Install iotagent-LoRaWAN using docker
Provisioning a device with attribute: temperature,
Now I want to check the flow is working correctly by sending the temperature value.
But I donât have the real device/sensor. I want to send dummy payload from iotagent LoRaWAN to context broker- orion through the things network. So, is there any API supported or any other method by which it can be done?
Please guide me how I can send payload without real sensors/device?
Go to the console at http://console.cloud.thethings.network/
Then under Applications â (your application) â End devices â (your end device) under tab âMessagingâ you can simulate an uplink. You can enter a port and a payload (bytes as hex).
You will need to know what the raw payload looks like, we cannot really help you with that.
This assumes of course that you have already defined an application and an end device.
The data you send using this way will appear on the MQTT stream. There will be no gateway info in the uplink message, no physical parameters (spreading factor, SNR, RSSI), etc, because it is a simulated message.
I have followed these steps but it was not working. I have used payload (bytes as hex) and port in uplink. it shows uplink message simulate but there is no change reflect in value.
Yes, weâve told you how to do that, youâve gone to the right place, youâve apparently tried with a proper port number (as 4061 is way out of range). Please answer the questions I wrote above.
I am able to send data from LoRaWAN to orion (NORTHBOUND TRAFFIC) through TTN.
Is there is any method or API through which we can send data from orion to LoRaWAN ( SOUTHBOUND TRAFFIC)?
Yes, to send a downlink message, you can publish (âwriteâ) a JSON payload to a specific MQTT topic.
In the console you can send a downlink command, similar to how you can simulate an uplink command.
Sorry I donât know exactly what the MQTT topic looks like, I have only done this with the TTN v2 stack. I guess just replace the â/up/â part of the topic with â/down/â. You will also need to connect to the MQTT server with an API key that allows publishing to the down-topic.
I have send the data from MQTT using the command:
mosquitto_pub -h eu.thethings.network -t âanjaliapplication***/devices/anjalidevice1234/downâ -u âanjaliapplication1234â -P âttn-account-v2.********â -m â{âpayload_fieldsâ:{âtemperature_1â:11.1}}â
The data is send successfully and this showing on TTN console.
I need to confirm the data is going through Orion ContextBroker.
Can you please describe the flow of data in downlink So that I can confirm my query.
That may well bypass the Orion software as the MQTT downlink request goes straight in to the Network server. I think you need to ask the people who make the software, I am not familiar with it, just giving hints on ways to investigate.
