Well, I a bit scared of giving you the wrong bit, but here goes nothing. “Packetbroker” may be the GW it uses?
"name": "ns.up.data.process",
"time": "2022-08-08T16:27:23.132506458Z",
"identifiers": [
"device_ids": {
"device_id": "eui-2cf7f12032400078",
"application_ids": {
"application_id": "tempsagene"
"dev_eui": "2CF7F12032400078",
"join_eui": "8000000000000009",
"dev_addr": "260B0946"
"data": {
"raw_payload": "QEYJCyaABQACTVAik8KlwEfhkoLcKg==",
"payload": {
"m_hdr": {
"m_type": "UNCONFIRMED_UP"
"mic": "koLcKg==",
"mac_payload": {
"f_hdr": {
"dev_addr": "260B0946",
"f_ctrl": {
"adr": true
"f_cnt": 5
"f_port": 2,
"frm_payload": "TVAik8KlwEfh",
"full_f_cnt": 5
"settings": {
"data_rate": {
"lora": {
"bandwidth": 125000,
"spreading_factor": 12
"coding_rate": "4/5",
"frequency": "867300000"
"rx_metadata": [
"gateway_ids": {
"gateway_id": "packetbroker"
"packet_broker": {
"message_id": "01G9Z4GJD1NF40M3T82M8D8011",
"forwarder_net_id": "000013",
"forwarder_tenant_id": "ttnv2",
"forwarder_cluster_id": "ttn-v2-legacy-eu",
"forwarder_gateway_eui": "C0EE40FFFF297392",
"forwarder_gateway_id": "eui-c0ee40ffff297392",
"home_network_net_id": "000013",
"home_network_tenant_id": "ttn",
"home_network_cluster_id": "eu1.cloud.thethings.network"
"rssi": -112,
"channel_rssi": -112,
"snr": -6.5,
"location": {
"latitude": 59.902731,
"longitude": 10.741787,
"altitude": 62
"uplink_token": "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",
"received_at": "2022-08-08T16:27:22.911388237Z"
"received_at": "2022-08-08T16:27:22.928433299Z",
"correlation_ids": [
"ns:uplink:01G9Z4GJDGNZG5ZAN7K1TYBK52",
"pba:conn:up:01G9YK8055Q7PAJ77WG4ZEF157",
"pba:uplink:01G9Z4GJD1NF40M3T82M8D8011",
"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01G9Z4GJDG4CRAJ3DR1BFP5Q1G"
"device_channel_index": 4,
"consumed_airtime": "1.482752s"
"origin": "ip-10-100-5-248.eu-west-1.compute.internal",
"context": {
"tenant-id": "CgN0dG4="
"visibility": {
"rights": [
"unique_id": "01G9Z4GJKWMF7P9DEEFRJ6RH9E"
