I am new to LoRa and TTN.
I would like to attach https://lorabridge2.github.io/ to TTN instead of owning a dedicated gateway.
I advised the AI to implement the connector and it looks fine now.
But: Login to the MQTT Server fails.
any idea why?
def on_connect(client, userdata, flags, rc):
logging.info("Connected to TTN with result code " + str(rc))
if rc == 0:
# Subscribe to uplink messages for all devices in the application
# Topic format: v3/{application-id}@{tenant-id}/devices/+/up
topic = TTN_UPLINK_TOPIC
logging.info(f"Subscribing to TTN uplink topic: {topic}")
client.subscribe(topic)
# JPT OLD client.subscribe(userdata["chirp"] + "+/event/up")
else:
logging.error(f"Failed to connect to TTN, return code {rc}")
You can find my source here:
MAIN branch is more or less what I am running, EMERGENT branch is what the AI produced.
If you want to see the original source just go where I forked from.
You can simply run converter.py from commandline, if python is set up correctly.
My log is:
$ ./converter.py
Starting TTN Converter
Connecting to TTN broker: eu1.cloud.thethings.network:1883
Username: 7D1903CBD0BBC269ACEE1DA1DBCD1995@ttn
Password: NNSXS.xxxx
Subscribe topic: v3/7D1903CBD0BBC269ACEE1DA1DBCD1995@ttn/devices/+/up
Connected to TTN with result code 5
Failed to connect to TTN, return code 5
Thank you very much.
JPT
