He means format your message when posting (or as now when you go back and edit to correct!), this is a universal request across the forum that oft needs repeating
we sent earlier a downlink message via TTN but with teh command that a possibile message before is deleted. So that could not be the case I think
But, at EXACT the same time the COLLISION_BEACON in in the TTN console, there is an uplink message form the sensor. The sensor is on SF12 and therefore it take longer airtime to transmit en and therefore the downlink message cloud collide while the uplink is still in the air?
I apologize if my technical terms are not always right as I have limited in-depth knowlegde of LoRa
But I am very thankfull for all the help in this forum
Which in theory could end up being blocked by the NS as the LoRaWAN Alliance requires network operators to restrict the regular use of SF11 & 12.
Is this a Class B device - as beacons are usually a function of class B - if not, is there the possibility from the logs that the gateway is servicing a Class B device.
