I’m trying to figure the LoRa downlink hexadecimal encoding but struggling to implement it. I understand how to convert hex (15 base) to decimal (10 base) and binary (2 base) but i don’t get how the hex maps to the settings, its a little confusing hows it been explained in the instructions here . Could somebody help me?
For example, I purchased a Kona Home Sensor / Smart Room Sensor (T0004895). I’ve hooked it up to gas meter and its transmitting every time the meter impulses so i know its working which is good. However, i would like it to transmit a count of the pulses every hour to save battery power. what is the hex i need to write for this?
I’ve logged into the things network. In the instructions here it said to enter “0x AE 00 00 AF 02”. I entered the following “AE 00 00 AF 02” (The 0x just i understand now tells us that it is a hex). In the instructions it says this is what the command is.
“”"Disable the Digital Input event-driven transmission, but report the number of times the Digital Input has been triggered whenever a report is inquired (i.e. in the case of periodic reporting):
Smart Room Sensor TRM T0006338_TRM Version 1.0
TEKTELIC Communications Inc. Confidential Page 26 of 44
o DL payload: { 0x AE 00 00 AF 02 }
Count Threshold set to 0 (zero)
Value to Tx set to “Digital Input count” “”"
