks for the reference code. I am able to connect to senet network using seeeduino lorawan,
I have an issue with downlink. In senet portal i need to set port number to initiate downlink. Can you please guide me what âPortâ number needs to be set in senet portal. I guess it is port number of Lora module.
Thanks for the help.
I know this is an old post, but Iâd like to share how I got it to work, as I was breaking my head over it for days reading many topics on this forum.
It turns out that the receive windows are automatically set, so setting them manually in the code will only leave room for error. That said, removing the two lines below resulted in my device successfully joining the network and sending packets to my gateway.
lora.setReceiceWindowFirst(0, 868.1);
My final working code:
char buffer[256];
void setup(void)
while(!SerialUSB);
lora.init();
SerialUSB.println("\nSetting keys...");
// setKey(char *NwkSKey, char *AppSKey, char *AppKey)
lora.setKey(NULL, NULL, "<<< APP_KEY_HERE >>>");
lora.setChannel(3, 867.1);
lora.setChannel(4, 867.3);
lora.setChannel(5, 867.5);
lora.setChannel(6, 867.7);
lora.setPower(14);
// Give it some time to join the network
// To prevent "LoRaWAN modem is busy" messages
SerialUSB.println("Joined network, waiting for modem...");
delay(5000);
void loop(void)
if(result)
short length;
short rssi;
if(length)
delay(5000);
This results in the following output for me:
+VER: 2.1.16
+ID: DevAddr, 26:01:1F:2F
+ID: DevEui, 00:08:35:6E:E4:DB:7B:29
+ID: AppEui, 70:B3:D5:7E:D0:01:2D:81
Setting keys and IDs...
+KEY: APPKEY 06CFB3CD9B0A144EE16AC0C236850A6A
+MODE: LWOTAA
+DR: EU868
+DR: DR0
+POWER: 14
+JOIN: Start
+JOIN: NORMAL
Joined network, waiting for response...
+MSG: Start
+MSG: Done
Hope this helps!
