Thank you for getting back to me quickly, really appreciate it.
noooo … don’t want to be taken off the Christmas list
Could you point me to the right direction on implementing a Downlink response please? Are you referring to the u1_t confirmed parameter value set to 1 when sending the next uplink request? We updated the device code to send the next uplink with u1_t confirmed value = 1, but still getting the previous downlink.
So far we have been using LMIC library with V2 and a confirmed downlink will normally be replaced by a non-confirmed downlink and once that is sent it stop repeating.
The device is a heltec esp32 lora unit. We are using ABP, downlink is just for initial installation where signal strength and confirmation on uplink msgs are received and confirmed. Then transmissions will be set to 30 mins interval via downlink and most probably never use downlink again. However it is vital during initial installation and setup.
Gateway is Laird RG186 on V3. I tried setting the RX1 delay to different values (1 to 5) but it doesn’t seems to have any effect and downlink still unable to reach device when using GSM network. Any suggestion on how to diagnose and a good way to overcome this problem? Thanks.
Thank you and looking forward to getting downlink working reliably
Out of curiosity I wondered … “What if I send a different confirmed downlink … would this new confirmed downlink repeat or the previous confirmed downlink will return after …” ?
With LAN (Broadband connection to Gateway) I scheduled a different downlink via TTN V3 console, after the device received this new downlink once, the previous downlink came back again … something very strange is happening … mmm
That is saying “send uplink as confirmed”. The acknowledgement of a downlink is done automatically from within LMIC. And as such there are notes regarding ensuring you don’t sleep before LMIC has finished. EV_TXDONE is only an event telling us that it has transmitted an uplink, it doesn’t tell us if the MAC still has other work to do which could take some time if there are series of MAC commands to process - as it may have a confirmed downlink to acknowledge that it transmits that receives a further downlink that needs processing and some sort of response.
It’s all cool, downlinks have their time & place, just not as a routine thing IMO.
It won’t do / that’s just advanced guessing.
You will have to change DELAY_DNW1 in lorabase.h for the downlink to work with ABP on 5s which is preferable but if you leave it as is in the code base you’ll need to set that to 1s in the device settings. I’m not sure if I should be proud or depressed that my brain retains this level of detail.
MCCI LMIC 3.2.0 onwards is highly compliant - as in it processes MAC commands which is an expectation of v3. You should use LoRaWAN version 1.0.3. I’m using 3.3.0 for real but have test devices running nicely on 4.0.0. I don’t deploy client devices using LMIC, but if further testing is satisfactory and given the world-wide shortage of modules I may well do.
Anyway, here’s the exciting command I’ve just tested.
I sent my device a confirmed reboot downlink which means it never confirms command and just keeps getting the downlink again.
Using:
ttn-lw-cli dev set your-application-id the-offending-device-id --unset mac-state.pending-application-downlink
Not strange at all, you asked for a downlink to be confirmed, it hasn’t yet, so TTS NS is resending.
Hopefully the CLI command above will reset the state of affairs.
If you need to know that a device has received a downlink it is preferable to put some logic in to the firmware & your backend systems.
To emphasise how non-PC confirmed downlinks are, TTI have only just put a message on the NS to tell us if a device has confirmed a downlink. Up until now we had no indication at all that one had been confirmed.
Is your device sleeping between uplinks? If so, does it go to ESP low power mode which forgets about the state of the LMIC stack with the result of the device not acknowledging the downlink?
That’s certainly a consideration - but as LMIC should ack a confirmed downlink in the same Tx request package, it’s likely that it just wasn’t compliant.
IIRC any ack should be in the next uplink. I don’t think the specification states an immediate uplink is required but I might be wrong. So if LMIC state is lost due to sleep before the next uplink it will not send the required ack.
Anyway, as we once again saw, confirmed down links are a source of issues so better to avoid them. As you stated, use application level logic in stead to ‘confirm’ receipt of new settings. That way you can also indicate the settings are valid or signal the device couldn’t apply them due to invalid values.
Very probably - so many moving parts - just admiring the Beelan source code which suggested it had added MAC command processing whereas in fact it’s still only a PR and only partially implemented - whilst I’m on a roll I can have a peek at LMIC to see what it thinks it’s doing & when.
@kersing, transpires that LMIC does trigger an uplink to confirm a downlink in v4. Took a while to trace so I’ll not do that with older versions.
I have created an ATmega4808 + RFM95 device specifically to trace MAC commands from TTS as they do appear to be numerous and I can put plenty of debug in to LMIC to see what’s going on, but printf only works (easily) on AVR, not SAMD.
Don’t know how the OP got in to a loop, but my client found the loop-da-loop by sending a confirmed reboot downlink and with the MKR WAN which you know I love, you can’t be sure you’ve done a Tx so if you get a confirmed downlink requesting it you’d then have to send a confirmed uplink to clear the confirmed downlink with the uplink being confirmed so you know that the downlink was confirmed (excepting MKR WAN doesn’t tell you an uplink was confirmed in current firmware) - we’ll end up with two Tx’s from the gateway in short order. What a mess!
@descartes Thanks Nick. I upgraded my LMIC lib to 3.3.0. I am impressed you can remembered the DELAY_DNW1 enum { DELAY_DNW1 = 1 };
Test Downlink with LAN-Home-broadband connection and it is responding as expected.
DELAY_DNWY1=1, RX1 Delay=1, Test Downlink with V3-Gateway+GSM-Cellular-Network connection and it is responding as expected (Missed downlink sometimes).
DELAY_DNWY1=5, RX1 Delay=5, Test Downlink with V3-Gateway+GSM-Cellular-Network connection and it missed most of the downlinks.
Nick, just to double confirm:
Should the u1_t confirmed parameter value set to 1 for the following UplinkTransmission when a ConfirmedDownlink was received?
Should I stick with LMIC lib version 3.3.0. and not 4.0.0. ?
I’m not sure I understand your results - are you saying that if you give the gateway longer to receive the downlink that it misses most of the downlinks?
Can you show the gateway & device web console for an uplink/downlink combo along with the gateway logging so we can see the actual timing.
It may be that there is some drift in the ESP32 that is causing the window to open late on 5 seconds but the drift isn’t sufficient to break the 1s delay. Ideally this needs fixing. Forum search will help.
No, that’s saying send a Confirmed Uplink and has nothing to do with what the Downlink status was. Sending a confirmed uplink isn’t really required with the newer firmware as it has Link Check built in so it will do that for you automatically every 64 uplinks (EU settings).
Anything that causes the gateway to transmit is BAD. Puppies may be harmed.
When??? Where did “when” come from? Please just don’t. Just no. Downlinks are the exception, confirmed downlinks are, as you’ve discovered, a whole world of hurt.
Just in case the message isn’t setting, this mummy cat is screaming because her kitten is crying because you sent a confirmed downlink.
Well, it’s all about making considered choices. I personally like to leave new versions running for a while on my test shelf - particularly if it’s a first number change. Right now I’m using 3.3.0 but I’m reading about the updates to the event system in 4 so I can start to migrate my code base so that I’m not doing it in a rush when the old event messages are deprecated.
Sort of, it’s the delay in the whole system, so the network server sends it to the gateway once it’s processed ‘stuff’ with when to send it to so that the gateway times it.
Again, sort of, its the NS logging that it sent the downlink straight away with a delay request baked in of 1 second.
You need to check your device settings on the web console to make sure Rx1 is set to 5s. It may be easier to set up a new device so you can ensure it ‘takes’.
OK, I haven’t circled back on this one but there are still some things to figure out with ABP and changing settings is one of them - work in progress as much as an issue as we need to apply some science to the process. I have ABP working on a variety of devices but I’ve lost track of it for LMIC.
Best thing is to create a new device. Couple of things to check:
The App/JoinEUI can’t be all zeros as suggested by the console as LMIC doesn’t cope with that at all - just make it all zeros with a one at the end.
When creating a new Device, I generate random Dev EUI but
AppEUI = n/a
JoinEUI = none
During my initial tests, Gateway is connected to LAN-Home-Broadband, downlink does work very well. It is when GSM network is involved, downlink just does not reach the device.
I performed a few tests with different DELAY_DNW1 and RX1 Delay value with both LAN-HomeBroadband and GSM Cellular network. I also utilised the simple ttn-abp (Example from LMIC lib) codes for testing the GSM network.
With LMIC 3.3.0 lib, Gateway connected to GSM cellular network, DELAY_DNW1=1, RS1 Delay=1, the downlinks does not reaching the device every time but it is sufficient for performing the necessary initial setup for a new device.
It would help if from TTN LiveData page we could find out whether a Downlink has been received by the device especially if we will not be able to see the device logs. You metioned LMIC will automatically confirm when it received a downlink? Any way to see this from TTN console? Thank you very much.
