OK, Thomas…, the telex printing and bells ringing made for a very inspiring presentation. Well done!
Now rigging a LoRa receiver for 162MHz with some parts I have on the desk. A hopeRF module, Raspberry PI and an antenne for receiving aircraft transmissions. Obviously the antenna goes on the roof.
So my setup did not catch anything. I had to step out of the office during the pass of the satellite, you know work…
So I set the LoRa receiver to continuously receive SF12 messages @162MHz. Not taking into account doppler shift or anything. So I might be listening at the wrong frequency… Nothing received during this pass. But that makes sense because I just saw Thomas’ post saying it is transmitting on SF11.
Oh well, will try with a more elaborate setup and the correct SF during the next pass of the satellite…
Center frequency: 161.862500Mhz
Bandwidth: 125kHz
Sync word: 0x12
Spreading: SF11
Low Data Rate Optimize: on
Header: on
Coding Rate: 4/8 (this is in the header, no need to configure)
IQ inverted (this is default for rx, don’t change anything)
Yes I set the center frequency to 161.862500MHz too now.
Maybe I have time to quickly put together a cross yagi antenna @ 162MHz for tonight. Don’t know, lets see what bits and pieces I have in the shed for that.
Nope. We just had another pass of Norsat 2. I installed ‘gpredict’ and configured ‘Norsat 2’ to actually see when the satellite is passing overhead. But so far my receiver is not picking up the LoRa signal from space.
When will the transmissions stop? As soon as the TTN conference is over? I like the challenge, but my setup needs some more tweaking I am afraid.
N2YO is showing passes at 22:41, which will be low in the sky for London/Amsterdam, and 00:17 over Ireland, which is technically tomorrow. Where are you getting 13:35 from?
I will post the receiver code at some point, it can be useful to have a simple receiver that can easily configured for different LoRa and frequency settings and can log packets as ASCII and hex to terminal and SD card. The code should run on most Arduino platforms.
We now know that LoRa can be received from low earth orbit with very simple ground based equipment.
And thanks to Thomas for such an interesting challenge.
I attempted to receive the messages from space. Unfortunately I received nothing with my setup. Probably my antenna setup was too simple. I colocated an aircraft antenna (120 - 140MHz) with the TTN node on the balcony. So wrong frequency and probably also wrong polarization. I did not have time to create a more sophisticated setup. You know… busy busy,…, but it was fun to try!
It would be difficult to come up with a matching challenge for a next TTN event.
