Some regions require LBT, Listen-Before-Talk. But with long-range radio, I wonder how a device knows what threshold it should use to decide if an ongoing transmission needs to be respected.
Like: if LoRa/LoRaWAN becomes popular, a device will often detect transmissions from other devices. But given the long-range nature of LoRa, those transmissions might originate from distant areas that are covered by other gateways, regardless the simultaneous transmissions of distant devices in other areas? I’d assume that such situations could safely be ignored for LBT. However, devices do not know anything about the density (number of gateways) of the network.
Maybe this relies on ADR, which might have configured the device to use an optimal data rate and transmission power, which might then make it understand what threshold to respect for LBT? Or maybe a device adapts its threshold when it cannot find an opportunity to transmit?
