@scl how does your code look like? I mean the sending and receiving part
My set up in both nodes is this
Serial.print("Pausing mac: "); Serial1.write("mac pause\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); Serial.print("Setting device in lora modulation: "); Serial1.write("radio set mod lora\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting frequency: "); Serial1.write("radio set freq 868000000\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting power: "); Serial1.write("radio set pwr 14\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting sf: "); Serial1.write("radio set sf sf12\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting afcbw: "); Serial1.write("radio set afcbw 125\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting rxbw: "); Serial1.write("radio set rxbw 250\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting fdev: "); Serial1.write("radio set fdev 5000\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting prlen: "); Serial1.write("radio set prlen 8\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); // Serial.print("Setting crc: "); // Serial1.write("radio set crc on\r\n"); // delay(50); // while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting cr: "); Serial1.write("radio set cr 4/8\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink();
Serial.print("Setting sync: "); Serial1.write("radio set sync 12\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink(); Serial.print("Setting bw: "); Serial1.write("radio set bw 250\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink();
Serial.print("Setting wdt: "); Serial1.write("radio set wdt 0\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink();
Serial.print("Setting IQ inversion: "); Serial1.write("radio set iqi on\r\n"); //Serial1.write("radio get iqi\r\n"); delay(50); while (Serial1.available()) Serial.write(Serial1.read()); LoRaBlink();
