Also, make sure to have SPI enabled (You wouldn’t be the first to forget that step)
Ah, thank you. Still confused as to what I should set SPI_SPEED
to. I saw some info about that here: https://github.com/Lora-net/lora_gateway/issues/26, but none have worked. I’ve experimented with many different SPI_SPEED
values in /opt/ttn-gateway/dev/lora_gateway/libloragw/inc/imst_rpi.h
, between 50k and 8M, and none have worked. Though now, with SPI_DEBUG
enabled, I get some SPI info before the failure:
14:24:41 INFO: [main] Starting the concentrator
Note: SPI port opened and configured ok
Note: SPI read success
14:24:41 ERROR: [main] failed to start the concentrator
Mp forwarder allows you to specify the SPI speed on the command line (-s ).
Have you locked the clock speed of the RPi3?
What do you use to reset the concentrator?
I’ve tried that method, too. No, I couldn’t figure out how to do that. Overclocking options are disabled on the Pi 3.
Locking the clock requires setting core_freq as mentioned in the message I linked to. Google helps as well…
I read that post feed, but was under the impression you didn’t need to lock it unless going >= 8M on baud. I’ll try locking it anyway.
I set core_freq=250
in /boot/config.txt
, rebooted, and tried a range of bauds, but still getting the same error. I’ve tried with sudo ./mp_pkt_fwd -s 8000000
. Is that reasonable? With all logging enabled, I get:
16:54:28 *** Multi Protocol Packet Forwarder for Lora Gateway ***
Version: 3.0.20
16:54:28 *** Lora concentrator HAL library version info ***
Version: 5.0.1; Options: native;
16:54:28 INFO: Little endian host
16:54:28 INFO: found global configuration file global_conf.json, parsing it
16:54:28 INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
16:54:28 INFO: lorawan_public 1, clksrc 1
lgw_board_setconf:437: Note: board configuration; lorawan_public:1, clksrc:1
16:54:28 INFO: no configuration for LBT
16:54:28 INFO: antenna_gain 0 dBi
16:54:28 INFO: Configuring TX LUT with 16 indexes
16:54:28 INFO: radio 0 enabled (type SX1257), center frequency 904300000, RSSI offset -166.000000, tx enabled 1
lgw_rxrf_setconf:486: WARNING: NOT A VALID TX NOTCH FILTER FREQUENCY [126000..250000]Hz
lgw_rxrf_setconf:498: Note: rf_chain 0 configuration; en:1 freq:904300000 rssi_offset:-166.000000 radio_type:2 tx_enable:1 tx_notch_freq:0
16:54:28 INFO: radio 1 enabled (type SX1257), center frequency 905000000, RSSI offset -166.000000, tx enabled 0
lgw_rxrf_setconf:498: Note: rf_chain 1 configuration; en:1 freq:905000000 rssi_offset:-166.000000 radio_type:2 tx_enable:0 tx_notch_freq:0
16:54:28 INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 0 configuration; en:1 freq:-400000 SF_mask:0x7e
16:54:28 INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 1 configuration; en:1 freq:-200000 SF_mask:0x7e
16:54:28 INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 2 configuration; en:1 freq:0 SF_mask:0x7e
16:54:28 INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 3 configuration; en:1 freq:200000 SF_mask:0x7e
16:54:28 INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 4 configuration; en:1 freq:-300000 SF_mask:0x7e
16:54:28 INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 5 configuration; en:1 freq:-100000 SF_mask:0x7e
16:54:28 INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 6 configuration; en:1 freq:100000 SF_mask:0x7e
16:54:28 INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:617: Note: LoRa 'multi' if_chain 7 configuration; en:1 freq:300000 SF_mask:0x7e
16:54:28 INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
lgw_rxif_setconf:591: Note: LoRa 'std' if_chain 8 configuration; en:1 freq:300000 bw:1 dr:4
16:54:28 INFO: FSK channel 8 disabled
lgw_rxif_setconf:525: Note: if_chain 9 disabled
16:54:28 INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
16:54:28 INFO: gateway MAC address is configured to B827EBFFFE15F6CB
16:54:28 INFO: Found 1 servers in array.
16:54:28 INFO: Server 0 configured to "router.us.thethings.network"
16:54:28 INFO: packets received with a valid CRC will be forwarded
16:54:28 INFO: packets received with a CRC error will NOT be forwarded
16:54:28 INFO: packets received with no CRC will NOT be forwarded
16:54:28 INFO: GPS is disabled
16:54:28 INFO: Upstream data is enabled
16:54:28 INFO: Downstream data is enabled
16:54:28 INFO: Ghoststream data is disabled
16:54:28 INFO: Radiostream data is enabled
16:54:28 INFO: Statusstream data is enabled
16:54:28 INFO: Beacon is disabled
16:54:28 INFO: Packet logger is disabled
16:54:28 INFO: Flush output after statistic is disabled
16:54:28 INFO: Flush after each line of output is disabled
16:54:28 INFO: Watchdog is disabled
16:54:28 INFO: [Transports] Initializing protocol for 1 servers
16:54:28 INFO: Successfully contacted server router.us.thethings.network
16:54:28 INFO: [main] Starting the concentrator
lgw_connect:532: INFO: no FPGA detected or version not supported (v0)
lgw_connect:555: ERROR: NOT EXPECTED CHIP VERSION (v0)
ERROR: FAIL TO CONNECT BOARD
16:54:28 ERROR: [main] failed to start the concentrator
It’s still not working, but I got closer. There’s a discrepancy between how we talk about pins in the TTN packet forwarder and forks off of Semtech’s. TTN’s reset pin refers to GPIO #, whereas Semtech and others refers to the reset pin by pin #. GPIO 7 = pin 26, so setting that to 26 in reset_lgw.sh
got me closer to working.
The last few lines of my verbose output are now:
lgw_spi_rb:373: BURST READ: to trans 1024 # chunk 1024 # transferred 8192
Note: SPI burst read success
ERROR: Failed to load fw 1
Note: SPI write success
ERROR: Version of calibration firmware not expected, actual:0 expected:2
21:18:55 ERROR: [main] failed to start the concentrator
Hello ehsanmgh,
I am facing the same problem. can you please tell me how you RESET the ic880a-SPI board.
I already tried it but it didn’t worked.
Is any other solutions to start the concentrator ?
Any help ll be appreciating.
Thank you.
Hi, I had the same issue, I could resolve it by resetting the CE0 and RESET pin before running the forwarder. Here is how i did it:
echo "Restarting the CE0 pin..."
CSPIN=8
echo "$CSPIN" > /sys/class/gpio/export
sleep 1
echo "out" > /sys/class/gpio/gpio$CSPIN/direction
echo "0" > /sys/class/gpio/gpio$CSPIN/value
sleep 1
echo "1" > /sys/class/gpio/gpio$CSPIN/value
echo "Done\n"
sleep 1
echo "Restarting the Concentrator..."
RSTPIN=17
echo "$RSTPIN" > /sys/class/gpio/export
sleep 1
echo "out" > /sys/class/gpio/gpio$RSTPIN/direction
echo "1" > /sys/class/gpio/gpio$RSTPIN/value
sleep 1
echo "0" > /sys/class/gpio/gpio$RSTPIN/value
echo "Done\nLaunching the forwarder..."
sleep 2
cd /PATH_TO_THE_GATEWAY_CODES/packet_forwarder/ && ./lora_pkt_fwd
Save this code in a shell file, change the path according to your own settings and make sure to run it with sudo
The full article can be found here
Moji
I read your article thank you very much, but I have doubts about how to save or create the code in the console. I am a newbie
As you can see i have the ‘ftdi’. Where can i find the instructions to fix this?
i’am having the same error:
“ERROR: [main] failed to start the concentrator”
Do you mean you have ftdi hardware? Or that you have SPI hardware and the wrong software version?
Which instructions have you used?
BTW the terminal output is ascii text, no need to use an image, just cut-and-paste the text as a quote/code block next time you post.
Any idea how I might resolve this error ? I am using LORA gateway along with a risinghf module. What might be the solution to this?
Be precise with details please if you expect help
Which model & configuration of hardware, which firmware, which packet forwarder…etc…
…and as last post above dont post images for such output…
@Jeff-UK Sorry Sir,
I am using RisingHF gateway “RHF2S025BH8-868” for my application to send data on iotsquare.xyz .
These are the steps I have followed:
- Created application on cloud.iotsquare.xyz and got DevEUI, AppEUI, Application and Network Key.
- Added gateway details and the Gateway ID onto cloud.iotsquare.xyz
- Packet Forward is enabled.
After performing above steps, the gateway is still not showing status as online.
Firewall is disabled, checked IP and it is present in the DHCP client table.
Also the internet speed is sufficient. So, I am not understanding what exactly might be the issue here.
Please suggest a solution for this.
…and TTN fits in where exactly, and what have you done to register there (gw, application, device?), what are you seeing in logs there?
To make Jeff’s post totally clear, it appears that you are not using TTN and this is a TTN forum.
If you are not using TTN, this is not the forum you are looking for.
Okay Sir. Sorry about the post.
