I still block on this . I have try to delete recreate the gateway. But gateway is connected but i never see the traffic. Nobody has an idea to debug this ? is there traces to provide ?
E..(i.@.@..y....4.L..k.....,.l..rv.....d
19:39:44.212258 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .x@./.r.4.L........k.....l..................t.
19:39:51.286062 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 235
E...kx@.@..3....4.L..s....,.....rv.....d{"rxpk":[{"tmst":719405219,"time":"2019-12-09T19:39:51Z","chan":0,"rfch":1,"freq":868.100000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":8.8,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBAD5eQMwppg="}]}
19:39:54.211301 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(l.@.@..x....4.L..k....}w.!+.rv.....d
19:39:54.251252 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .R@./.m@4.L........k...f.!+................Z.=
19:39:54.734935 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E...l:@.@.......4.L..s....-
....rv.....d{"stat":{"time":"2019-12-09 19:39:54 GMT","rxnb":2,"rxok":2,"rxfw":2,"ackr":33.3,"dwnb":0,"txnb":0,"ping":42}}
19:39:54.762166 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .X@.0.l:4.L........s......................ou..
19:40:04.251293 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(m.@.@.......4.L..k.....C.U..rv.....d
19:40:04.295861 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.i.4.L........k...2.U.................Ib;
19:40:07.434573 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 235
E...o.@.@.......4.L..s........p.rv.....d{"rxpk":[{"tmst":735542259,"time":"2019-12-09T19:40:07Z","chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":9.0,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBAAEfmb2ZNM="}]}
19:40:14.291443 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(o.@.@.......4.L..k....4...s.rv.....d
19:40:14.332562 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.h.4.L........k......s................xT2
19:40:24.131871 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(p.@.@.......4.L..k.....].;..rv.....d
19:40:24.173826 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.`.4.L........k.. M.;.................e..
19:40:24.738240 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E...p.@.@..;....4.L..s.....].\..rv.....d{"stat":{"time":"2019-12-09 19:40:24 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":43}}
19:40:24.774191 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. ..@.0._.4.L........s..9&.\................;H..
19:40:34.171277 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(s.@.@.......4.L..k.....b.6..rv.....d
19:40:34.212424 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.`{4.L........k...Q.6....................
19:40:44.211458 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(v.@.@.......4.L..k..........rv.....d
19:40:44.251139 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .?@./.`S4.L........k..t....................O..
19:40:54.251276 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(x.@.@.~.....4.L..k..........rv.....d
19:40:54.293794 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.[.4.L........k..3..................."v..
19:40:54.748773 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E...x.@.@.~P....4.L..s....u.....rv.....d{"stat":{"time":"2019-12-09 19:40:54 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":43}}
19:40:54.779481 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .*@.0.Zh4.L........s..m...................Wq4.
19:41:04.291486 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(||@.@.{.....4.L..k....vI.O2.rv.....d
19:41:04.332607 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .r@./.U 4.L........k...8.O2...................
19:41:14.132004 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(})@.@.za....4.L..k...._...I.rv.....d
19:41:14.174073 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .q@./.P!4.L........k...r..I.................+:
19:41:24.171859 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(}@@.@.zJ....4.L..k....%.....rv.....d
19:41:24.212789 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.K.4.L........k..........................
19:41:24.754129 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E...}r@.@.y.....4.L..s....m{.N..rv.....d{"stat":{"time":"2019-12-09 19:41:24 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":43}}
19:41:24.784325 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .%@.0.Jm4.L........s..c4.N................->P.
19:41:34.211442 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.v.....4.L..k....8...p.rv.....d
19:41:34.251562 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .6@./.G\4.L........k......p................JP.
19:41:44.251296 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.s.....4.L..k..........rv.....d
19:41:44.290369 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .6@./.?\4.L........k..q...................  ...
19:41:54.291572 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.q.....4.L..k........).rv.....d
19:41:54.332736 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.8.4.L........k......)...............^ke(
19:41:54.752997 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E.....@.@.pj....4.L..s.....u.TH.rv.....d{"stat":{"time":"2019-12-09 19:41:54 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":41}}
19:41:54.783759 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .0@.0.7b4.L........s.....TH..................D
19:42:04.132105 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.o.....4.L..k........
.rv.....d
19:42:04.174174 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.5.4.L........k......
................4M.
19:42:14.171878 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.m.....4.L..k..........rv.....d
19:42:14.213178 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .L@./.2F4.L........k..N.....................[.
19:42:23.876021 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 235
E....s@.@.j8....4.L..s.....d....rv.....d{"rxpk":[{"tmst":871987659,"time":"2019-12-09T19:42:23Z","chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":7.0,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBACjOpuAxP0="}]}
19:42:24.211397 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.x@.@.k.....4.L..k....c...D.rv.....d
19:42:24.252284 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.,.4.L........k......D...............K.H.
19:42:24.753773 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E.....@.@.j.....4.L..s........[.rv.....d{"stat":{"time":"2019-12-09 19:42:24 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":43}}
19:42:24.788773 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .E@.0.+M4.L........s......[...............Yu:g
19:42:34.251319 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.h.....4.L..k..........rv.....d
19:42:34.291041 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .9@./.*Y4.L........k......................^...
19:42:44.291346 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.m@.@.e.....4.L..k.....K.L..rv.....d
19:42:44.335890 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.'.4.L........k..M;.L....................
19:42:54.131668 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.K@.@.b?....4.L..k.....k.-..rv.....d
19:42:54.171746 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.$.4.L........k...Z.-................1.,.
19:42:54.757293 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E....v@.@.a.....4.L..s.......   B.rv.....d{"stat":{"time":"2019-12-09 19:42:54 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":43}}
19:42:54.789821 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .C@.0.#O4.L........s...y.   B..................N
19:43:04.171297 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.`.....4.L..k..........rv.....d
19:43:04.211003 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k......................iN..
19:43:10.090159 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 235
E.....@.@.^.....4.L..s....{...3.rv.....d{"rxpk":[{"tmst":918201547,"time":"2019-12-09T19:43:10Z","chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":9.2,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBACxczQc3+A="}]}
19:43:14.211291 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.].....4.L..k..........rv.....d
19:43:14.251559 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .4@./..^4.L........k..V...................6f^1
19:43:24.251303 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.B@.@.]H....4.L..k....#.....rv.....d
19:43:24.290582 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k......................-..;
19:43:24.787351 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E....t@.@.\.....4.L..s...."=..-.rv.....d{"stat":{"time":"2019-12-09 19:43:24 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":41}}
19:43:24.828030 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. ..@.0...4.L........s......-.................6.
19:43:26.222724 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 235
E.....@.@.[.....4.L..s..........rv.....d{"rxpk":[{"tmst":934339083,"time":"2019-12-09T19:43:26Z","chan":0,"rfch":1,"freq":868.100000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":9.5,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBAAcJcnKsXo="}]}
19:43:34.291270 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.\     ....4.L..k....a".vG.rv.....d
19:43:34.332590 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k.....vG................;.p
19:43:44.131281 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.A@.@.[I....4.L..k....u...2.rv.....d
19:43:44.170757 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k......2...............c/3.
19:43:54.171416 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.X.....4.L..k.....{....rv.....d
19:43:54.213138 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k..8k....................}E
19:43:54.788367 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E....9@.@.W.....4.L..s.....p.J..rv.....d{"stat":{"time":"2019-12-09 19:43:54 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":42}}
19:43:54.824264 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. ..@.0...4.L........s..H8.J....................
19:44:04.211268 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.V.....4.L..k.....g.0..rv.....d
19:44:04.252103 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k...W.0..................!.
19:44:14.251441 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.S.....4.L..k.....x. #.rv.....d
19:44:14.290911 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./..e4.L........k...h. #...............*.).
19:44:24.291273 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.P.....4.L..k....<...l.rv.....d
19:44:24.333357 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E..
d@./...4.L........k......l...............CW..
19:44:24.802492 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E.....@.@.P4....4.L..s....`.....rv.....d{"stat":{"time":"2019-12-09 19:44:24 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":43}}
19:44:24.837471 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E..
n@.0..$4.L........s..Y....................i.O
19:44:25.942387 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 236
E.....@.@.O.....4.L..s..........rv.....d{"rxpk":[{"tmst":994031948,"time":"2019-12-09T19:44:25Z","chan":7,"rfch":0,"freq":867.900000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":9.2,"rssi":nan,"size":23,"data":"QJZTnQ+ALAIIffYQeo85SEfOoz6CMZY="}]}
19:44:34.131716 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.C@.@.PG....4.L..k..........rv.....d
19:44:34.170936 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .;@./..W4.L........k..7....................)r.
19:44:44.171713 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.O.....4.L..k..........rv.....d
19:44:44.214396 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k..k|..................a..M
19:44:54.211277 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.N}....4.L..k.....w. ..rv.....d
19:44:54.252298 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. .`@./..24.L........k..jg. ................t(.7
19:44:54.804064 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E.....@.@.N.....4.L..s.....3....rv.....d{"stat":{"time":"2019-12-09 19:44:54 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":43}}
19:44:54.840057 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .i@.0..)4.L........s..H.....................i.
19:45:04.251403 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.Lw....4.L..k.....Z.>..rv.....d
19:45:04.291329 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k...J.>................[..z
19:45:14.291281 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.l@.@.J.....4.L..k..........rv.....d
19:45:14.333661 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. !.@./...4.L........k..7...................."=+
19:45:24.131726 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.h@.@.H"....4.L..k....@...g.rv.....d
19:45:24.171380 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. (.@./...4.L........k......g...............m..1
19:45:24.802950 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E.....@.@.G{....4.L..s....\..3..rv.....d{"stat":{"time":"2019-12-09 19:45:24 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":42}}
19:45:24.836454 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. (.@.0...4.L........s..UO.3.................<..
19:45:32.644392 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 236
E.....@.@.F.....4.L..s........P.rv.....d{"rxpk":[{"tmst":1060760531,"time":"2019-12-09T19:45:32Z","chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":7.0,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBACKVFfkLv0="}]}
19:45:34.171425 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.Gq....4.L..k..........rv.....d
19:45:34.210710 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. 0C@./..O4.L........k..@....................h..
19:45:44.211293 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.=@.@.DM....4.L..k..........rv.....d
19:45:44.252806 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. 3.@./...4.L........k..Qs..................e..,
19:45:54.251423 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.A.....4.L..k....s...4.rv.....d
19:45:54.291857 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. :8@./..Z4.L........k......4..................1
19:45:54.803354 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E.....@.@.A.....4.L..s........^.rv.....d{"stat":{"time":"2019-12-09 19:45:54 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":41}}
19:45:54.844870 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. :|@.0...4.L........s......^...................
19:46:04.291281 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.@r....4.L..k..........rv.....d
19:46:04.330621 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. >.@./...4.L........k..1....................*..
19:46:14.131712 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.&@.@.>d....4.L..k..........rv.....d
19:46:14.172305 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. A.@./...4.L........k..|w..................l..M
19:46:24.171351 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.;.....4.L..k..........rv.....d
19:46:24.211012 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. F`@./..24.L........k.........................5
19:46:24.805868 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E....$@.@.:.....4.L..s.....6....rv.....d{"stat":{"time":"2019-12-09 19:46:24 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":41}}
19:46:24.848755 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. F.@.0...4.L........s..
19:46:28.885443 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 236
E.....@.@.9.....4.L..s....Qz....rv.....d{"rxpk":[{"tmst":1117000811,"time":"2019-12-09T19:46:28Z","chan":0,"rfch":1,"freq":868.100000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":9.5,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBABTNMbEIyQ="}]}
19:46:34.211277 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.G@.@.9C....4.L..k....c...D.rv.....d
19:46:34.253623 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. N.@./...4.L........k......D.................I.
19:46:44.251346 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.5.....4.L..k.......x..rv.....d
19:46:44.293055 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. R.@./...4.L........k..*..x................:o..
19:46:45.026440 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 236
E.....@.@.4.....4.L..s....r8.Ii.rv.....d{"rxpk":[{"tmst":1133137619,"time":"2019-12-09T19:46:45Z","chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":9.8,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBABPD6t8nFM="}]}
19:46:54.291546 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.c@.@.3'....4.L..k........#.rv.....d
19:46:54.331461 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. Xc@./../4.L........k......#.................}.
19:46:54.802197 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E.....@.@.2.....4.L..s..../.....rv.....d{"stat":{"time":"2019-12-09 19:46:54 GMT","rxnb":2,"rxok":2,"rxfw":2,"ackr":33.3,"dwnb":0,"txnb":0,"ping":42}}
19:46:54.843348 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. X.@.0...4.L........s......................SCth
19:47:04.131984 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.1.....4.L..k....>...i.rv.....d
19:47:04.172724 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. a5@./..]4.L........k......i.................o.
19:47:14.171286 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.0.....4.L..k....*..j~.rv.....d
19:47:14.211491 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. d.@./...4.L........k.....j~...............4.#>
19:47:24.211433 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(./@.@.-[....4.L..k....*L.L~.rv.....d
19:47:24.253940 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. k]@./..54.L........k...;.L~...............S.:.
19:47:24.821086 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E....d@.@.,.....4.L..s.....x.Q%.rv.....d{"stat":{"time":"2019-12-09 19:47:24 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":42}}
19:47:24.865225 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. k.@.0...4.L........s...1.Q%.................q.
19:47:34.251410 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.).....4.L..k...._...H.rv.....d
19:47:34.292250 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. q.@./...4.L........k......H................./.
19:47:44.291411 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.%.....4.L..k....U...S.rv.....d
19:47:44.331244 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. x.@./...4.L........k......S................m.w
19:47:54.131729 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.S@.@.#7....4.L..k.....^.:..rv.....d
19:47:54.172913 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. z.@./...4.L........k...M.:..................c.
19:47:54.824303 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E....]@.@.".....4.L..s........1.rv.....d{"stat":{"time":"2019-12-09 19:47:54 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":42}}
19:47:54.865678 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. z.@.0...4.L........s......1...............v..z
19:48:04.171861 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@. t....4.L..k..........rv.....d
19:48:04.211456 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./...4.L........k.........................5
19:48:14.211421 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.......4.L..k....Qf.2W.rv.....d
19:48:14.250509 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.~.4.L........k...U.2W..................<
19:48:24.251290 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.......4.L..k.....S.D..rv.....d
19:48:24.292822 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.y.4.L........k..6C.D.................4.j
19:48:24.821682 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 123
E.....@.@.......4.L..s....T.....rv.....d{"stat":{"time":"2019-12-09 19:48:24 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":42}}
19:48:24.864523 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .(@.0.xj4.L........s..O....................v<G
19:48:34.291546 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.x@.@.......4.L..k..........rv.....d
19:48:34.331314 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.t.4.L........k..>......................m
19:48:44.132071 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.5@.@..U....4.L..k.....r.%..rv.....d
19:48:44.172923 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.p~4.L........k..Ub.%.................=..
19:48:51.447047 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 236
E....G@.@..c....4.L..s..........rv.....d{"rxpk":[{"tmst":1259557483,"time":"2019-12-09T19:48:51Z","chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":7.5,"rssi":nan,"size":23,"data":"AFJdAtB+1bNwTwweAAujBAArb2vw8g8="}]}
19:48:54.171314 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.`@.@..*....4.L..k..........rv.....d
19:48:54.211965 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.m.4.L........k..A...................QF.h
19:48:54.823164 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E....q@.@.......4.L..s.....\.^S.rv.....d{"stat":{"time":"2019-12-09 19:48:54 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":42}}
19:48:54.865630 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. .-@.0.le4.L........s...$.^S................_..
19:49:04.211427 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.......4.L..k.....7.`..rv.....d
19:49:04.250696 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.i.4.L........k..z'.`................w...
19:49:14.251294 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(.$@.@..f....4.L..k..........rv.....d
19:49:14.292935 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.a.4.L........k..q.......................
19:49:24.291582 IP 192.168.1.30.36715 > 52.169.76.203.1700: UDP, length 12
E..(..@.@.......4.L..k....".....rv.....d
19:49:24.332470 IP 52.169.76.203.1700 > 192.168.1.30.36715: UDP, length 4
E.. ..@./.^.4.L........k........................+.
19:49:24.770029 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 238
E..
..@.@.......4.L..s........T.rv.....d{"rxpk":[{"tmst":1292857668,"time":"2019-12-09T19:49:24Z","chan":3,"rfch":0,"freq":867.100000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":10.5,"rssi":nan,"size":23,"data":"QJZTnQ+ALQII6v5Xu0XEVRW5Vlnsra0="}]}
19:49:24.876019 IP 192.168.1.30.42867 > 52.169.76.203.1700: UDP, length 122
E.....@.@..R....4.L..s........5.rv.....d{"stat":{"time":"2019-12-09 19:49:24 GMT","rxnb":1,"rxok":1,"rxfw":1,"ackr":50.0,"dwnb":0,"txnb":0,"ping":42}}
19:49:24.917155 IP 52.169.76.203.1700 > 192.168.1.30.42867: UDP, length 4
E.. ..@.0.]v4.L........s......5...............B`..
