I want to create a device in TTN, but I only have the possibility to create devices as OTAA.
So I found a workaround.
I created a device as OTAA, and go the the settings a changed it to ABP and put in the Session Key and Application key, but cannot change the device Address ??
I know that, and we are also moving to OTAA, but I just need my current devices in test in TTN in a pilot,
Our devices cannot just be changed to OTAA, We need to produce new, but there is a quite long lead time on components at the momentsā¦
One reason would be because a lot of people are arguing to keep gateways on V2, and V2->V3 forwarding is only implemented for OTAA devices, not for ABP ones, because it is triggered based on the device address pool allocated for issue by TTN v3 under OTAA, not the arbitrary device addresses an ABP device may have.
But yes, if one controls a gateway which can be pointed at V3, then it would make sense to do the testing there.
Thatās a misunderstanding. Packets with V3 ABP addresses are forwarded from V2.
It is questionable whether arbitrary ABP addresses should be used on TTN anyway. Addresses assigned to other providers might be routed to those providers at some point in time. Only addresses in the TTN range and those starting with 00 and 01 are āsafeā for use on TTN. And for the later category you are right, those will not be forwarded from V2 gateways.
