Could I get your collective guru like help on an issue I am having please?
I have a Feather M0 and I am trying to a connect it with OTAA in the EU. I have the board soldered and a jumper between 6 and io1. Pic is attached:
My issue is that I am getting:
06:33:36.561 -> 8890728: EV_TXSTART
06:33:42.866 -> 9284437: EV_JOIN_TXCOMPLETE: no JoinAccept
06:34:48.521 -> 13388293: EV_TXSTART
06:34:54.858 -> 13785217: EV_JOIN_TXCOMPLETE: no JoinAccept
06:36:57.342 -> 21441679: EV_TXSTART
06:37:03.713 -> 21838604: EV_JOIN_TXCOMPLETE: no JoinAccept
06:39:06.862 -> 29535310: EV_TXSTART
06:39:13.195 -> 29932236: EV_JOIN_TXCOMPLETE: no JoinAccept
Now somewhere along the line I was getting the same problem but I was getting traffic at the gateway:
When I say ‘somewhere along the line’ I mean I have been reading other people’s issues and fiddling about and forgotten what I had at the time to get the traffic at the gateway.
Now I think its something with the region selection. This is because I was I was trying to alter the original lmic_project_config.h to match EU instead of the US as I thought that maybe the added project_config folder in the sketch folder wasn’t being ‘listening to’. When I did this I got an error about LMIC_selectSubBand. I commented this out as I had read it may not be needed and I get back to the cycling TXSTART Join etc. When take the comment out for LMIC_selectSubBand(1) and put the original lmic_project_config.h back to US I get the cycling again. It seems to be the change to EU it doesn’t like. I have also taken out the project_config folder in the sketch folder and tried all this with the same result.
To me it seems not to like the EU for some reason? Or am I just reading too much into selectSubBand being required to select a band?
So after all that any advice would be appreciated
I am attaching the sketch if its useful to see.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// For normal use, we require that you edit the sketch to replace FILLMEIN
// with values assigned by the TTN console. However, for regression tests,
// we want to be able to compile these scripts. The regression tests define
// COMPILE_REGRESSION_TEST, and in that case we define FILLMEIN to a non-
// working but innocuous value.
#ifdef COMPILE_REGRESSION_TEST
# define FILLMEIN 0
#else
# warning "You must replace the values marked FILLMEIN with real values from the TTN control panel!"
# define FILLMEIN (#dont edit this, edit the lines that use FILLMEIN)
#endif
// 0x70.
static const u1_t PROGMEM APPEUI[8]= { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x03, 0x15, 0xE7 };
static const u1_t PROGMEM DEVEUI[8]= { 0x00, 0x22, 0xBF, 0xD0, 0x77, 0xC2, 0x17, 0xAE };
// practice, a key taken from the TTN console can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = { 0x96, 0x54, 0x5B, 0xBC, 0x56, 0x6F, 0x94, 0x58, 0xD7, 0x20, 0x17, 0xD9, 0x32, 0x23, 0xC1, 0x38 };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping
// Adafruit BSPs are not consistent -- m0 express defs ARDUINO_SAMD_FEATHER_M0,
// m0 defs ADAFRUIT_FEATHER_M0
#if defined(ARDUINO_SAMD_FEATHER_M0) || defined(ADAFRUIT_FEATHER_M0)
// Pin mapping for Adafruit Feather M0 LoRa, etc.
.nss = 8,
.rxtx = LMIC_UNUSED_PIN,
.rst = 4,
.dio = {3, 6, LMIC_UNUSED_PIN},
.rxtx_rx_active = 0,
.rssi_cal = 8, // LBT cal for the Adafruit Feather M0 LoRa, in dB
.spi_freq = 8000000,
#elif defined(ARDUINO_AVR_FEATHER32U4)
// Pin mapping for Adafruit Feather 32u4 LoRa, etc.
// Just like Feather M0 LoRa, but uses SPI at 1MHz; and that's only
// because MCCI doesn't have a test board; probably higher frequencies
// will work.
.nss = 8,
.rst = 4,
.dio = {7, 6, LMIC_UNUSED_PIN},
.rssi_cal = 8, // LBT cal for the Adafruit Feather 32U4 LoRa, in dB
.spi_freq = 1000000,
#elif defined(ARDUINO_CATENA_4551)
// Pin mapping for Murata module / Catena 4551
.nss = 7,
.rxtx = 29,
.rst = 8,
.dio = { 25, // DIO0 (IRQ) is D25
26, // DIO1 is D26
27, // DIO2 is D27
.rxtx_rx_active = 1,
.rssi_cal = 10,
.spi_freq = 8000000 // 8MHz
#else
# error "Unknown target"
#endif
void printHex2(unsigned v) {
v &= 0xff;
if (v < 16)
Serial.print('0');
Serial.print(v, HEX);
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("AppSKey: ");
for (size_t i=0; i<sizeof(artKey); ++i) {
if (i != 0)
Serial.print("-");
printHex2(artKey[i]);
Serial.println("");
Serial.print("NwkSKey: ");
for (size_t i=0; i<sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print("-");
printHex2(nwkKey[i]);
Serial.println();
LMIC_setLinkCheckMode(0);
break;
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
Serial.println(LMIC.dataLen);
// Schedule next transmission
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
break;
case EV_TXCANCELED:
Serial.println(F("EV_TXCANCELED"));
break;
case EV_RXSTART:
/* do not print anything -- it wrecks timing */
break;
case EV_JOIN_TXCOMPLETE:
Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
break;
default:
break;
void do_send(osjob_t* j){
} else {
void setup() {
delay(5000);
while (! Serial)
Serial.begin(9600);
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
// LMIC init
os_init();
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 3 / 100);
LMIC_setDrTxpow(DR_SF7,14);
// LMIC_selectSubBand(1);
do_send(&sendjob);
void loop() {
os_runloop_once();
