My sentrius RG186 gateway not connected
In my TTN console the gateway is disconnected.
Sin tĂ­tulo
My global_conf.json is the following :
  "SX1301_conf": {
    "lorawan_public": true,
    "clksrc": 1,
    "antenna_gain": 0,
    "radio_0": {
      "enable": true,
      "type": "SX1257",
      "freq": 867500000,
      "rssi_offset": -166,
      "tx_enable": true,
      "tx_freq_min": 863000000,
      "tx_freq_max": 870000000
    "radio_1": {
      "enable": true,
      "type": "SX1257",
      "freq": 868500000,
      "tx_enable": false
    "chan_multiSF_0": {
      "enable": true,
      "radio": 1,
      "if": -400000
    "chan_multiSF_1": {
      "enable": true,
      "radio": 1,
      "if": -200000
    "chan_multiSF_2": {
      "enable": true,
      "radio": 1,
      "if": 0
    "chan_multiSF_3": {
      "enable": true,
      "radio": 0,
      "if": -400000
    "chan_multiSF_4": {
      "enable": true,
      "radio": 0,
      "if": -200000
    "chan_multiSF_5": {
      "enable": true,
      "radio": 0,
      "if": 0
    "chan_multiSF_6": {
      "enable": true,
      "radio": 0,
      "if": 200000
    "chan_multiSF_7": {
      "enable": true,
      "radio": 0,
      "if": 400000
    "chan_Lora_std": {
      "enable": true,
      "radio": 1,
      "if": -200000,
      "bandwidth": 250000,
      "spread_factor": 7
    "chan_FSK": {
      "enable": true,
      "radio": 1,
      "if": 300000,
      "bandwidth": 125000,
      "datarate": 50000
    "tx_lut_0": {
      "pa_gain": 0,
      "mix_gain": 8,
      "rf_power": -6,
      "dig_gain": 0
    "tx_lut_1": {
      "pa_gain": 0,
      "mix_gain": 10,
      "rf_power": -3,
      "dig_gain": 0
    "tx_lut_2": {
      "pa_gain": 0,
      "mix_gain": 12,
      "rf_power": 0,
      "dig_gain": 0
    "tx_lut_3": {
      "pa_gain": 1,
      "mix_gain": 8,
      "rf_power": 3,
      "dig_gain": 0
    "tx_lut_4": {
      "pa_gain": 1,
      "mix_gain": 10,
      "rf_power": 6,
      "dig_gain": 0
    "tx_lut_5": {
      "pa_gain": 1,
      "mix_gain": 12,
      "rf_power": 10,
      "dig_gain": 0
    "tx_lut_6": {
      "pa_gain": 1,
      "mix_gain": 13,
      "rf_power": 11,
      "dig_gain": 0
    "tx_lut_7": {
      "pa_gain": 2,
      "mix_gain": 9,
      "rf_power": 12,
      "dig_gain": 0
    "tx_lut_8": {
      "pa_gain": 1,
      "mix_gain": 15,
      "rf_power": 13,
      "dig_gain": 0
    "tx_lut_9": {
      "pa_gain": 2,
      "mix_gain": 10,
      "rf_power": 14,
      "dig_gain": 0
    "tx_lut_10": {
      "pa_gain": 2,
      "mix_gain": 11,
      "rf_power": 16,
      "dig_gain": 0
    "tx_lut_11": {
      "pa_gain": 3,
      "mix_gain": 9,
      "rf_power": 20,
      "dig_gain": 0
    "tx_lut_12": {
      "pa_gain": 3,
      "mix_gain": 10,
      "rf_power": 23,
      "dig_gain": 0
    "tx_lut_13": {
      "pa_gain": 3,
      "mix_gain": 11,
      "rf_power": 25,
      "dig_gain": 0
    "tx_lut_14": {
      "pa_gain": 3,
      "mix_gain": 12,
      "rf_power": 26,
      "dig_gain": 0
    "tx_lut_15": {
      "pa_gain": 3,
      "mix_gain": 14,
      "rf_power": 27,
      "dig_gain": 0
  "gateway_conf": {
    "gateway_ID": "C0EE40FFFF29E058",
    "server_address": "eu1.cloud.thethings.network",
    "serv_port_up": 1700,
    "serv_port_down": 1700,
    "servers": [
        "serv_enabled": true
auto_awesome
QuizĂĄs quisiste decir: podrĂ­a alguien decirme porque Ă©sta no conectado
volume_up
47 / 5000
Resultados de traducciĂłn
Could someone tell me why it is not connected.
waiting for some answer, regards
Luis Valseca
Was it previously registered in V2?
Which firmware build?
How registered (legacy/UDP or basicstation or
) which instructions did you follow to register and if needed update gw?
Is there a known good working node in the area sending traffic?
Have you double checked correct device details (gw eui
What have you tried?
What does gw local dashboard show?
Hi Jeff-UK,
I answer after your questions :
I am not register in V2 never, i am new in this
Laird Linux gatwick-laird-93.9.6.12
In the sentrius RG-186 → LoRa → Select Preset = The Things Legacy - EU
In the sentrius RG-186 → LoRa → forwarder → Mode = Semtech Basics Station
In the sentrius RG-186 → LoRa → forwarder → LNS Server = wss://eu1.cloud.thethings.network:8887
In the sentrius RG-186 → LoRa → forwarder → LNS Certificates → Server Certificate File = isrgrootx1.pem
In the sentrius RG-186 → LoRa → forwarder → LNS Certificates → Key File = tc.Key
there is not a known good working node in the area sending traffic
i think yes
i test a lot of things
Sin tĂ­tulo
best regards
Luis Valseca
I havent started migrating my RG186’s yet so dont have 1st hand experience and mine are running a mix of earlier firmware builds but wonder if anything in this thread might help you
Also, as looks like you have set Basic-Station (gateway mode sbs?) am unsure if that works with your earlier selection of ‘The Things Legacy - EU’ - what other options do you see for this that might work with B-S?
Also I know with other B-S GW’s (i.e. TTIG’s) there were issues with connection keep alive (that have evolved over the last year or two!) hence asking if there is a known good node in the area - it may be you need to see traffic - in your case to initiate connection vs keep one alive - perhaps others can comment on this
I really need to crack on with moving more of my (Laird) GW’s now so perhaps I will find more to offer you myself in coming days
Check the log files (little up arrow at the bottom when logged in to the RG186) and click auto update. There should be a clue in there when it tries to connect.
Double and triple check the key file. See the other thread, the line ending must be perfect or it doesn’t work. Also if you change the file, delete it from the RG186 before reuploading or change the name eg tc2.key or it will appear to update but won’t.
2 posts were merged into an existing topic: Restriction of post on new accounts?
Hi bwooce,
I check the log files how you told me and a can see this:
[AIO:ERRO] Malformed URI - expecting ws(s)://host:port (no path, port mandatory) but found:wss://eu1.cloud.thethings.network:8887/
/opt/lora/basicstation/tc.uri: Misconfigured URI - expecting scheme ws: wss://eu1.cloud.thethings.network:8887/
No server URIs configured - expecting at least one of the following files to exist:
/opt/lora/basicstation/tc-boot.uri
/opt/lora/basicstation/tc-bak.uri
/opt/lora/basicstation/cups-boot.uri
/opt/lora/basicstation/cups-bak.uri
/opt/lora/basicstation/cups.uri
i think that LNS Server is ok, i have put wss://eu1.cloud.thethings.network:8887/
Could you tell me what happen, waiting some comment
best regards
Luis Valseca
i have remove de / that there was after 8887 and now i do not have this error, but the GateWay Connected still is false
i do not what happen
Progress at least, what are the errors now? did you hexdump the end of your key file to check the line endings?
I would see this setting as a problem:
“In the sentrius RG-186 → LoRa → Select Preset = The Things Legacy - EU”
Take a look at this topic:
Here is the dump log when i want to connect :
i can not see now any error, but the status is not cionnect
Luis Valseca
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|2021-07-07 11:08:12.695 [TCE:INFO] INFOS reconnect backoff 30s (retry 3)|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:08:12|2021-07-07 11:08:12.694 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|2021-07-07 11:07:52.685 [TCE:INFO] INFOS reconnect backoff 20s (retry 2)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:52|2021-07-07 11:07:52.685 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.681 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.681 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.679 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.678 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.674 [TCE:INFO] Starting TC engine|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.467 [SYS:WARN] Station in NO-CUPS mode|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.466 [SYS:INFO] Station temp: /var/tmp/ (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.466 [SYS:INFO] Station home: /opt/lora/basicstation/ (--home)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.466 [SYS:INFO] Station EUI : c0ee:40ff:ff29:e058|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.465 [SYS:INFO] prefix EUI : ::1 (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.465 [SYS:INFO] proto EUI : 0:c0ee:4029:e058 (/sys/class/net/eth0/address)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.465 [SYS:INFO] Package Ver : 1.0.0|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.464 [SYS:INFO] Station Ver : 2.0.5(laird/std) 2021-06-11 22:59:16|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|2021-07-07 11:07:42.464 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:42|Killing process 3813|
|RG1xx29E058|root|user.notice|Jul 7 11:07:41|3813|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.809 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.808 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.806 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.806 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.801 [TCE:INFO] Starting TC engine|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.592 [SYS:WARN] Station in NO-CUPS mode|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.592 [SYS:INFO] Station temp: /var/tmp/ (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.592 [SYS:INFO] Station home: /opt/lora/basicstation/ (--home)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.592 [SYS:INFO] Station EUI : c0ee:40ff:ff29:e058|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.592 [SYS:INFO] prefix EUI : ::1 (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.592 [SYS:INFO] proto EUI : 0:c0ee:4029:e058 (/sys/class/net/eth0/address)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.591 [SYS:INFO] Package Ver : 1.0.0|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.591 [SYS:INFO] Station Ver : 2.0.5(laird/std) 2021-06-11 22:59:16|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|2021-07-07 11:07:39.591 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:39|Killing process 3724|
|RG1xx29E058|root|user.notice|Jul 7 11:07:38|3724|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.846 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.845 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.844 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.843 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.838 [TCE:INFO] Starting TC engine|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:WARN] Station in NO-CUPS mode|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:INFO] Station temp: /var/tmp/ (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:INFO] Station home: /opt/lora/basicstation/ (--home)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:INFO] Station EUI : c0ee:40ff:ff29:e058|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:INFO] prefix EUI : ::1 (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:INFO] proto EUI : 0:c0ee:4029:e058 (/sys/class/net/eth0/address)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:INFO] Package Ver : 1.0.0|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.629 [SYS:INFO] Station Ver : 2.0.5(laird/std) 2021-06-11 22:59:16|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|2021-07-07 11:07:36.628 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:36|Killing process 3646|
|RG1xx29E058|root|user.notice|Jul 7 11:07:35|3646|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|2021-07-07 11:07:34.944 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|2021-07-07 11:07:34.943 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|2021-07-07 11:07:34.942 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|2021-07-07 11:07:34.941 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:35|2021-07-07 11:07:34.936 [TCE:INFO] Starting TC engine|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:WARN] Station in NO-CUPS mode|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:INFO] Station temp: /var/tmp/ (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:INFO] Station home: /opt/lora/basicstation/ (--home)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:INFO] Station EUI : c0ee:40ff:ff29:e058|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:INFO] prefix EUI : ::1 (builtin)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:INFO] proto EUI : 0:c0ee:4029:e058 (/sys/class/net/eth0/address)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:INFO] Package Ver : 1.0.0|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.727 [SYS:INFO] Station Ver : 2.0.5(laird/std) 2021-06-11 22:59:16|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|2021-07-07 11:07:34.726 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)|
|RG1xx29E058|lora|user.notice|Jul 7 11:07:34|Killing process 2729|
|RG1xx29E058|root|user.notice|Jul 7 11:07:33|2729|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|2021-07-07 11:06:55.431 [TCE:INFO] INFOS reconnect backoff 60s (retry 6)|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:55|2021-07-07 11:06:55.430 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|2021-07-07 11:06:05.423 [TCE:INFO] INFOS reconnect backoff 50s (retry 5)|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:06:05|2021-07-07 11:06:05.423 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|ntpd|daemon.info|Jul 7 11:05:55|kernel reports TIME_ERROR: 0x41: Clock Unsynchronized|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|2021-07-07 11:05:25.415 [TCE:INFO] INFOS reconnect backoff 40s (retry 4)|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:05:25|2021-07-07 11:05:25.414 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|2021-07-07 11:04:55.406 [TCE:INFO] INFOS reconnect backoff 30s (retry 3)|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:55|2021-07-07 11:04:55.405 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|2021-07-07 11:04:35.396 [TCE:INFO] INFOS reconnect backoff 20s (retry 2)|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:35|2021-07-07 11:04:35.396 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|2021-07-07 11:04:25.392 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|key usage : K|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|basic constraints : CA=true|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|RSA key size : 4096 bits|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|signed using : RSA with SHA-256|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|expires on : 2035-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|issued on : 2015-06-04 11:04:38|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|subject name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|issuer name : C=US, O=Internet Security Research Group, CN=ISRG Root X1|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|serial number : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|cert. version : 3|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|2021-07-07 11:04:25.392 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|2021-07-07 11:04:25.390 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|2021-07-07 11:04:25.389 [any:INFO] /opt/lora/basicstation/tc.trust:|
|RG1xx29E058|lora|user.notice|Jul 7 11:04:25|2021-07-07 11:04:25.384 [TCE:INFO] Starting TC engine|
Hi everyone I hope you are doing well, I am trying to connect my Laird gateway to the TTN but it seems that I do not have the right firmware version. So please can you check it with me. If I need to update the firmware which link I can use I found a lot. Thanks a bunch.
It loooks like you are targeting the old V2 instance of TTN - wrong server - no longer operational. No doubt due to selecting a preset in the LoRa TAB which, depending on revision/age of f/w will still have old defaults.
Manually go in and simply change server to eu1.cloud.thethings.network, keep port 1700 and change Packet Forwarder to Semtech legacy if not already set for that - ignore any calling out TTN. Should then be golden. You could update f/w if needed and go the BasicStation route but a bit more complex and whilst more ‘secure’ I find my old Lairds are working fine on V3 with UDP with no issues and no significant packet loss to date.
Thanks a bunch, much appreciated :smiley:
