How can i get my data (nodes) to twitter?
get the measure and then tweeting automatically, like a bot, what integration can i use?
Do you have a very good use case for this?
Sending bot-like status messages to Twitter is often only generating Twitter spam.
Examples of such behavior are hobbyists spamming the #raspberrypi hashtag with temperature and humidity measurements from their Raspberry Pi, and organisations spamming the #iot hashtag when some bridge somewhere is opened and closed.
Which is not what Twitter should be used for.
Does not sound like a good use case.
Don’t send status tweets (spam) ā€˜just because you can’.
You can do it easily with Zapier. Create a webhook in Zapier, and connect it to you Twitter account. I did it several times and it works like a charm. Enjoy.
You can use private Tweets if you want to be an ā€œethicalā€ guy. And you can also use Zapier to tweet only important events and not all the measures. Twitter will probably ask additionnal verification at the beginning, but after a couple of days, if you are not publishing 100 msg / day, it will be ok.
