Apologies for the confusion, that was not a successful TTIG join, that was just the traffic getting picked up from the successful join with the Conduit. Included it to illustrate that both are on the same channel plan. The TTIG and Conduit are in close proximity to each other.
OK, and for the other questions …
I can try and create an ABP device on V3, but this will be my first dabble into this territory. Will definitely try this as I can then retain device for troubleshooting in the future.
My understanding is that we can no longer register devices on V2. I have a few hundred V2 devices but they are on the EU868 channel plan operating in South Africa.
I “borrowed” the Conduit from our production department so I am hesitant to configure it to TTI. I have placed an urgent order for another TTIG.
OK then, my bad.
Do you have a device on ABP on v2?
Do you have a device on OTAA on v2?
I type pointers & suggestions on here at speed, I get paid to type detailed & exhaustive test & debugging plans. As I suggested above, read around the topic. don’t look for someone with your exact same situation, if TTS was exhibiting system wide problems I’d be moderating half-a-dozen topics about the same thing.
I believe the issue is not system wide but it is only affecting V3 devices that are trying to join via au1.cloud.thethings.network since Friday. Those that have existing sessions are currently not affected.
Currently no ABP devices, all V2 devices are OTAA but on EU868 channel plan.
Ah, and this is the first time I’ve entered this transition “Twigglet Zone” where we need a device on v2 but can’t register it due to the read-only situation.
As I understand it, it’s establishing if downlinks of any variety can be sent from TTS on AU1 using AU915 FSB2 via a v2 gateway.
So hopefully you can create an ABP device on TTS to give that a try. You may need to enter the different channel frequencies so TTS doesn’t try to use something that the device doesn’t know about - but they can be edited in after the fact, so you could travel hopeful and just bang in an ABP device - you’ve got an oven ready DevAddr in your PDF.
Maybe the grownups @kersing or @Jeff-UK can weigh in with suggestions?
I’m on the ABP V3 AU915 route and will provide feedback asap.
The screenshots below refer. Have registered a new V3 node with ABP and the uplinks are received 100%, It would appear that the downlinks are not forwarded. The downlink scheduled at 14:52:07 on the Live Data preview screen for the node does not appear on the V2 console gateway traffic log. Are all downlinks not getting forwarded?
No idea, I’m on the other side of the planet with no kit that covers that frequency range.
But I’ve gone in the RF shielded cellar where I keep naughty forum members locked up and tried a v3 OTAA join & downlink using a v2 gateway and it’s working for EU868. Checked the meta-data and only Packet Forwarder entries.
This has highlighted one of those bits of info that I’d not recalled - the v2 console doesn’t show Join Accepts or Downlinks.
So just incase, can you put a serial log on a device to see what it thinks is happening, ie, does show any evidence of a Join Accept? And what is the device, just incase it’s one that needs particular version settings for LW.
I’m almost 100% certain downlinks are not getting forwarded as the ADR is not kicking in. At a RSSI of -48 and a SNR of 11.75 the data rate should speed up to SF8BW125 quite quickly. The live data for the ABP node (verbose mode) is enqueuing ADR requests to switch to SF7BW125 and these are not getting actioned by the node.
"name": "ns.mac.link_adr.request",
"time": "2021-07-04T15:04:13.246163961Z",
"identifiers": [
"device_ids": {
"device_id": "ausabp-37-37-33-31-78-37-7c-03",
"application_ids": {
"application_id": "ausv3-au915-c8-monitor"
"device_ids": {
"dev_eui": "3737333178377C03",
"dev_addr": "260D88C9"
"data": {
"@type": "type.googleapis.com/ttn.lorawan.v3.MACCommand.LinkADRReq",
"data_rate_index": 5,
"tx_power_index": 2,
"channel_mask": [
false,
false,
false,
false,
false,
false,
false,
false,
true,
true,
true,
true,
true,
true,
true,
true
"nb_trans": 1
"correlation_ids": [
"ns:downlink:01F9S0RSNWYTA4HRDZYCCRJMWT",
"ns:uplink:01F9S0RS8EMFREC4C6CH77HBVS",
"pba:conn:up:01F993M51D8FDK8N6X7W380RXY",
"pba:uplink:01F9S0RS6WN0SHR44NAW0ZTJMR",
"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01F9S0RS8EFY2AWPGZYVYZFR6W"
"origin": "ip-10-102-12-39.ap-southeast-2.compute.internal",
"context": {
"tenant-id": "CgN0dG4="
"visibility": {
"rights": [
"RIGHT_APPLICATION_TRAFFIC_READ",
"unique_id": "01F9S0RSNY0A0EKNNWGYHR85VS"
@SteveLeigh-AUS we had a configuration issue since Thursday. We have resolved that and we will do some additional operational maintenance tomorrow (July 6). Please try again and post the results here.
Hi @johan unfortunately no change in behavior - downlinks still not received. I will retest after your scheduled maintenance tomorrow (July 6), what is your anticipated end time of the scheduled maintenance? Thanks.
Hi Johan, I am joining v3 devices on v2 gateways via au1 this morning. ie back to how it was before Friday.
@SteveLeigh-AUS Hi Steve, thanks so much for all your work and excellent documentation on this issue. Hope you have some success today mate!
Great to hear, thanks for letting me know!
Hi Johan, re " we had a configuration issue since Thursday." I was watching the TTN staus page closely but didnt see any posting regarding the configuration issue you were working on during the outage. Is that status page meant to record these type of outages, or if not where is the best place to stay aware of sytem wide issues being worked on? @Maj and @descartes also seemed to be unaware there was an outage. Rgds Nick
No one was aware there was an outage because @SteveLeigh-AUS & myself were figuring out the details. At the time two, possibly three, individuals had reported a problem so not identifiable as an outage as such which I’d define as being system wide (to a region at the least) impacting all users in a clearly identifiable way. Once we’d concluded we’d exhausted all reasonable tests it was escalated to ops.
It is a curious situation - a sort of Heisenberg / Schrödinger moment when you cross the threshold of investigation to conclude that there is an issue - in this instance we could only come to a Holmesian conclusion that in the absence of evidence, the only logical explanation was that there was an issue. My namesake would no doubt be pleased with this kind of zen of debugging, I think there is an issue, therefore there might be. As opposed to “it’s not working so it must be the servers”.
I’ll leave @johan to go in to the details of when an issue becomes an outage and the circumstances that trigger a post to the status page.
PS, Whilst you were watching the status page, did you see the Data Storage retrieve issue on v2 that was system wide - it was fixed whilst I was still providing the details …
@descartes Hi Nick, mate you managed to put a lot of big words in your response and I’m not really smart enough to understand them all. But even I could see instantly that you were making the classic debugging mistake of “assuming the most convenient option first”. We all do it, all the time. If theres a fancy word for it let me know, and I’ll be sure to use it. ("McClouding the issue"maybe?)
Thats my narky little jab done. Aside from that, I do appreciate your help and we did get to a solution within a few days. Actually I took Johan’s response to mean he’d been aware of and working on the configuration issue since Thursday. Reading more closely I may have got that wrong there, so apologies for my misunderstanding.
