MQTT add own metadata
Hi all,
I all i have some difficulties with the mqtt as it needs a multiple receivers when using multiple applications. Is it possible to add some extra information (own metadata) in the callback, so i can use a single application?
Did you see Is it possible to define an extra payload fields directly from TTN application different per device like an API Key?
