New Application - missing generate Button for EUI
Hi all,
i am trying to migrate my v2 stuff to v3. Partially i like to create new Applications (to get clean) - and i stumbled across the missing generate EUI Button from v2 Console.
So this is a feature-request - please implement the generate Button once more - and another one
Maybe implement a copy Arduino LMIC template…
static const u1_t PROGMEM APPEUI[8]={ FILLMEIN };
static const u1_t PROGMEM DEVEUI[8]={ FILLMEIN };
// practice, a key taken from ttnctl can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = { FILLMEIN };
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
Feature requests have to be made on GitHub - but this one is unlikely to be done - devices should have officially assigned EUI’s with them - maker devices can generate ones using tools you can find on the forum.
Why don’t YOU do it - we are a community forum after all?
ok; Thanks for the fast answer; I’ll check for the tools;
Not really…
See: Generating DevEUI in V3 Console still not possible
