Dragino RS485-LN + ABB Meter: Getting Modbus Timeout (Empty Payload) on Uplink
Hi everyone,
I am currently troubleshooting a remote setup using a Dragino RS485-LN connected to an ABB Energy Meter via Modbus RTU. The LoRaWAN connection itself is rock solid (great SNR and RSSI), but I keep getting constant Modbus timeouts (empty payloads in the uplink).
Here is what is currently working and configured:
  • Downlinks reach the device perfectly.
  • I successfully configured the UART settings via TTN downlinks to match the ABB factory defaults: 19200 Baud, Even Parity, 1 Stop Bit.
  • The Dragino acknowledges these settings by replying with “01” on FPort 2, so they are definitely saved in the flash memory.
  • To speed up debugging, I temporarily changed the uplink interval to 60 seconds (“01 00 00 3C”), which also works flawlessly.
The Problem:
When I send a Modbus read command (for example: A8 01 06 01 03 50 00 00 04 FF for the total energy register), the Dragino schedules it, polls the meter, but the resulting uplink response has a completely empty payload (0 bytes). The meter is completely silent.
What I have already tried remotely:
  • Function Codes: Tested both 03 (Read Holding) and 04 (Read Input). Both return empty.
  • Slave IDs: Tested polling IDs 01, 02, and 03 on the off chance it was changed during installation. All return empty.
  • Different Registers: Tested polling live voltage (Register 5B 00) instead of total energy (Register 50 00) to rule out the ABB “MidLock” feature (which blocks energy registers until a consumption of 1 kWh is reached). Still empty.
Crucial Limitation:
I currently have no physical access to the cabinet. I cannot attach a USB-RS485 sniffer right now, and I cannot physically swap the A/B data wires. I had the same problem for another device and it did not help swapping A/B.
Are there any specific Dragino configuration quirks, timing parameters, or ABB-specific Modbus settings that I might be overlooking from the remote side? Any suggestions on what else to look for in the TTN data stream would be highly appreciated.
Thanks in advance for any hints!
correct modbus termination enabled?
