Sorry English is not my first languange so
What i’ve done is, changing the lorawan protocol and using Semtech UDP and my gateway is working now, i’ve tried different payload and all still my gateway wont receive it and uplink it. I’ll attach log below
I use MCCI Arduino LMIC version 4.1.1 from github
Here’s a log snippet below
Mon Mar 11 15:59:10 2024 daemon.info fwd[15575]: #[server] Semtech status report ready.
Mon Mar 11 15:59:10 2024 daemon.info fwd[15575]: DEBUG~ [server] semtech_push_up fetch 0 pachages.
Mon Mar 11 15:59:10 2024 daemon.info fwd[15575]: PKTUP~ [server] JSON: {"stat":{"time":"2024-03-11 08:59:10 UTC","lati":-7.79883,"long":110.35416,"alti":6,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0,"pfrm":"SX1301","mail":"dragino-1cff3c@dragino.com","desc":"Dragino LoRaWAN Gateway"}}
Mon Mar 11 15:59:10 2024 daemon.info fwd[15575]: ################### [server] End of reporting #########################
Mon Mar 11 15:59:13 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 174 ms
Mon Mar 11 15:59:14 2024 user.notice iot_keep_alive: Internet Access OK: via wlan0-2
Mon Mar 11 15:59:14 2024 user.notice iot_keep_alive: use WAN or WiFi for internet access now
Mon Mar 11 15:59:18 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 150 ms
Mon Mar 11 15:59:23 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 161 ms
Mon Mar 11 15:59:28 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 163 ms
Mon Mar 11 15:59:33 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 180 ms
Mon Mar 11 15:59:34 2024 user.notice iot_keep_alive: Internet Access OK: via wlan0-2
Mon Mar 11 15:59:34 2024 user.notice iot_keep_alive: use WAN or WiFi for internet access now
Mon Mar 11 15:59:38 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 163 ms
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]:
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ################[PKT_SERV] no report of this service ###############
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: #######################################################
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ##### [2024-03-11 08:59:40 UTC] server #####
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ### [UPSTREAM] ###
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # RF packets received by concentrator: 0
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # RF packets forwarded: 0 (0 bytes)
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # PUSH_DATA datagrams sent: 14 (238 bytes)
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # PUSH_DATA acknowledged: 0.00%
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ### [DOWNSTREAM] ###
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # PULL_DATA sent: 89 (100.00% acknowledged)
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # RF packets sent to concentrator: 0 (0 bytes)
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # TX errors: 0
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ### [SX1301 status] ###
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # SX130X counter (INST): 0
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # SX130X counter (PPS): 422884498
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # Concentrator temperature: 0 C #
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ### [BEACON] ###
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # Packets queued: 0
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # Packets sent so far: 0
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # Packets rejected: 0
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ### [JIT] ###
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ----------------
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ### [GPS] ###
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: # GPS *FAKE* coordinates: latitude -7.79883, longitude 110.35416, altitude 6 m
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: #[server] Semtech status report ready.
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: DEBUG~ [server] semtech_push_up fetch 0 pachages.
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: PKTUP~ [server] JSON: {"stat":{"time":"2024-03-11 08:59:40 UTC","lati":-7.79883,"long":110.35416,"alti":6,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0,"pfrm":"SX1301","mail":"dragino-1cff3c@dragino.com","desc":"Dragino LoRaWAN Gateway"}}
Mon Mar 11 15:59:40 2024 daemon.info fwd[15575]: ################### [server] End of reporting #########################
Mon Mar 11 15:59:43 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 148 ms
Mon Mar 11 15:59:48 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 147 ms
Mon Mar 11 15:59:54 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 151 ms
Mon Mar 11 15:59:54 2024 user.notice iot_keep_alive: Internet Access OK: via wlan0-2
Mon Mar 11 15:59:54 2024 user.notice iot_keep_alive: use WAN or WiFi for internet access now
Mon Mar 11 15:59:59 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 151 ms
Mon Mar 11 16:00:00 2024 cron.info crond[1572]: USER root pid 23873 cmd /etc/init.d/DR_enable_rssh.sh start
Mon Mar 11 16:00:04 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 142 ms
Mon Mar 11 16:00:09 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 142 ms
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]:
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ################[PKT_SERV] no report of this service ###############
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: #######################################################
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ##### [2024-03-11 09:00:10 UTC] server #####
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ### [UPSTREAM] ###
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # RF packets received by concentrator: 0
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # RF packets forwarded: 0 (0 bytes)
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # PUSH_DATA datagrams sent: 15 (238 bytes)
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # PUSH_DATA acknowledged: 0.00%
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ### [DOWNSTREAM] ###
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # PULL_DATA sent: 95 (100.00% acknowledged)
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # RF packets sent to concentrator: 0 (0 bytes)
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # TX errors: 0
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ### [SX1301 status] ###
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # SX130X counter (INST): 0
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # SX130X counter (PPS): 482885501
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # Concentrator temperature: 0 C #
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ### [BEACON] ###
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # Packets queued: 0
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # Packets sent so far: 0
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # Packets rejected: 0
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ### [JIT] ###
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ----------------
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ### [GPS] ###
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: # GPS *FAKE* coordinates: latitude -7.79883, longitude 110.35416, altitude 6 m
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: #[server] Semtech status report ready.
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: DEBUG~ [server] semtech_push_up fetch 0 pachages.
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: PKTUP~ [server] JSON: {"stat":{"time":"2024-03-11 09:00:10 UTC","lati":-7.79883,"long":110.35416,"alti":6,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0,"pfrm":"SX1301","mail":"dragino-1cff3c@dragino.com","desc":"Dragino LoRaWAN Gateway"}}
Mon Mar 11 16:00:10 2024 daemon.info fwd[15575]: ################### [server] End of reporting #########################
Mon Mar 11 16:00:13 2024 user.notice iot_keep_alive: Internet Access OK: via wlan0-2
Mon Mar 11 16:00:13 2024 user.notice iot_keep_alive: use WAN or WiFi for internet access now
Mon Mar 11 16:00:14 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 153 ms
Mon Mar 11 16:00:19 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 152 ms
Mon Mar 11 16:00:23 2024 daemon.info fwd[15575]: DEBUG~ [main-up] Size of package list is 6
Mon Mar 11 16:00:23 2024 daemon.info fwd[15575]: DEBUG~ [PKT_SERV] pkt_push_up fetch 1 pachages.
Mon Mar 11 16:00:23 2024 daemon.info fwd[15575]: DEBUG~ [server] semtech_push_up fetch 1 pachages.
Mon Mar 11 16:00:24 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 155 ms
Mon Mar 11 16:00:29 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 174 ms
Mon Mar 11 16:00:33 2024 user.notice iot_keep_alive: Internet Access OK: via wlan0-2
Mon Mar 11 16:00:33 2024 user.notice iot_keep_alive: use WAN or WiFi for internet access now
Mon Mar 11 16:00:34 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 142 ms
Mon Mar 11 16:00:39 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 182 ms
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]:
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ################[PKT_SERV] no report of this service ###############
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: #######################################################
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ##### [2024-03-11 09:00:40 UTC] server #####
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ### [UPSTREAM] ###
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # RF packets received by concentrator: 1
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # RF packets forwarded: 0 (0 bytes)
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # PUSH_DATA datagrams sent: 16 (238 bytes)
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # PUSH_DATA acknowledged: 0.00%
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ### [DOWNSTREAM] ###
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # PULL_DATA sent: 101 (100.00% acknowledged)
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # RF packets sent to concentrator: 0 (0 bytes)
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # TX errors: 0
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ### [SX1301 status] ###
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # SX130X counter (INST): 0
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # SX130X counter (PPS): 482885501
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # Concentrator temperature: 0 C #
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ### [BEACON] ###
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # Packets queued: 0
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # Packets sent so far: 0
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # Packets rejected: 0
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ### [JIT] ###
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ----------------
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ### [GPS] ###
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: # GPS *FAKE* coordinates: latitude -7.79883, longitude 110.35416, altitude 6 m
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: #[server] Semtech status report ready.
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: DEBUG~ [server] semtech_push_up fetch 0 pachages.
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: PKTUP~ [server] JSON: {"stat":{"time":"2024-03-11 09:00:40 UTC","lati":-7.79883,"long":110.35416,"alti":6,"rxnb":1,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0,"pfrm":"SX1301","mail":"dragino-1cff3c@dragino.com","desc":"Dragino LoRaWAN Gateway"}}
Mon Mar 11 16:00:40 2024 daemon.info fwd[15575]: ################### [server] End of reporting #########################
Mon Mar 11 16:00:44 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 149 ms
Mon Mar 11 16:00:49 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 160 ms
Mon Mar 11 16:00:52 2024 user.notice iot_keep_alive: Internet Access OK: via wlan0-2
Mon Mar 11 16:00:52 2024 user.notice iot_keep_alive: use WAN or WiFi for internet access now
Mon Mar 11 16:00:55 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 148 ms
Mon Mar 11 16:00:59 2024 daemon.info fwd[15575]: DEBUG~ [main-up] Size of package list is 7
Mon Mar 11 16:00:59 2024 daemon.info fwd[15575]: DEBUG~ [PKT_SERV] pkt_push_up fetch 1 pachages.
Mon Mar 11 16:00:59 2024 daemon.info fwd[15575]: DEBUG~ [server] semtech_push_up fetch 1 pachages.
Mon Mar 11 16:01:00 2024 daemon.info fwd[15575]: INFO~ [server-down] PULL_ACK received in 179 ms
Mon Mar 11 16:01:00 2024 daemon.err uhttpd[1656]: killall: logread: no process killed
From what ive seen i think its still because of CRC_fail. Is there any solution ?
