Link between registered devices and gateways
I am working on following flow,
Sensor-1 ----> Gateway 1 ----> TTN ----> Thingsboard
Sensor-2 ---->
As we understand that data flows from Sensor-1 and 2 to TTN through Gateway-1 and to Thingsboard.
While registering the devices in TTN, we create an application and adds the devices. There is a separate option for registering the gateway.
I am not understanding what is the link between devices and gateways. How does sensor-1 sends data through gateway-1? Or how can we restrict that sensor-1 sends data only through gateway-1?
Thank you.
that is not possible… all LoRaWAN gateways within range of the node will receive and forward the data to the TTN backend.
pls see https://www.thethingsnetwork.org/docs/
Though in the upcoming V3, a gateway could filter:
But that’s kind of the other way around, and probably far beyond what’s being asked.
yes indeed my idea too :wink:
