What makes you think that - because that will give us a clue of what you might need to do.
I thought it was connected because i changed the server addresse In lorafwd.toml under gwmp the node to “eu1.cloud.thethings.network” and the port for uplink and downlink to 1700. As described in the documentation. What else do I have to change ?
So you’ve not seen any hard evidence that you are connected - nothing in the logs of the gateway or on the v3 console?
No, i have not. In the Overview of the things stack is the gateway still disconnected.
Have you entered the serv_gw_key correctly ?
“serv_gw_key”: “NNSXS.blah.blah”
This should match your Gateway Link API key that you generated
Just a thought.
Do you know where i can enter this key (in which file)? sorry i am not a professional.
On my system I added the key value to local_conf.json - the file is in the same folder that you downloaded global_conf.json
I cant find any file like local_conf.json
ok, the serv_gw_key value can go into global_conf.json if you don’t have a local_conf.json
But I think the idea is that the local_conf will override the values that have been created in global_conf.json (assuming you clicked the download global_conf button).
Normally you would put the personal stuff in there (like “contact_email” : “value”) and perhaps key values related to gps (assuming you have gps enable to provide better timing).
It is also important in the global_conf.json to adjust the “antenna_gain” to match the published dBi gain of your antenna (allowing for a few db loss in the cabling, depending on the length and quality of coax between antenna and gateway).
Sorry I am a little confused. I have now downloaded the globa_conf.json as here:
https://www.thethingsindustries.com/docs/gateways/semtech-udp-packet-forwarder/
Now I have to put in the file /etc/default/lorad at CONFIFURATION_FILE the globa_conf.json I just downloaded right ?
P.S. when I downloaded again, only globa_conf.json was downloaded in the folder I just had open. But not local_conf.json
You aren’t going to get a local_conf.json file from a button that says global_conf.json.
But you don’t need one as long as you remember that you have edited the global_conf.json by putting in the serv_gw_key with the API key to suit and restart the gateway.
Is it important in which line I put the serv_gw_key here?
Next to gateway_ID?
Pick one and try it, if that doesn’t work, try the other, if that doesn’t work, try both.
Please do not post pictures of things that can be copied & pasted.
unfortunately still does not work.
So I have done:
- downloaded global_conf.json
- added “serv_gw_key”: “API Key” to global_con.json (in all three combinations)
- put global_conf.json into /etc/default/lorad
- enabled the packet forwarder in /etc/default/lorafwd
- edited lorafwd.toml (node = eu1.cloud.thethings.network and for down- and uplink port 1700)
did i miss something or made a mistake ?
When you say “API Key”, you have actually put an API key in there? The start NNSXS.
Did you power cycle the whole gateway each time?
Yes, i copied the API from the consle. And yes, I rebooted the gateway a few times.
Can you copy & paste the global_conf.json section with removal of some of the letters in the API Keys, just so another set of eye balls can have a look see.
"gateway_conf": {
"gateway_ID": "7076FF005605031F",
"serv_gw_key": "NNSXS.VNN...PXJQA",
"server_address": "eu1.cloud.thethings.network",
"serv_port_up": 1700,
"serv_port_down": 1700,
"servers": [
"serv_gw_key": "NNSXS.VNNPXA...PXJQA",
"serv_enabled": true
In the TTN console ‘General settings’ for the gateway, is ‘Require authenticated connection’ set to ‘Enabled’? If so, remove the check mark and save and wait a couple of minutes. Forget about the serv_gw_key, it is not being used by the software that uses UDP on port 1700.
