Is this these specifically wrt LoRaWAN or what your doing with it (in terms of the sensing)? Asking as if you need to do a defence of your thesis you will really need to be able to answer questions that demonstrate knowledge of the underlying technology and use cases and so some of that time improving learning should benefit & help you.
if the devices shout at each other noise should not be an issue so that is good. I tried to use STM32 once and it was a night mare. no documentation and the docs I found did nto even work. so alot of time was just spend trying to figure out what works and what doenst. the HAL system sued made everythign wworse and I was fighting against that aswell. esp32 was choosen becuase so far I had great experience with it and as arduino supports it coding at it is easy< enoguh and you actually find workign docs.
RTC is nto that hard, as I can edit the code I can jsut add RTC_DATA_ATTR to the varibales of the libraries.
yeah lora uses shirps and i defined to use sf9 so 512 shirps per symbol. more air time but longer trans mission range. that was still from the time when I expected the gateway would ahve a longer range and not just 100m around the building its at…
I tried wifi in the past wwhich did nor work. alternative is zigbee whixch is better suited for this but sadly its industrial standart and closed source or everythign is behind a paywal, so Lora it is. My mistake was to assume LoRa and LoRaWAN are the same and people jsut dont like to sue the full name, but apparently LoraWAN is somethign ontop of Lora. simiular to how TCP is basicly ontop the IP protokoll.
You don’t mention what gateway is used. I have seen problems with the packet forwarder on the gateway discarding packets where the first 4 bytes (after the header byte) are all zero. Normally not a problem, but a join request with an AppEUI of all zero will have the first 4 bytes all zero. There is nothing special about the AppEUI; you can set it to any value you like. If you chose 01-01-01-01-01-01-01-01, you will guarantee that the AppEUI won’t trigger the discard.
The mentioned delays are because of duty-cycle limitations. The LMIC is not fully compliant in the backoff calculations from the LoRaWAN spec, but it does comply with regulatory limitations (less strict than join backoff instructions in 1.0.3).
It is one of the forwarders for the MultiTech. We observed the problem and narrowed it down to the packet forwarder, and then went looking. Jeff Honig of TTN Ithaca has the code on his machine; I looked at it with him a week or two ago; today I’m traveling and can’t check as there are several repos that are pulled together.
If memory serves, we found code that looks for packets with 4 bytes of zero; comments say it’s to reject spurious packets from USB-based LoRa cards. We concluded the code meant to check for a devaddr of zero, but it doesn’t use the packet type from the MHDR; IMO it should not do this unless the packet type is unconfirmed uplink or confirmed uplink. (If you want to find the code yourself, look for four byte-by-byte compares of packet[] to zero, for each of the bytes after the MHDR.) I’ve sent a query to Jeff, will repost after I get word back.
Yes, cause has been found but I need some more testing before I release the fixed sources.
If you take a moment of two to check GitHub you will find I’ve found the same some
September 14th, the code was added to drop rogue packets created by USB connected concentrators on (yes you guessed it) MultiTech hardware. It didn’t cause issues on V2 because back then everyone was using a real AppEUI. These days it seems there is no need for them so all zeros is recommended triggering the issue in joins.
If you wait a couple of days I intend to push a fix.
So a round of field upgrades in order?! Perhaps rather than all zeroes as recomendation we change to 010101… as above if not using a ‘real’ ID (or the other trick of duplicate Dev EUI?)
I guess crossing messages. We have about 100 MultiTechs deployed, and first noticed this issue as soon as we upgraded to V3, but we didn’t get a chance to check the code until more recently. In any case, we have remote management software so we can push updates.
I have no objection to checking mote address for zero; but those four bytes are only the mote address if MHDR says that the packet is an unconfirmed or confirmed uplink.
For those who can’t push updates, an AppEUI of 0x1 is sufficient as long as the user doesn’t hit endian issues (and that’s what we normally use at TTN NY). Using 0x01010101010101 avoids endian issues.
those effects honestly sound super interesting, I wish I had courses about these topics and more advanced electronics
even if I edit the library itself?
chances are low it will arrive on time alias if I order now it will take 3 weeks at best until it arrives.
that is a good idea I will try that. if it still triggers a MIC Mismatch, even when I am far away so I dont overload the circuit, what else can I try ? (besides from trying to switch btween big and little endien for the AppKey) ?
Thanks everone! I changed JoinEUI to 2222… DevEUI to 44444… AppKey to 666… and it worked. Which means software and hardware can work! (this was ma greatest fear) now I need to find actual save value which are somehwat secure and find out what was the issue. ( I als changed the transmission window back to 60 seconds )
It has been a while since I worked on that issue, however what I recall is that the data I was getting was mostly random with just a few bytes consistently providing the same values indicating it wasn’t a valid uplink. I need to check again with MultiTech hardware to find the other ‘stable’ bytes to see if I can refine the valid uplink check.
This will take some time as I’m rebuilding my Linux development system after the previous system died and I don’t have the toolchains available yet.
The fix for other platforms will be available soon. (Basically just removing the check as it isn’t needed)
So, to clarify, you changed the JoinEUI as suggested 3 days ago in post 9 and here we are on post 40 and now you have it working. What does this suggest to you?
Your DevEUI is not a legal one to use. Please use one generated by the console or a locally administered address. As it happens all 2’s is OK for a JoinEUI
You were told about this 3 days ago on post 9. This is still in breach of FUP - if you don’t start responding to this matter, you may well find that further interest in helping you becomes more & more sporadic.
Please don’t waste your time trying to work out ‘the issue’ - it’s a long way inside the LoRaWAN system - you can get an official DevEUI from the console, you can use all 2’s for the JoinEUI or, from a forum search, use this tool to create a valid EUI that won’t clash with anyone else: Random EUI or Key generator and you can get the console to generate an AppKey.
This is NOT a locally administered address and should not be used or suggested (and it’s not actually 8 bytes either). I know this because I read this post:
I also wrote back then that I could not change the JoinEUI via TTN I needed to make a new device to enter all numbers form scratch. Also as stated only when I am away from home I can actually test changes thats why it takes so long to test stuff.
as states
this value was never used in the first place as stated above.
I used the console to generate random value the first time and it did not work, finding the issue for me is finding out what value actually causes the issue - alias what value can be a actuall good random value and which one cant.
Another question. if I just send LoRa messages constantly is this also against the spec or is that ok? (asking because a random tutorial did that to test out how good some antenna design where and what distance they provided)
If one guy posts a video of crashing himself into a brick wall would you follow that? There is a lot of bad advice and poor info on the net…that is fine in an RF anechoic chamber for characterising an antenna as a test set up but should not be used in the open depending on where in the world…remember the spectrum is a shared resource for all and in most bands and locations where LoRa would be used there are regulatory limits wrt duty cycle, dwell time or what ever with penal/judicial backing - be warned. Also where a short range RF system may only impact a few LORa (its in the name!) will impact many more and further afield if you abuse the airwaves… just saying…
