This works well: TheThingsStack-Integration-Starters/DataStorage-to-Tab-Python3 at main · descartes/TheThingsStack-Integration-Starters · GitHub
You need to fill in the top two lines. It’s a starter script so not so bright so it will download whatever you ask, it won’t deduplicate or look at previous downloads. Data storage only holds about 36 hours worth of data on v3 so needs to be kicked off at least once a day.
In the repro is also the same sort of functionality for Webhooks - no configuration required. I can set one up on a server if you’d like. There is also the same thing but with MQTT.
