How to connect Utrecht E&A exhibition KISS LoRa to TTN?
Today i have tested the Kiss-Lora cycling to Eindhoven-centre using ttnmapper.org
You see a very poor coverage, despite of the fact that there are enough gateways, and the ttnmapper map shows good coverage. If i compare the result with nearly the same route a week a go with a ‘standard’ RFM95 node with a short antenna, i have a much better connection.
-> EDIT: I was not satisfied with the result. I did another slightly different tour, removed the esd bag (LOL), and it was pretty good with the sensor in my hand:
Feather M0-RFM95 combo:
