My Kerlink GW was updated to the latest version 3.3, and i decided to use TTN Packet Forwarder for Kerlink IoT Station. I have no problems with configuration, but I get an error message when I start packet-forwarder.
Can anybody help?
[root@Wirnet_080EXXXX ttn-packet-forwarder]# ./packet-forwarder start
INFO Packet Forwarder for LoRa Gateway HALVersionInfo=Version: 4.0.0; Options: native;
ERROR Failed to find gateway specified as gateway ID AuthServer=https://account.thethingsnetwork.org GatewayID=comet_electronics_gateway error=Get https://account.thethingsnetwork.org/api/v2/gateways/comet_electronics_gateway: dial tcp 104.40.216.89:443: getsockopt: connection timed out
FATAL Couldn’t read configuration error=Get https://account.thethingsnetwork.org/api/v2/gateways/comet_electronics_gateway: dial tcp 104.40.216.89:443: getsockopt: connection timed out
Thanks for the quick reply!
Тhe same GW was registered and worked under the name eui-0000024b080e030a using semtech packet forwarder. After the update I decided to switch to TTN packet forwarder. Because I was getting the same error from the top post, I decided to remove the old registration and make a new one - comet_electronics_gateway.
Unfortunately even after that I can not register the GW.
On your question - the new GW is registered and the GW key is taken from GATEWAY OVERVIEW page
Hi everyone,
I am trying to log into my Kirlink gateway through the web interface 169.254.0.1 and local ethernet through ssh but i get the message “refused to connect”. Can anyone help?
