No, that really doesn’t happen at the power levels involved. And given that the case is plastic, the postulated effect wouldn’t happen either.
One’s eyes are not electrical test instruments. Nor are they able to see the internal function of MCU software.
The tools you should be using are a storage scope watching the power rail (or else some improvisation like an Ardiono ADC input), and debug output from the MCU firmware run through a recording serial terminal program.
It also looks like you have a switching power supply in there, which in addition to your present reboot problem could be generating noise de-sensitizing your receiver, or in an extreme case corrupting transmissions.
I have seen this type of problem several times, with the Pro Mini resetting when the transmitter is turned on. Changes to the antenna, wiring or shielding and\or waving your hand around etc can make the problem better or worse. The same problem, the resetting, occurs when switching loads such as GPSs that are connected to VCC on the Pro Mini.
The problem can be significantly reduced by changing the brownout level. The brownout level set on every 3.3V Pro Mini I have used in the last 4 years or so has been 2.7V. Thats a bit to close for 3.3V operation and way to close for 3.0V operation. Small short duration spikes on the VCC supply which dont otherwise affect operation can cause the Pro Mini to reset and its not helped by the generally poor supply decoupleing and regulators used.
On every 3.3V Pro Mini I use, I set the fuses for 1.8V brownout and reset problems are then very rare.
These are good points.
It may be best not to use the on-board regulator to power other loads. And for a battery powered project one probably wants to replace it with one having lower quiescent current anyway. Also for old-style FTDI based designs the output current which the on-chip regulator can supply is very limited (though hopefully those are not showing up in a battery-powered context)
But brownout is not necessarily downstream of the regulator, either - many types of batteries will sag under high load, and so the actual input to the regulator can sag far enough to put it into dropout.
With a reduced clock (and there isn’t really any need for a fast one) an ATmega will run at quite low voltages.
Hi, I hope that my approach will help you as it helped me. On the other hand it would be perfect if someone could explain why it works?
I had exactly same issue. When board was out of the enclosure or sometimes when I tried to move the wires inside of the enclosure, it was working. But when I closed the cover it happened that right after the connected to TTN, the board rebooted and all started over. I figured out that it is not during the sending phase but during the receiving phase. Probably something with induction.
I tried several things that I have found on the internet - capacitors between Vcc and Ground of RFM95, on the arduino board. Place pull up resistor to reset pin on the arduino, … And nothing worked.
I was so desperate that I was just trying to place the capacitor on different places… And at the end I placed the 104 capacitor (0.1 uF) between the end of the helical antenna and ground. And it just started to work in all places I tried - Inside the enclosure, outside enclosure and in any position I tried. And I did not found any issue with worse signal strength (from the TTN console).
I think that I made a filter but don’t know what filter it is. The upper pass or lower pass filters are normally made of a capacitor and a resistor. Here, only a capacitor and on very strange place is used.
I am uploading pictures with my board. I know it is a nasty hack, but works. If someone can explain what the hell is that, then we might to find a proper solution.
Can you, verify, whether it works on your board as well? According to your photos, the antenna and GND pind on arduino is not far so capacitor can be used exactly as in my case
I would not be playing with the antenna impeadnce in that way, you dont know if its going to destroy the RFM95.
As I mentioned earlier, the first thing I do to my 3.3V Pro Minis is set them to a sensible brownout voltage.
So far it is deployed on 15 boards that are working fine for several weeks so far. I would like an explanation from someone who knows why it is working.
The messages like “you’re going to destroy everything” are fine, but it will not help me anything.
I think that if there someone who understand the problematic, we can find a proper solution for this. In case @Miwo can try the same approach, maybe he can tell you whether it works as well on his side…
Unless you are sure you know the characteristic impedance of a particular type of 0.1uF decoupling capacitor at the frequency involved, then indeed you, or others, could be indeed be "going to destroy everything”. Ceramic capacitors vary considerably in the dielectric type used and characteristics at RF. Attaching random capacitors to the end of an antenna is not recommended, unless you know its impedance.
As a minimum you would be needing to use some form of antenna tester to see how much the capacitor has messed up or changed the antenna tuning.
A more constructive elimination test would be to check and set the brownout voltage for the Pro Mini. If you have a bad antenna (and those coil things are often not good) then you can get large amounts of reflected power back onto the VCC of the Pro Mini, which can trigger a brownout reset.
I do not mind too much, risking my node (or the node’s RFM95) by attaching a capacitor to the end of the antenna, so I am considering to do it, especially as I already played with wires of different length attached as a replacement for the antenna and noticed that this had a significant impact on the behaviour of my node.
Testing will be a little bit unprofessional, though, as the reproducibility of the effects observed are limited and I do not know of measurements I could really perform except from reporting the effect and maybe some RSSI and S/N values.
And as mentioned before, I am an absolute dummy regarding antenna design and RF behaviour which is why my initial question was: “Has anyone seen this strange type of behaviour (rebooting during/after sending)”. Now, I know the answer is yes.
@LuckyV: Thank you for “admitting” and by the way: It is probably rebooting during receive as well here as I see the activate message on the gateway but no answer. I have not been sufficiently precise before regarding this detail.
I must also admit that I have no means (technical/knowledge) to do an assessment of impedances and antenna effects, whatsoever. Even measuring ultra short drops in the voltage for the Pro Mini which might cause brown-outs are - missing a real memory oscilloscope - out of scope for me - Yes, I could attach another Arduino as such.
It, however, sounds reasonable to reduce the brown-out value to something lower, taking care that it does not affect the functionality of the Pro Mini or any of the sensors attached.
What I do not understand is this:
How does the power from the antenna reflect onto VCC? How are the internal connections in the RFM95 causing reflection to induce something back on VCC? Couldn’t it as well induce voltage to GND, thus lowering VCC by this amount comparatively and so causing a brownout?
At least, as far as I understood, you can destroy the RFM module by not having attached an antenna due to reflection at the open pin, although this piece of hardware seems quite robust to me.
I will update here if I know more.
@Miwo, good to know that I am not the only one. My symptoms looks exactly same as yours.
I am dummy as well and in simmilar situation - no oscilloscope and so on.
Maybe there could be made any low pass / high pass filter on the antenna pin to only accept the frequencies somewhere near 868 MHz. Somehow I think that the capacitor does something like that. But, thinking is too far from knowing…
Regarding this, I was trying to attach electrolytic capacitor between GND anv Vcc of Arduino to hold the voltage in case there is any spike when receiving. But maybe the capacitor was still too small or I don’t know - simply there was no change and restarts was still there.
So far I have to use my capacitor-on-antenna solution until someone finds a better one
You can ask the MCU the reason for reset:
In addition to turning off/down the BOD, you could try reducing the transmit power on the radio to see if that makes a difference. Firmware bugs can also cause a sudden reset.
I don’t recommend soldering random capacitors to the end of the antenna.
This is wrong on so many levels…
At the frequencies involved one must also consider the inductance of the leads of your capacitor, and the PCB traces. It would take fairly expensive RF geometric modeling software to figure out exactly what you’ve done, but it is a thoroughly bad idea.
Your success at this point is pretty much pure coincidence - you have an actual issue (perhaps with a noisy power supply) and you do not currently know what it is.
Did you try my suggested modifications to your code?
The default state of I/O is input mode. The standard input protection circuitry on an input has an effective diode pull-up to VCC. RF input on an unterminated input is passed by the input protection diode to the VCC. High values of RF and/or insufficient bypass on the inputs and power supply decoupling will cause all sorts of problems. This is why I suggested setting all unused pins to outputs.
I tried to say so at the beginning. But because it is so far the only working solution, I am using what I have… With my next board I can try the things that @Sandgroper proposed.
No, that would make it unusable. The VCC clamp diode is a pull down for out of range pin voltage, it’s the GND clamp diode that could be viewed as a pull up.
Probably not. Go ahead and calculate the voltage needed to forward bias the diode compared to the available RF power levels. Then calculate the amount of power able to be delivered into the supply rail.
If this were a broadcast transmitter you might have a point…
I am not wrong. Page 58 of the Atmega328p datasheet (http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-7810-Automotive-Microcontrollers-ATmega328P_Datasheet.pdf) shows the I/O Pin Equivalent circuit for this processor clearly showing the protection diode to the power rail. This is why you also see cheap level converters from 12 volt to +5v of the processor using a simple series resistor as opposed to a traditional level converter with the series resistor limiting the input current.
No, you are wrong. There is a diode of course, but as I explained, the direction is opposite of what you claimed.
You erroneously claimed “The standard input protection circuitry on an input has an effective diode pull-up to VCC.”
Because a diode would be a very “stiff” pullup, having a diode in that direction would make the pin essentially unusable - you wouldn’t be able to internally or externally drive the pin more than a diode drop below VCC without overstressing and cooking the diode.
In actual fact the IO clamp diode is oriented the other way, it is a “pull down” preventing the voltage on the pin from exceeding VCC by more than a diode drop.
The other diode prevents the voltage from dropping more than a diode drop below ground.
So two things happen with the input protection diodes. The input protection diode to VDD will result in the VDD increasing. You see this effect when you power off the processor by removing the power to the regulator and yet the processor can still run because it is being powered via voltages being present on the input pins. How much it raises VDD depends on many factors but it is easy to test.
The pull down diode (from input to ground) has the opposite effect, a negative signal below the ground rail, will drive the ground rail lower.
If the power supply impedance to the processor power pins is not low enough the power rails will effective be modulated by the RF signal. There is nothing clean about this.
As I pointed out several posts ago, that would only be true if the diode actually becomes forward biased. Given the absolute maximum ratings are half a volt outside the rails, that’s going to require something like 500-600 mV amplitude at the receiving side of the coupling - or several volts if the pin wasn’t already DC biased to the rail.
For a DC source like an externally driven I/O, sure, but you are proposing coupled RF, which is unlikely to be coupling enough energy to raise the rail much at all.
If this were a high power transmitter, you might have a point. But at the power levels actually supported, it’s a bit unlikely.
If the supply biasing doesn’t create a low impedance at RF, then your digital circuitry is itself a radio jammer splattering harmonics of clock fractions all over the place.
I have same problem on my board. I developed my board, and one board sometimes go to reboot loop. I found out that this happens when there is no antena attached to this SMA connector, or antenna is small and bad. Try to solder another antenna.
