@bluejedi is right using the modules from EByte for example does not bring you the nice arduino integration.
you have to use the SDK from cypress for example
Is it possible to give an estimate for availability of PlatformIO support?
I noticed (but did not see such low price).
Ebyte has 2-3 stores on AE. At least one of them does typically make a ‘sale’ offer at any particular moment. This is one example
No generic Arduino support is available for ASR650x I guess. I have only seen Arduino support for the CubeCells.
Since ASR6501 is a S-i-P - most of stuff is hardwired inside the package. This makes such devices very compatible between different final product manufacturers.
Even firmware binaries are likely transferable in such cases, not only SDKs.
Example of such compatibility within single SiP (valid not for ASR but for similar AcSiP S76G package) is this one - firmware binaries from RAK7200 LoRaWAN GNSS assets tracker can run on TTGO T-Motion tracker (and likely vice versa).
Has anyone successfully used a DHT22(AM2305) in combination with a CubeCell board?
I am very sorry for this.
I tried platform.io support at the end of last year, but I did not succeed because I don’t have enough sense about this platform.
Not long ago, the founder of platform.io contacted me and gave some suggestions and support. These days I am busy with the release of the new ASR6502 series (the original plan was released last week, but there were some problems in production because of COVID-19 The impact of many components can not reach our factory on time).
The support of platform.io is already in my plan, and I will deal with it when the ASR6502 series is released.
Thank you! Many people are waiting for Platform.io support for CubeCell boards. In our case this is the main reason why our company hesitates with switching to this platform.
Some new products of CubeCell series released:
https://heltec.org/proudct_center/lora/cubecell/
When using the things stack server which MAC and PHY version is right for the cubecells?
It would be nice to add a comparison between the different CubeCell products so one can select a board based on requirements.
HTCC-AB02S product page Overview says:
Ultra low power design, 50uA in deep sleep;
HTCC-AB02S product page Tech Specs says:
Low power design Deep Sleep 3.5uA
Apparently the 50uA in the Overview is correct and 3.5uA is uncorrected copy/paste?
Why is deep sleep current 14+ times higher than for the other CubeCell boards?
the deep sleep current is higher because the GPS needs so much current even in sleep.
That is what I suspected. Are those 46uA during deep sleep needed to keep GPS state e.g. for hot start?
There should be an option to power-off/on the GPS if the user so desires so it can be disabled during deep sleep when GPS is not always needed (similar to why VExt was added).
Sorry, that’s a mistake, fixed now.
Because the sleep current of the Air530 GPS module used is about 20uA, plus other peripheral circuits (mainly diodes), there are nearly 20uA, plus the current of CubeCell, so the sleep current is ~50uA
So no option to power-off GPS (etc.) when not needed?
Is the stated 3.5uA deep sleep current for HTCC-AB02 (not AB02S) correct?
Can the display be fully powered off or is true deep sleep current of the board higher than 3.5uA?
CubeCell 1/2AA Node (HTCC-AB02A)
This is the most basic version of the three new ASR6502 based boards.
Features that the other ASR6502 based models do not have:
CubeCell Dev-Board Plus (HTCC-AB02)
Similar to HTCC-AB02A with added:
Comparable to HTCC-AB01 but with display and ASR6502 with more IO ports and additional SPI.
CubeCell GPS-6502 (HTCC-AB02S)
Note: The boards have different pinouts.
Preference: I would have liked USB-C instead of microUSB connectors.
for the HTCC-AB02A:
if you dont need the SPI pins you can use pin header expansions for using it on a breadboard.
If you design your own PCBs you can use long female pin headers.
Yes that is a good and non-destructive option.
Those SPI pins used for LoRa should not be needed anyway (unless needed for measurements) and ASR6502 has a second SPI port if SPI is needed.
My first CPU was a MOS Technology 6502 (second-sourced by Rockwell).
So the ASR6502 feels like some kind of Déjà vu.
A long time ago my first was a
Zilog Z80A @ 4 MHz
In a schneider cpc
10 years after your 6502
