Hello, I deleted my account that still had a gateway still linked to it, because my gateway couldn’t connect to the TTN, I tried to recreate my account, but I cant access the gateway or create it again, it’s saying GATEWAY ID ALREADY EXISTS. what can i do to use my gateway again?
Forum search will reveal this is a common issue. The error message says gateway id, which you can’t re-use. It doesn’t say gateway EUI, which you can reuse.
Unless you deleted your v3 account with the gateway registered on v3, in which case, no, you can’t reuse the gateway EUI so you’ll have change it on the gateway or use it on a different network.
Moved to new topic as not related to login in to v3 console
Mod comment: Deleted a spam user/comment and removed account…
