Europe 863 MHz frequency plan SF12 vs. SF9 for RX vs. OTAA devices
You shouldn’t have to. For gateways, both plans are equivalent. The difference in the RX2 data rate is only relevant for end devices.
I just filed Indicate whether plan is applicable to gateways / end devices · Issue #41 · TheThingsNetwork/lorawan-frequency-plans · GitHub to add an indicator in the frequency plans that tells the Console if a frequency plan applies to only end devices, only gateways or both.
