Moderator, if any aspect of this post is inappropriate, then please delete it. Is there any reason a LoRa beginner should not attempt to combine the below three items towards uploading data to TTN?
Thank you!
Thank you!
Yes - the sensor is LoRa only - it only supports the LoRa RF Phy layer and is not LoRaWAN (As espected by the GW) which requires the implementation of the relevant prootocols and specs/rules/responses - you need a LoRaWAN enabled sensor…these types of soil sensors can be bought where they are just the sensor and the output connected to a LoRaWAN module as another option.
Apart from the issue of picking a LoRa only device …
Yes, because combine is trying too hard. Just do one step at a time.
Get your internet working - ![]()
Get your gateway online - ![]()
Register & turn on your LoRaWAN device -
Gateways use WiFi. If it’s normal standard wifi, then the gateway will work. I can’t comment on the router, but the gateway choice is good.
LoraWAN devices use LoRaWAN gateways. 99.999% of the time they work together as there is a standard, like WiFi for communications.
But as I said, if you try to set them all up at once, you may end up with a mess. Just do one thing at a time.
Dear Jeff and Nick, Thank you for commenting about the LoRa only device! I will study further. Best, Andrei near San Francisco.
Thanks for the advice. I am in a similar situation. I ordered 2 Makerfabs Lora soil moisture sensor that I was planning using with my Dragino LPS8N Gateway. I am trying to cancel this PO.
