I want to use a Dragino LG308-868 LoRaWAN gateway to push some data from my sensors into TTN. The gateway is configured and connected with my TTN account. The next step is to push some data from my ESP over the gateway into TTN, but my application (I´m using the LoRaWAN LMIC library) doesn´t transmit the data:
Starting
RXMODE_RSSI
3767: engineUpdate, opmode=0x808
Packet queued
3805: EV_JOINING
3812: engineUpdate, opmode=0xc
3835: Unknown event
3908: TXMODE, freq=905300000, len=23, SF=10, BW=125, CR=4/5, IH=0
start single rx: now-rxtime: 3
339467: RXMODE_SINGLE, freq=927500000, SF=10, BW=500, CR=4/5, IH=0
rxtimeout: entry: 340367 rxtime: 339460 entry-rxtime: 907 now-entry: 5 rxtime-txend: 312375
401967: RXMODE_SINGLE, freq=923300000, SF=12, BW=500, CR=4/5, IH=0
rxtimeout: entry: 405555 rxtime: 401960 entry-rxtime: 3595 now-entry: 4 rxtime-txend: 374875
405576: Unknown event
405584: engineUpdate, opmode=0xc
441847: engineUpdate, opmode=0xc
441863: Unknown event
441930: TXMODE, freq=904600000, len=23, SF=8, BW=500, CR=4/5, IH=0
I use the following keys from TTN (OTAA) and the following application code:
#define LMIC_DEBUG_LEVEL 1
#include <Arduino.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// 0x70.
static const u1_t PROGMEM APPEUI[8] = { 0x90, 0x74, 0x03, 0xD0, 0x7E, 0xD5, 0xB3, 0x70 };
void os_getArtEui (u1_t* buf){ memcpy_P(buf, APPEUI, 8); }
static const u1_t PROGMEM DEVEUI[8] = { 0x2C, 0x4F, 0xEE, 0xBE, 0x3A, 0x12, 0x70, 0x00 };
void os_getDevEui (u1_t* buf){ memcpy_P(buf, DEVEUI, 8); }
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = { 0x47, 0x5B, 0x31, 0xDF, 0x77, 0x4F, 0xD8, 0x78, 0x23, 0x30, 0xCE, 0x97, 0x43, 0x8F, 0x3A, 0xDD };
void os_getDevKey (u1_t* buf){ memcpy_P(buf, APPKEY, 16); }
static osjob_t sendjob;
const unsigned TX_INTERVAL = 60;
.nss = 5,
.rxtx = LMIC_UNUSED_PIN,
.rst = 14,
.dio = {2, 22, LMIC_UNUSED_PIN},
void do_send(osjob_t* j);
void onEvent(ev_t Event)
Serial.print(os_getTime());
Serial.print(": ");
switch(Event)
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("artKey: ");
for(uint8_t i = 0; i < sizeof(artKey); ++i)
Serial.print(artKey[i], HEX);
Serial.println("");
Serial.print("nwkKey: ");
for(uint8_t i = 0; i < sizeof(nwkKey); ++i)
Serial.print(nwkKey[i], HEX);
Serial.println("");
LMIC_setSeqnoUp(140);
// during join, but not supported by TTN at this time).
LMIC_setLinkCheckMode(0);
break;
case EV_RFU1:
Serial.println(F("EV_RFU1"));
break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
break;
case EV_TXCOMPLETE:
if(LMIC.txrxFlags & TXRX_ACK)
if(LMIC.dataLen)
Serial.print(F("Received "));
Serial.print(LMIC.dataLen);
// Schedule next transmission
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
default:
break;
if(LMIC.opmode & OP_TXRXPEND)
else
LMIC_setTxData2(1, mydata, sizeof(mydata) - 1, 0);
void setup()
Serial.begin(115200);
Serial.println("Starting");
os_init();
LMIC_reset();
LMIC_setDrTxpow(DR_SF7, 14);
LMIC_selectSubBand(1);
do_send(&sendjob);
void loop()
os_runloop_once();
So what is wrong with this code?
