MQTT Topic TTN
Screenshot (39)
Yes there is a value in the “dev_eui” row.
Then everything would be broken…
You are right… in two years or so I probably don’t know this anymore and would add another device…
But im not sure why this is happening… I meant there is a dev_eui so why is it saying its undefined?
What bugs me is that you getting two separate JSON, one for the “Distance” and “dev_eui” out of the change node, that all should be in the same JSON.
Well, I’m getting them in two because we are making two or am I wrong?
msg.payload and msg.dev_eui.
Copy and past your flow from node-red, then I can look.
Don’t worry Node-red leaves all the keys and passwords out.
        "id": "153ff67d1f2c61b8",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "8e52c3ed8907ee0c",
        "type": "mqtt in",
        "z": "153ff67d1f2c61b8",
        "name": "Füllstand Quelle",
        "topic": "v3/DEVICEID@ttn/devices/+/up",
        "qos": "2",
        "datatype": "json",
        "broker": "0a4f4fef6fee57c6",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 260,
        "y": 260,
        "wires": [
                "059296a9a604036f",
                "1ae3c6d92610a908"
        "id": "059296a9a604036f",
        "type": "change",
        "name": "change node",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.uplink_message.decoded_payload.Distance",
                "tot": "msg"
                "t": "set",
                "p": "dev_eui",
                "pt": "msg",
                "to": "payload.end_device_ids.dev_eui",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 470,
        "y": 260,
        "wires": [
                "08529e03113c98e2",
                "c4aa3711222d1081"
        "id": "08529e03113c98e2",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 990,
        "y": 280,
        "wires": []
        "id": "1ae3c6d92610a908",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 430,
        "y": 180,
        "wires": []
        "id": "c4aa3711222d1081",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "dev_eui",
        "statusVal": "",
        "x": 990,
        "y": 240,
        "wires": []
        "id": "0a4f4fef6fee57c6",
        "type": "mqtt-broker",
        "broker": "eu1.cloud.thethings.network",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
Thats the flow
You have added a few thing that aided in the confusion.
You should rather keep your debug node set to as below.
This way you only get part of the JSON
I have corrected your flow, you will see there is a “Test Json”, if I hade you JSON I could have solved the problem faster.
You should be good now to inject the JSON into the Influx DB node and have the correct data in the DB.
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "type": "mqtt in",
        "qos": "2",
        "datatype": "json",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 220,
        "y": 260,
        "wires": [
                "059296a9a604036f"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "Distance",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "p": "dev_eui",
                "pt": "msg",
                "to": "payload.end_device_ids.device_id",
                "tot": "msg"
                "t": "delete",
                "p": "payload.uplink_message",
                "pt": "msg"
                "t": "delete",
                "p": "payload.correlation_ids",
                "pt": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 510,
        "y": 260,
        "wires": [
                "c4aa3711222d1081"
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 530,
        "y": 360,
        "wires": []
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "targetType": "full",
        "statusVal": "dev_eui",
        "x": 670,
        "y": 260,
        "wires": []
        "id": "60f39d916a35dd8b",
        "type": "inject",
        "name": "Test Json",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{\"topic\":\"v3/compact-tracker-abeeway@ttn/devices/eui-20635f0161000093/up\",\"payload\":{\"end_device_ids\":{\"device_id\":\"eui-dhdfth\",\"application_ids\":{\"application_id\":\"fjdjdy\"},\"dev_eui\":\"hth3\",\"join_eui\":\"hrhxf\",\"dev_addr\":\"hhF\"},\"correlation_ids\":[\"as:up:01FPZ2ZC6PJQE0XQ68ECN239B7\",\"gs:conn:01FNXTS68EYM139F0J53QR5ZK0\",\"gs:up:host:01FNXTS699E4A2H7VSP45SZG62\",\"gs:uplink:01FPZ2ZC04E8WTWP10DHJX97S6\",\"ns:uplink:01FPZ2ZC0568ACBK2MBZQK4148\",\"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FPZ2ZC052XX7N17EDTRCYW6D\",\"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FPZ2ZC6MRZ4WAM86KEJC7J6B\"],\"received_at\":\"2021-12-15T13:02:16.279389076Z\",\"uplink_message\":{\"session_key_id\":\"AX23nQJEOCVpz1fId9ugRw==\",\"f_port\":18,\"f_cnt\":182,\"frm_payload\":\"BSBhigAQAgAAAwIA\",\"decoded_payload\":{\"ack\":0,\"batteryPersentage\":97,\"bleFirmware\":\"bleFwVersion3.2.0\",\"data\":0,\"Distance\":512,\"debug\":{\"length\":12,\"payload\":\"0520618a0010gfhfg030200\",\"port\":18,\"server_time\":\"2021-12-15T13:02:16.283Z\"},\"lastResetCause\":\"lastResetCause: 16\",\"mcuFirmware\":\"fwVersion: 2.0.0\",\"status\":{\"mode\":{\"code\":1,\"description\":\"Motion tracking\"},\"moving\":false,\"on_demand\":false,\"periodic\":false,\"sos\":false,\"tracking\":false},\"temperature\":25.81,\"type\":\"HEARTBEAT\"},\"rx_metadata\":[{\"gateway_ids\":{\"gateway_id\":\"dhdth-mdhdfhfn-01-dbn\",\"eui\":\"3dhdfhdfgh0\"},\"time\":\"2021-12-15T13:02:15.958012Z\",\"timestamp\":534735231,\"rssi\":-109,\"channel_rssi\":-109,\"snr\":1.75,\"location\":{\"latitude\":-505059.885050571,\"longitude\":5050.905081617,\"altitude\":225,\"source\":\"SOURCE_REGISTRY\"},\"uplink_token\":\"CiIKIAoUdGVjaDUtbWFsdmVybi0wMS1kYm4SCDQ2MjgkAFAAEP/S/f4BGgsI2M7njQYQ1+/aICCYsNCFyP3/ASoMCNfO540GEOC06MgD\",\"channel_index\":4}],\"settings\":{\"data_rate\":{\"lora\":{\"bandwidth\":125000,\"spreading_factor\":7}},\"coding_rate\":\"4/5\",\"frequency\":\"867300000\",\"timestamp\":534735231,\"time\":\"2021-12-15T13:02:15.958012Z\"},\"received_at\":\"2021-12-15T13:02:16.069864716Z\",\"consumed_airtime\":\"0.061696s\",\"locations\":{\"frm-payload\":{\"latitude\":-29.8889728,\"longitude\":30.916608,\"source\":\"SOURCE_GPS\"}},\"network_ids\":{\"net_id\":\"000013\",\"tenant_id\":\"ttn\",\"cluster_id\":\"ttn-eu1\"}}},\"qos\":0,\"retain\":false,\"_msgid\":\"d38de075552048d0\"}",
        "payloadType": "json",
        "x": 230,
        "y": 360,
        "wires": [
                "99997bbb40d80fb0"
        "id": "99997bbb40d80fb0",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 360,
        "y": 360,
        "wires": [
                "059296a9a604036f",
                "1ae3c6d92610a908"
        "id": "3f4efbddb8220f44",
        "type": "comment",
        "name": "For Testing",
        "info": "",
        "x": 210,
        "y": 320,
        "wires": []
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
Thank you very much!
I like the solution and I’m very thankful for your very useful tips!
I also like the testing via the inject node. I did not know this trick… I just waited for the next payload from the LoraNode.
Okay first of all you are writing the distance and the deveui into msg.Distance and msg.deveui and then you are deleting everything from the stream we don’t want to save into the DB. Do I understand that correctly?
!The question is obsolete! I’ve found a solution!
Now I have an additional question. Now the “Distance” stands for the distance between an ultrasonic sensor and a water level.
Now I want to have the height of the water. The mathematical solution for this is to subtract"2300" from the measurement and multiply it by “-1”.
I’m pretty sure you would do this with a function node but I’m having trouble taking the msg.Distance and calculate with the number.
There is a “Copy Value” Button.
dwJ9uLCIM0
and past in inject node, press the … and delete what ever is in the window and past your JSON, hit “Done”, Done" and “Deploy”
Now you can inject your JSON into the flow.
Some math in the function node, or you can save DB space and do it when you display the data, if you use Grafana or the likes easy to do there.
I don’t like extra long JSON, only the necessities.
Save the electrons from flowing :smiling_imp:
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "type": "mqtt in",
        "qos": "2",
        "datatype": "json",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 220,
        "y": 260,
        "wires": [
                "059296a9a604036f"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "Distance",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "p": "dev_eui",
                "pt": "msg",
                "tot": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 510,
        "y": 260,
        "wires": [
                "a99ae555ccc4abb5"
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 530,
        "y": 360,
        "wires": []
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 870,
        "y": 260,
        "wires": []
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 230,
        "y": 360,
        "wires": [
                "99997bbb40d80fb0"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 360,
        "y": 360,
        "wires": [
                "059296a9a604036f",
                "1ae3c6d92610a908"
        "type": "comment",
        "info": "",
        "x": 210,
        "y": 320,
        "wires": []
        "id": "a99ae555ccc4abb5",
        "type": "function",
        "name": "level",
        "func": "msg.level =  msg.Distance - 2300\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 260,
        "wires": [
                "c4aa3711222d1081"
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
Very cool!
Okay that’s as i expected another approach to this “problem”.
I installed a calculator Plugin and did it with this.
        "id": "dec69ff8f39faf70",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "9c6d69e06c2386f7",
        "type": "change",
        "z": "dec69ff8f39faf70",
        "rules": [
                "t": "set",
                "p": "Distance",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "p": "dev_eui",
                "pt": "msg",
                "tot": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 430,
        "y": 240,
        "wires": [
                "c7fe070daa6649a2"
        "id": "9a2ef07e29a54a89",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 950,
        "y": 60,
        "wires": []
        "id": "c7fe070daa6649a2",
        "type": "calculator",
        "name": "-2300",
        "inputMsgField": "Distance",
        "outputMsgField": "Distance",
        "operation": "sub",
        "constant": "2300",
        "round": true,
        "decimals": "2",
        "x": 550,
        "y": 180,
        "wires": [
                "dc8fb232d449aaa2"
        "id": "dc8fb232d449aaa2",
        "name": "x-1",
        "operation": "mult",
        "constant": "-1",
        "round": true,
        "decimals": "2",
        "x": 670,
        "y": 140,
        "wires": [
                "11f0bf4bb0abba44"
        "id": "11f0bf4bb0abba44",
        "name": "x1,64x1,417",
        "outputMsgField": "Füllmenge",
        "constant": "2.32388",
        "round": true,
        "decimals": "0",
        "x": 810,
        "y": 100,
        "wires": [
                "9a2ef07e29a54a89",
                "ba2599eea969d74a"
        "id": "ba2599eea969d74a",
        "type": "influxdb out",
        "influxdb": "9f2a7e530ba069af",
        "name": "Influxdb fuellstandquelle",
        "measurement": "distanz",
        "precision": "",
        "retentionPolicy": "",
        "database": "database",
        "precisionV18FluxV20": "ms",
        "retentionPolicyV18Flux": "",
        "org": "organisation",
        "bucket": "bucket",
        "x": 1010,
        "y": 140,
        "wires": []
        "id": "06f471c9d70fc21f",
        "type": "mqtt in",
        "topic": "v3/fuellstandquelle@ttn/devices/+/up",
        "qos": "2",
        "datatype": "json",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 140,
        "y": 240,
        "wires": [
                "9c6d69e06c2386f7",
                "4962ee966ff9499e"
        "id": "4962ee966ff9499e",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 310,
        "y": 160,
        "wires": []
        "id": "9f2a7e530ba069af",
        "type": "influxdb",
        "hostname": "localhost",
        "port": "8086",
        "protocol": "http",
        "database": "fuellstandquelle",
        "name": "Influx DB fuellstandquelle",
        "usetls": false,
        "tls": "",
        "influxdbVersion": "1.x",
        "url": "http://localhost:8086",
        "rejectUnauthorized": true
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
That is my approach and it’s working and I’m fine with that…
Thats the calculator if you need it.
But I can’t save the result into my db.
Screenshot (42)
Screenshot (44)
Screenshot (43)
I have another question.
Is there a reason you are not deleting the “_msgid”?
The “_msgid” does not matter, used in node-red to ID the JSON packet.
This is a setting in your Influx DB, read there documentation on retention policies.
Far to many nodes needed.
Look at this flow.
        "type": "tab",
        "label": "Flow 2sddsdvv",
        "disabled": false,
        "info": "",
        "env": []
        "type": "mqtt in",
        "qos": "2",
        "datatype": "json",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 220,
        "y": 260,
        "wires": [
                "059296a9a604036f"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload.Distance",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "p": "payload.dev_eui",
                "pt": "msg",
                "tot": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 510,
        "y": 260,
        "wires": [
                "a99ae555ccc4abb5",
                "c4aa3711222d1081"
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 530,
        "y": 360,
        "wires": []
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 850,
        "y": 360,
        "wires": []
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 230,
        "y": 360,
        "wires": [
                "99997bbb40d80fb0"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 360,
        "y": 360,
        "wires": [
                "059296a9a604036f",
                "1ae3c6d92610a908"
        "type": "comment",
        "info": "",
        "x": 210,
        "y": 320,
        "wires": []
        "type": "function",
        "name": "level",
        "func": "msg.payload.Füllmenge =  (2300 - msg.payload.Distance)*2.32388\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 260,
        "wires": [
                "c4aa3711222d1081"
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
Well, when I’m looking at the two rows of code I’m feeling stupid… :smiley:
Thank you for showing me this solution.
Then there is only the problem with the DB left…
I’m very confused about the error.
I don’t mean the problem with the retention of the data…
I am here to learn, there are no stupid questions.
Try that flow, I had to brush up on Influxdb, not my 1st choice for a DB.
Yes, that’s true but sometimes I’m feeling stupid. even if I’m learning a lot of things by trying things iv never done before…
Error: A 400 Bad Request error occurred: {"error":"unable to parse 'distanz Distance=510,Füllmenge=4159.7452,dev_eui=\"\",end_device_ids=[object Object],received_at=\"2021-12-15T20:10:26.405479754Z\"': invalid boolean"}
There’s still the same error with the DB…
I would say that’s a problem with the “Measurement” in the DB Node
Because we did not delete ‘msg.payload.end_device_ids’ from the JSON
        "type": "change",
        "z": "454b7c0d2cc14647",
        "rules": [
                "t": "set",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "pt": "msg",
                "tot": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "payload.end_device_ids",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 450,
        "y": 1020,
        "wires": [
                "a99ae555ccc4abb5",
                "c4aa3711222d1081"
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 470,
        "y": 1120,
        "wires": []
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 790,
        "y": 1120,
        "wires": []
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 170,
        "y": 1120,
        "wires": [
                "99997bbb40d80fb0"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 300,
        "y": 1120,
        "wires": [
                "059296a9a604036f",
                "1ae3c6d92610a908"
        "type": "comment",
        "info": "",
        "x": 150,
        "y": 1080,
        "wires": []
        "type": "function",
        "name": "level",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 640,
        "y": 1020,
        "wires": [
                "c4aa3711222d1081",
                "ac3964d106fdecc3"
        "id": "ac3964d106fdecc3",
        "influxdb": "bb5dec3a1b53afc0",
        "name": "nodemap in",
        "precision": "",
        "bucket": "bucket",
        "x": 950,
        "y": 1040,
        "wires": []
        "id": "bb5dec3a1b53afc0",
        "type": "influxdb",
        "hostname": "127.0.0.1",
        "port": "8086",
        "protocol": "http",
        "database": "distanz",
        "name": "",
        "usetls": false,
        "tls": "7f61ad963cfa96fb",
        "id": "7f61ad963cfa96fb",
        "type": "tls-config",
        "name": "",
        "cert": "",
        "key": "",
        "ca": "",
        "certname": "",
        "keyname": "",
        "caname": "",
        "servername": "",
        "verifyservercert": true,
        "alpnprotocol": ""
Yes, you are completely right. The only thing I don’t like is that now I’m saving “Füllmenge” values like this: “4157.4213199999995”. I need to fix this in the next step.
Why does this message make this problem?
I need to understand what I’m able to save and what doing errors are like this.
I have a similar problem with a flow but there is no msg like that.
        "id": "9c24fe17e2b4595c",
        "type": "tab",
        "label": "Flow 5",
        "disabled": false,
        "info": "",
        "env": []
        "id": "095152322e671325",
        "type": "mqtt in",
        "z": "9c24fe17e2b4595c",
        "name": "Temparatur ",
        "topic": "v3/themparatur1@ttn/devices/+/up",
        "qos": "2",
        "datatype": "json",
        "broker": "0609d37da1a4a29b",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 370,
        "y": 280,
        "wires": [
                "26c486158f93296b",
                "808a392ee0f14c26"
        "id": "0c34f16c12515dd8",
        "influxdb": "29f2f16219709fb9",
        "name": "Influxdb temparatursensor1",
        "measurement": "sensorshopf",
        "precision": "",
        "bucket": "bucket",
        "x": 920,
        "y": 300,
        "wires": []
        "id": "26c486158f93296b",
        "type": "debug",
        "name": "",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 570,
        "y": 260,
        "wires": []
        "id": "36435addeb3bb719",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "statusVal": "payload",
        "x": 850,
        "y": 260,
        "wires": []
        "id": "808a392ee0f14c26",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "temp",
                "pt": "msg",
                "to": "payload.uplink_message.decoded_payload.TempC_SHT",
                "tot": "msg"
                "t": "set",
                "p": "hum",
                "pt": "msg",
                "to": "payload.uplink_message.decoded_payload.Hum_SHT",
                "tot": "msg"
                "t": "set",
                "p": "dev_eui",
                "pt": "msg",
                "tot": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "qos",
                "pt": "msg"
                "t": "delete",
                "p": "retain",
                "pt": "msg"
                "t": "delete",
                "p": "qos",
                "pt": "msg"
                "t": "delete",
                "p": "msg.payload.end_device_ids",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 570,
        "y": 300,
        "wires": [
                "36435addeb3bb719",
                "0c34f16c12515dd8"
        "id": "0609d37da1a4a29b",
        "name": "Temparatur Sensor",
        "port": "1883",
        "tls": "",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
        "id": "29f2f16219709fb9",
        "type": "influxdb",
        "port": "8086",
        "protocol": "http",
        "database": "temparatursensor1",
        "usetls": false,
        "tls": "",
Its a Dragino LHT65 and I’m filtering the messages the same way we did on the distance flow. But there is the same error but I only have the following messages.
{"_msgid":"8c0ece481a3c8051","temp":1.53,"hum":99.8,"dev_eui":"eui-a84041f4218401dc"}
And there is something else I want to know if I understand it correctly.
The “_msgid” is just a marker for the message in Node-red right?
It won’t be saved into the DB if I don’t delete it?
Its not in the db from the distance flow but im not sure if I understand this correctly.
It is just the accuracy of the calculation, you are using a constant of 2.32388, so you are going to get a few decimals.
Change the function node to
msg.payload.Füllmenge =  Math.round((2300 - msg.payload.Distance)*2.32388);
Yes, Influx needs the measurements as msg.payload.temp, msg.payload.hum, you are omitting the payload part.
Read the help
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload.temp",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "p": "payload.hum",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "pt": "msg",
                "tot": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "pt": "msg"
                "t": "delete",
                "p": "topic",
                "pt": "msg"
                "t": "delete",
                "p": "qos",
                "pt": "msg"
                "t": "delete",
                "p": "retain",
                "pt": "msg"
                "t": "delete",
                "p": "qos",
                "pt": "msg"
                "t": "delete",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 570,
        "y": 300,
        "wires": [
                "36435addeb3bb719",
                "0c34f16c12515dd8"
For node-red only, it is to keep track of JSON, there are a few other properties it adds in certain circumstances, but I will not go into that now.
Yeah, I know. I already wrote a similar code like you did to “fix” this. Now it’s working very well.
I don’t need the value to be that exact… It’s a water tank with a little over 4000l so it’s not important that the value is that exact.
Now everything is working :slight_smile:
I hat a lot of flows with this exact same “user error” and now all of them are up and running.
Thank you very much! you helped me there a lot! @Johan_Scheepers
