JSON import of devices errors
Hi guy´s
We earlier used a EUI/onboarding program to produce import .json files for our devices like below
{“ids”:{“device_id”:“a84041d4d18332e6”,“dev_eui”:“A84041D4D18332E6”,“join_eui”:“5a656e7a725a3635”},“name”:“LST25375462”,“description”:“”,“lorawan_version”:“MAC_V1_0_2”,“lorawan_phy_version”:“PHY_V1_0_2_REV_B”,“frequency_plan_id”:“EU_863_870_TTN”,“supports_join”:true,“root_keys”:{“app_key”:{“key”:“842FF7A7D8DA74838DE3FADFC431F1C2”}}},{“ids”:{“device_id”:“a8404178618332e7”,“dev_eui”:“A8404178618332E7”,“join_eui”:“5a656e7a725a3635”},“name”:“LST25375463”,“description”:“”,“lorawan_version”:“MAC_V1_0_2”,“lorawan_phy_version”:“PHY_V1_0_2_REV_B”,“frequency_plan_id”:“EU_863_870_TTN”,“supports_join”:true,“root_keys”:{“app_key”:{“key”:“37EAD38FDF217EA2F1B7B537EE87A88E”}}},{“ids”:{“device_id”:“a84041e7f18332e8”,“dev_eui”:“A84041E7F18332E8”,“join_eui”:“5a656e7a725a3635”},“name”:“LST25375464”,“description”:“”,“lorawan_version”:“MAC_V1_0_2”,“lorawan_phy_version”:“PHY_V1_0_2_REV_B”,“frequency_plan_id”:“EU_863_870_TTN”,“supports_join”:true,“root_keys”:{“app_key”:{“key”:“52D472C164E2587126D11AC6BFFADDDA”}}}
When trying to import with this, we get an error saying
There was an error and the operation could not be completed
An unknown error occurred. Please try again later.
“field_mask”: {
“paths”: [
“ids.dev_eui”,
“ids.device_id”,
“lorawan_phy_version”,
“name”,
“root_keys.app_key.key”,
“frequency_plan_id”,
“lorawan_version”,
“supports_join”,
“ids.join_eui”
undefined
Whats the change anyone?
Best Regards
/ Anders
Bit hard to tell due to the lack of formatting, you can edit and use the </> tool, but at first glance you don’t appear to be sending an array of devices, more a CSV of JSON snippets.
I’d not regard this as a new feature, more an error at either or both ends so I’ve adjusted the title accordingly!
Hi, and thank you, we re-wrote it to look like this instead - worked fine
Example:
{“ids”: {“device_id”: “eui-a84041d9fc5c712f”, “dev_eui”: “A84041D9FC5C712F”, “join_eui”: “A840410000000101”}, “name”: “eui-LST36058287”, “description”: “LoraST3.0 sensor”, “lorawan_version”: “MAC_V1_0_3”, “lorawan_phy_version”: “PHY_V1_0_3_REV_A”, “frequency_plan_id”: “EU_863_870_TTN”, “supports_join”: true, “root_keys”: {“app_key”: {“key”: “FA56412C54DC34E53EBAD852BD6E0EA9”}}}
{“ids”: {“device_id”: “eui-a8404174bb5c7130”, “dev_eui”: “A8404174BB5C7130”, “join_eui”: “A840410000000101”}, “name”: “eui-LST36058288”, “description”: “LoraST3.0 sensor”, “lorawan_version”: “MAC_V1_0_3”, “lorawan_phy_version”: “PHY_V1_0_3_REV_A”, “frequency_plan_id”: “EU_863_870_TTN”, “supports_join”: true, “root_keys”: {“app_key”: {“key”: “209DBCC4B2E842E00F6C0B704CD8BF56”}}}
